Toshiba Satellite - Locks up when plugged in
  • Alessio
    • Mar 2013
    • 6
    • iTALIA
    #761
    Re: Toshiba Satellite - Locks up when plugged in
    Hello
    .....my stupid question of the day!
    Can I use normal electrolytic capacitors instead of Tantalum ?
    or, I can add to the nec tokin a capacitor instead of replacing it ?
    Tnx!
    Acer 6920G
    • mockingbird
      • Dec 2008
      • 5483
      #762
      Originally posted by Alessio
      Hello
      Tnx!
      Acer 6920G
      They need to meet the following criteria:
      1) They will need to be short enough so that you can put back the laptop together properly afterwards. You're supposed to use V case size tantalum, which is 2mm high. You might be able do get away with D size tantalums, which are 2.8mm high...
      2) They need to have an ESR of 0.015. Maybe you can get away with a higher ESR, but not that much higher. A preliminary search on Digikey reveals no suitable Ultra-Low ESR radial electrolytic or polymer capacitors.
      So practically, the answer is no. You can use either ceramic caps or chip-type caps (Tantalum, niobium, organic aluminum).
      "We have offered them (the Arabs) a sensible way for so many years. But no, they wanted to fight. Fine! We gave them technology, the latest, the kind even Vietnam didn't have. They had double superiority in tanks and aircraft, triple in artillery, and in air defense and anti-tank weapons they had absolute supremacy. And what? Once again they were beaten. Once again they scrammed [sic]. Once again they screamed for us to come save them. Sadat woke me up in the middle of the night twice over the phone, 'Save me!' He demanded to send Soviet troops, and immediately! No! We are not going to fight for them."
      -Leonid Brezhnev (On the Yom Kippur War)
      • Alessio
        • Mar 2013
        • 6
        • iTALIA
        #763
        Thanks mockingbird!
        http://myboct.blogspot.it/2011/09/to...c-adapter.html
        Is a bad fix or good idea?
        • toni comp
          • May 2012
          • 10
          • indonesia
          #764
          please visit my blog http://newbielaptop.wordpress.com/20...-kerusakannya/
          • mockingbird
            • Dec 2008
            • 5483
            #765
            Thanks mockingbird!
            I don't like it. There are small traces there and small components, personally I think it's easier doing it the regular way.
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              #766
              Yep... Just rip apart the Tokin and solder the new capacitors in its place.
              A working TV? How boring!
              • holmes222
                • Aug 2009
                • 61
                • INA
                #767
                can i replace tokin with this type http://id.mouser.com/ProductDetail/A...1IGMRLIg%3D%3D
                • rievax_60
                  • May 2012
                  • 897
                  • australia
                  #768
                  Originally posted by holmes222
                  The ESR is too high. Most of us use capacitors with 9 milliohms of ESR which is 100X better than 0.9 ohms. I use 2R5TPE330M9.
                  • hnn49
                    • Jan 2015
                    • Malaysia
                    #769
                    After I remove the NEC tokin 128, with CPU installed, the outer + strip is shorted with inner - strip, is this normal?
                    I not yet solder the new capacitor on the board.
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      #770
                      Yes it is normal. The CPU has a low internal resistance and you're mistaking that for a short. As long as it reads anything else than 000 on your meter it is not a dead short, and it is normal for such a low voltage, high current circuit.
                      I understand that if you remove the CPU, the "short" goes away. If so, there is no problem with the board. Go ahead and solder your tantalum capacitors and it will work fine.
                      • Marbc
                        • Jan 2015
                        • 8
                        • Philippines
                        #771
                        What is the maximum height and leakage current of the capacitor that may be used?
                        • hnn49
                          • Jan 2015
                          • Malaysia
                          #772
                          OK, understand.
                          Before I solder the tantalum capacitors, if I power on the motherboard, will I get any voltage between outer + strip and inner - strip ?
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            #773
                            Of course, but it is really NOT a good idea to power it on without capacitors as you may damage the MOSFETs.
                            • grotkilla
                              • Dec 2014
                              • ireland
                              #774
                              hey guys thanx for the great work!
                              is it safe enough to leave the CPU in when carrying out the work (especially the soldering)?
                              • rievax_60
                                • May 2012
                                • 897
                                • australia
                                #775
                                Yes, I think so, I leave it in every time. I have not been able to realize any possible risk. So long as you are using the same method of prying the old capacitor from the PCB.
                                • polytek
                                  • Dec 2013
                                  • 496
                                  • TUNISIA
                                  #776
                                  the best method to replace nectokin
                                  • bonniedoon
                                    • Jan 2015
                                    • 22
                                    Hi peoples, I have an A300 that needs to have the NEC Tokin 0E907 replaced. Now I am a novice at this sought of thing, so can some please post a complete fix: this would be from the removal of the Tokin, cleaning the 4 strips and how to solder the 4 new capacitors, including the soldering method, Photos of each stage. Also, what one has to to do to determine the corrects Tantalums. I have seen these Tatalums on ebay where they state them as being a replacement for the Nec Tokin 0E907. http://www.ebay.com.au/itm/4x-SMD-Ta...-/330953629462 Thanks peoples
                                    • bonniedoon
                                      • Jan 2015
                                      • 22
                                      Would these caps do the job for my previous post.
                                      http://au.mouser.com/ProductDetail/K...1myMofWw%3D%3D
                                      • mockingbird
                                        • Dec 2008
                                        • 5483
                                        #779
                                        These are a better match:
                                        http://au.mouser.com/ProductDetail/K...sMqWJK5Fxn0%3d
                                        • mcrap
                                          AdvancedBF
                                          • Nov 2014
                                          • 5
                                          • Portugal
                                          #780
                                          Originally posted by benmah
                                          I have nec tokin Oe128 replaced with 4x 330e75 tantalum cap (i believe it a 330uf 2.5V cap). It works perfectly without fail after one yrs but I think it has cause my build-in multi card not to work any more from the beginning. Then I replace it with the orignal nec tokin 0e128. It still works but 2 month till now it starts to show sign of failing. It happen few days ago 3 times cut off suddenly. Now I plan to put back the 4 x 330e75 cap. Don't waste time on the 0e128 cap as it is not durable. I believe it has a 5000hrs life span on a ideal condition from the datasheet. Take a look at the pic. I use only a normal soldering gun. I just break the 0e128 with a test pen and small long nose pliers carefully. Clean up the contacts. Then carefully solder. Hope this helps U guys out there.
                                          Did you solded the 4 caps touching one in the other?
                                          It seems that they are touching one with each other...
                                          Can you explain better how I must put they, and is possible to all this procedure just with an normal soldering gun. even remove the Nec cap...?
                                            Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 06:10 AM
                                            Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 05:40 AM
                                            09-06-2024, 05:27 AM
                                            Toshiba Satellite Satellite P50t-C-111 Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Satellite P50t-C-111 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite P50t-C-111 boardview and Satellite P50t-C-111 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 08:10 PM
