Toshiba Satellite - Locks up when plugged in
  • Philly Cheese Steak
    • Mar 2011
    • 114
    Re: Toshiba Satellite - Locks up when plugged in
    Hey all,
    To keep me busy when not working I buy used motherboards with bad CPU pins to fix. Long story short I lolled when I saw this board and it's issue, look next to the CPU socket(towards the I/O) to find the TEC chip.
    Asus Maximus IV Extreme
    http://www.ebay.com/itm/ASUS-MAXIMUS...3D222217845967
    Might pick it up, if I didn't have so many projects already.
    X99 5930K
    X99-gaming 9
    EVGA 1080 Vanilla
    Gskill 16GBRip JAWS@2400
    SSD'S
    Corsair AX1200
    • muib
      • Nov 2016
      • Nigeria
      #942
      Originally posted by Rainbow
      Just fixed one Satellite A300. This is caused by a bad cap. A big one - NEC/TOKIN 0E907 (900uF/2.5V) under the CPU. Mine had 900uF but probably lost some of its magic, resulting in >100mV ripple on CPU power. Adding 1x 100uF and 5x 10uF ceramic caps fixed the problem.
      can you help me with my toshiba c855, am having the same problem and i was unable to detect the nec tokey on the motherboard
      • muib
        • Nov 2016
        • Nigeria
        #943
        i am having problem with my toshiba c855, it always restarts after 5minutes if working, i have tried all the over heating stuff, replaced the hardisk and the ram but the problem still persist, plz i need your help
        • zetabo
          • Oct 2016
          #944
          Big thanks for this thread !
          I managed to fix my L350 myself with a really awful iron.
          I used 4 330uf Panasonic Capacitor (2R5TPE330MF)
          Final result, a bit ugly but 100% working !
          • jeremykum
            • Feb 2012
            • 95
            • Malaysia
            #945
            Actually 330uf x 4pcs isn't really sufficient in value, since OE907 new measured with ESR meter show almost 1300uf.
            Now 470uf tantalum low ESR is easily available, 4pcs of these last a long time before need to replace it again.
            Mainly repair laptops, sometimes LCD/LED monitors. Also accepts changing/reballing/reflow BGA job request.
            • zetabo
              • Oct 2016
              #946
              Alright, thanks, good to know.
              If it happens again, it will be much easier next time now the nec tokin has been removed.
              Hopefully I will have a better iron next time as well. I'm a total beginner.
              • alderick
                • Jun 2015
                • 76
                • france
                #947
                I've just repair an Acer Aspire 6920G with the same OE907 chip and the same failure.
                Thanks a lot!
                • xisque
                  • Jul 2017
                  • Brazil
                  #948
                  Just a quick help here.
                  I got notebook with the same problem.
                  I disassembled it and I found a WR 2R5 901 proadlizer.
                  The motherboard diagram shows as PFAF250E907MCBTE part number, which seens a 900uf / 2.5v / ESR 1.5 nec tokin (0E907).
                  I can only found a 330uf/2.5/ESR 9 as a replacement. Can I use it?
                  4x 330 = 1320 uf
                  4x ESR9 paral. = 2.25 mOhm
                  • Napalm
                    • Mar 2013
                    • 20
                    • Portugal
                    #949
                    Yes you can use it. Many people here in this thread did that.
                    • xisque
                      • Jul 2017
                      • Brazil
                      #950
                      Can you explain a little more? These ESR values are a way off the original. Is this problematic? How much?
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        #951
                        Have always used 4x 330uF pulled from scrap boards, always the black ones with gray writing. Lost count of how many machines i did this replacement on. Not a single one ever came back. I actually have one in to fix at this time.
                        A working TV? How boring!
                        • BleedCap
                          • Aug 2015
                          • 30
                          • Malaysia
                          #952
                          I got Acer 6920g that wont post.
                          Can I replace nec tokin with polymer cap like from desktop motherboard as a replacement?
