Toshiba Satellite - Locks up when plugged in
  • dupetank
    • Jan 2014
    • 7
    • usa
    #681
    Re: Toshiba Satellite - Locks up when plugged in
    Ok so after cleaning up the solder. With some help from my cousin I finally managed to re-solder the caps on.
    After the process the laptop turns on with the ac adapter plugged in, but the display does not turn on. A light on the laptop tells that the laptop is on and I also confirmed it by hearing the fan spin.
    I will post the pictures.
    The first picture are all the lights.
    The second picture is the VGA that I used to plug into an external moniter to see if it would work. It did not.
    The third picture is the iron I used.
    The fourth picture is the re-soldered caps.
    So. What went wrong? Any feed back would help.
    • lezsimply
      The Wanderer
      • 645
      • Philippines
      #682
      outer strips are positive terminals, one solder overlapped the other. You should redo it first. The one with huge led ball.
      • spleenharvester
        • Mar 2010
        • 882
        Looks like two resistors missing at the top left of pic#4? Is this a GM945 board?
        Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
        • dupetank
          • Jan 2014
          • 7
          • usa
          #684
          Ok thanks. I'll try to get that redone.
          As far as I know there were never any resistors in the nec/tokin area.
          • spleenharvester
            • Mar 2010
            • 882
            Take a multimeter and test the resistance between the positive and negative strips. If it reads only a few ohms, you have shorted somewhere.
            Also, the bottom blob of solder on the negative terminals covers part of the positive side of the PCB. There shouldn't be any conductive material in that area but if the surface has been scratched, eg by the soldering iron, that may also cause a short.
            What capacitors did you use?
            • Dimitrios
              • Nov 2013
              • 127
              • Greece
              #686
              Hello, I have a L300 but with no leds and no power. Fuses are ok. You think it is the NEC/TOKIN cap under proccessor or maybe something else??
              • spleenharvester
                • Mar 2010
                • 882
                Doubtful, though it may be worth checking the + and - terminals of the Tokin to see if it's shorted out.
                But chances are you have a fault on DCIN/DCBATOUT.
                If you can't find the fault, it may be easier to just buy another, non-POSTing board off ebay and replace the Tokin cap.
                • dj_ricoh
                  • 2073
                  • uk
                  #688
                  i saw one like yours! bios
                  • Dimitrios
                    • Nov 2013
                    • 127
                    • Greece
                    #689
                    Yeah you are right. Capacitor is not shorted...
                    Will check voltage on bios chip as well as always voltages!
                    Thanks guys!
                    • Dimitrios
                      • Nov 2013
                      • 127
                      • Greece
                      #690
                      BIOS chip has no voltage with adpter on. I think there should be an always 3.3V ther, correct? Also power button has no voltage.
                      • atsio
                        • Oct 2013
                        • 819
                        • Greece
                        #691
                        Yes. You should check your charger and 5v & 3.3v regulator.
                        • Dimitrios
                          • Nov 2013
                          • 127
                          • Greece
                          #692
                          I have VREG3 and VREG5, 3.3V and 5V correct. But I don't have +3VLA, only +5VLA. Is +3VLA an always voltage? Maybe I will start a new thread!
                          • atsio
                            • Oct 2013
                            • 819
                            • Greece
                            #693
                            Which version of the l300 do you have? Give board model.
                            • Dimitrios
                              • Nov 2013
                              • 127
                              • Greece
                              #694
                              I have a 6050A2264901-MB-A02 motherboard.
                              • atsio
                                • Oct 2013
                                • 819
                                • Greece
                                #695
                                Give voltage on all pins of U511
                                • Kkarlov
                                  • Jan 2014
                                  • Portugal
                                  #696
                                  Originally posted by Kkarlov
                                  First of all I'll thank all for all the info that I found here.
                                  I have a A300-276 with the NEC Tokin 0E907 (PFAF250E907MCBTE) with the same problem of not booting with AC Adapter.
