Re: Toshiba Satellite - Locks up when plugged in
I don't have available a laptop donor board.
I have to buy new capacitors from Ebay.
This result comes from division 6/4=1.5?
Take 4x 330uF aluminum SMD capacitors from CPU VCore section of a laptop donor board.
NEC Tokin ESR is 1 to 2 ohms. ESR of replacement cap should preferably be close to 6 ohms so 4x in parallel means 1.5 ohm total ESR.Leave a comment:
I have an Acer Aspire 6935g which seems it needs replacement of the NEC TOKIN capacitor.
330uf tantalum need to be SMD (https://www.ebay.com/itm/4-x-SMD-Tan...8/232303050868) or are ESR also OK (https://www.ebay.com/itm/4pcs-ESR-7-...332242655643)?
Are these capacitors below, 470uf tantalum low ESR?
https://www.ebay.com/itm/T520D477M00...m/193458822505Leave a comment:
Just when I thought I'd fixed it....oh well.
Got an old Toshiba Satellite from a garage sale, $3/for parts-only it read. I had another I had gotten for free(thrown out)that was missing keys on the keyboard, so for $3 I figured what the heck, $3 keyboard. Thing is...it booted/ran fine, ...added cheap ssd/core2duo CPU upgrades, ended up with a nice laptop for browsing/messing around with....except for the freeze with AC adapter plugged in(guess the owners figured it was toast or close to it).
After finding this site I tried my lack of skills at soldering and purchased 4x470uf tantalum low ESR and was able to remove/replace. Not the best soldering job for sure, but I got it to work with the A/C adapter(no more freezing), and it ran great...
...for a couple months.
Today I went to turn it on and it powers up for about 6 seconds(briefly shows boot-up screen)...then it powers down. I tried the pull battery/adapter, hold power button trick...no change. With battery only the charging LED(orange)blinks with no response, with adapter I get 6 seconds boot/then dead.
Tore it apart(ugh)again and tried disconnecting this and that, memory modules in/out, different power adapter/batteries...no luck....6 seconds on/then dead.
Sad, was fun while it lasted...thinking it could be 1/more of the caps went bad or need re-soldered, but I have no idea...not really wanting to spend much more time with it, unless you guys have any suggestions.Leave a comment:
The leads need to be very short.Leave a comment:
[QUOTE=BleedCap;767512]I got Acer 6920g that wont post.
Can I replace nec tokin with polymer cap like from desktop motherboard as a replacement?
Not permanently, just as a test before I get the tantalum.
Virtually , you can put any kind of capacitors , but the smd tantalum capacitors do not have liquid , but solid electrolyte , contrarily to some Aluminium polymers ..
Anyway , read this :
By the way , and in a strange coincidence , i'm too repairing an Acer 6920 G . i've already applied the new 4 capacitors , but the laptop now on normally with a blurry picture , so i'm working now on the Nvidia slot card .Last edited by SMDFlea; 09-18-2020, 09:17 AM.Leave a comment:
Have always used 4x 330uF pulled from scrap boards, always the black ones with gray writing. Lost count of how many machines i did this replacement on. Not a single one ever came back. I actually have one in to fix at this time.Leave a comment:
Yes you can use it. Many people here in this thread did that.Leave a comment:
Just a quick help here.
I got notebook with the same problem.
I disassembled it and I found a WR 2R5 901 proadlizer.
The motherboard diagram shows as PFAF250E907MCBTE part number, which seens a 900uf / 2.5v / ESR 1.5 nec tokin (0E907).
I can only found a 330uf/2.5/ESR 9 as a replacement. Can I use it?
4x 330 = 1320 uf
4x ESR9 paral. = 2.25 mOhmLast edited by xisque; 07-16-2017, 11:51 AM.Leave a comment:
I've just repair an Acer Aspire 6920G with the same OE907 chip and the same failure.
Thanks a lot!Leave a comment:
If it happens again, it will be much easier next time now the nec tokin has been removed.
Hopefully I will have a better iron next time as well. I'm a total beginner.Leave a comment:
Actually 330uf x 4pcs isn't really sufficient in value, since OE907 new measured with ESR meter show almost 1300uf.
Now 470uf tantalum low ESR is easily available, 4pcs of these last a long time before need to replace it again.
Big thanks for this thread !
I managed to fix my L350 myself with a really awful iron.
I used 4 330uf Panasonic Capacitor (2R5TPE330MF)
Final result, a bit ugly but 100% working !
i am having problem with my toshiba c855, it always restarts after 5minutes if working, i have tried all the over heating stuff, replaced the hardisk and the ram but the problem still persist, plz i need your helpLeave a comment:
can you help me with my toshiba c855, am having the same problem and i was unable to detect the nec tokey on the motherboardLeave a comment:
Hey all,
To keep me busy when not working I buy used motherboards with bad CPU pins to fix. Long story short I lolled when I saw this board and it's issue, look next to the CPU socket(towards the I/O) to find the TEC chip.
Asus Maximus IV Extreme
http://www.ebay.com/itm/ASUS-MAXIMUS...3D222217845967
Might pick it up, if I didn't have so many projects already.Last edited by Philly Cheese Steak; 08-19-2016, 04:02 AM.Leave a comment:
Take a look on schematics from other similar laptops, there you will find your answer. Me, i have always used capacitors marked "330" from scrap boards, like this:
None of the fixed laptops ever came back.Leave a comment:
This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...09-06-2024, 06:10 AM
This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...09-06-2024, 05:40 AM
This specification for the Toshiba Satellite Pro C660-1NQ can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the C660-1NQ boardview and C660-1NQ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...09-06-2024, 05:27 AM
This specification for the Toshiba Satellite Pro Satellite Pro R50-EC-11J Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-EC-11J boardview and Satellite Pro R50-EC-11J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...09-06-2024, 08:10 PM
- Loading...