                          Not permanently, just as a test before I get the tantalum.
                          • jiroy
                            • Jun 2016
                            • 2416
                            • Lebanon
                            #953
                            [QUOTE=BleedCap;767512]I got Acer 6920g that wont post.
                            Virtually , you can put any kind of capacitors , but the smd tantalum capacitors do not have liquid , but solid electrolyte , contrarily to some Aluminium polymers ..
                            Anyway , read this :
                            By the way , and in a strange coincidence , i'm too repairing an Acer 6920 G . i've already applied the new 4 capacitors , but the laptop now on normally with a blurry picture , so i'm working now on the Nvidia slot card .
                            • rievax_60
                              • May 2012
                              • 897
                              • australia
                              #954
                              The leads need to be very short.
                              • fstheatr
                                • Feb 2017
                                Just when I thought I'd fixed it....oh well.
                                Got an old Toshiba Satellite from a garage sale, $3/for parts-only it read. I had another I had gotten for free(thrown out)that was missing keys on the keyboard, so for $3 I figured what the heck, $3 keyboard. Thing is...it booted/ran fine, ...added cheap ssd/core2duo CPU upgrades, ended up with a nice laptop for browsing/messing around with....except for the freeze with AC adapter plugged in(guess the owners figured it was toast or close to it).
                                After finding this site I tried my lack of skills at soldering and purchased 4x470uf tantalum low ESR and was able to remove/replace. Not the best soldering job for sure, but I got it to work with the A/C adapter(no more freezing), and it ran great...
                                ...for a couple months.
                                Today I went to turn it on and it powers up for about 6 seconds(briefly shows boot-up screen)...then it powers down. I tried the pull battery/adapter, hold power button trick...no change. With battery only the charging LED(orange)blinks with no response, with adapter I get 6 seconds boot/then dead.
                                Tore it apart(ugh)again and tried disconnecting this and that, memory modules in/out, different power adapter/batteries...no luck....6 seconds on/then dead.
                                Sad, was fun while it lasted...thinking it could be 1/more of the caps went bad or need re-soldered, but I have no idea...not really wanting to spend much more time with it, unless you guys have any suggestions.
                                • zinksoft.net
                                  • Nov 2013
                                  • 17
                                  • malaysia
                                  #956
                                  try add 2 more caps on it.
                                  • Aurumnus
                                    • Sep 2020
                                    • 6
                                    • Greece
                                    #957
                                    I have an Acer Aspire 6935g which seems it needs replacement of the NEC TOKIN capacitor.
                                    330uf tantalum need to be SMD (https://www.ebay.com/itm/4-x-SMD-Tan...8/232303050868) or are ESR also OK (https://www.ebay.com/itm/4pcs-ESR-7-...332242655643)?
                                    Are these capacitors below, 470uf tantalum low ESR?
                                    https://www.ebay.com/itm/T520D477M00...m/193458822505
                                    • piernov
                                      • Jan 2016
                                      • 4437
                                      • France
                                      #958
                                      Take 4x 330uF aluminum SMD capacitors from CPU VCore section of a laptop donor board.
                                      NEC Tokin ESR is 1 to 2 ohms. ESR of replacement cap should preferably be close to 6 ohms so 4x in parallel means 1.5 ohm total ESR.
                                      • Aurumnus
                                        • Sep 2020
                                        • 6
                                        • Greece
                                        #959
                                        I don't have available a laptop donor board.
                                        I have to buy new capacitors from Ebay.
                                        This result comes from division 6/4=1.5?
                                          Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 06:10 AM
                                          Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 05:40 AM
                                          09-06-2024, 05:27 AM
                                          Toshiba Satellite Pro Satellite Pro R50-EC-11J Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro Satellite Pro R50-EC-11J Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-EC-11J boardview and Satellite Pro R50-EC-11J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-06-2024, 08:10 PM