                                  I searched the info about the NEC 0E907 and found in NEC datasheet this specs:
                                  Rated Voltage: 2,5V / Capacitance: 900uF / DC Leakage Current: 250 u A / ESR (m Ω) at 100kHz : 1.5
                                  Now my doubt is what is the best combination of Capacitors?
                                  Are Tantalum Capacitators better than Aluminum Capacitators?
                                  If the actual uF is 900 is it best to maintain at the 900 or should I go higher to 1200?
                                  The ESR on NEC datasheet says 1.5 - is this 1,5 ( one and a half) mOhm ? I find only with 6 mOhm...
                                  I'm planning in remove the T3400 CPU and putting a T8300 that heats a bit more and consumes a bit more too.
                                  Sorry for all the questions but I don't know much about electronic and to repair the A300 would take me about 130 Dollars with shippings - I'll try do it myself.
                                  Regards to everyone.
                                  I saw one report that the 900uF cap actually measured in at 1200 and the 1200uF cap measured in at 1500uF. But that was only one report, meter could have been uncalibrated or similar.
                                  For 0E907 I used 3x330uF on several boards and all still work perfectly. Probably wouldn't hurt to go 4x330uF though.
                                  Also, you need to take into account that ESR is calculated using the parallel resistance equation (1/Rtotal) = (1/R1) + (1/R2) + (1/R3) etc etc. If four caps are used with an ESR of 6mOhm the total ESR is 1.5mOhm.
                                  Just came to thanks for the help of spleenharvester and give feedback on the repair after a few moths.
                                  I did as sugested and went for the 4x300uf thinking on the CPU upgrade.
                                  In the first month I kept using it with the original CPU and everything went fine, not a problem or loss of functionality (suspend/hibernate either).
                                  I did the upgrade from the T3400 to T8300 about a month later and not a problem either untill now. With the T8300 runs way better and faster, it also runs much cooler then it did with the T3400:
                                  Laptop is used every day and never less than 1 hour.
                                  Thanks to everyone.
                                  • oxlahun
                                    • Mar 2014
                                    • Mexico
                                    #697
                                    Repaired Toshiba L305 with success . NEC / TOKIN 0E907.
                                    Capacitors are 330. Extracted from a damaged motherboard HP-DV6000.
                                    Here I share pictures of the steps performed:
                                    • oxlahun
                                      • Mar 2014
                                      • Mexico
                                      #698
                                      This step must be done very carefully, I drew a line with the tip of the screwdriver to weaken the metal foil and then I could break and lift. I used a common 30W soldering iron.
                                      • lezsimply
                                        The Wanderer
                                        • 645
                                        • Philippines
                                        #699
                                        hey oxlahun, are those caps 330 d? can't see much from the image. its a 330uf 2v caps right?
                                        • jeremykum
                                          • Feb 2012
                                          • 95
                                          • Malaysia
                                          #700
                                          Originally posted by Napalm
                                          Could I try them anyway? will it do any harm?
                                          Most black tantalums on laptop boards are from low esr type. But best if you can measure the capacitance if you intend to try from scrap board.
                                          Just a note, recently i had purchased 500pcs 330uf low esr, when i receive my goods i measure the capacitance its only 240+uf although its mark 330. Many types of lousy sellers out there just be careful. Lucky i get a refund when i snap a photo of the reading measure with atlas esr meter. Initially the seller denied.
                                          Mainly repair laptops, sometimes LCD/LED monitors. Also accepts changing/reballing/reflow BGA job request.
                                            Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 06:10 AM
                                            Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-06-2024, 05:40 AM
                                            09-06-2024, 05:27 AM
                                            Toshiba Satellite Pro Satellite Pro R50-EC-12X Notebook Specification for Upgrade or Repair
                                            This specification for the Toshiba Satellite Pro Satellite Pro R50-EC-12X Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-EC-12X boardview and Satellite Pro R50-EC-12X schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-06-2024, 08:10 PM
