Dell Latitude e6530 laptop camera module
  • ut-norm
    • Nov 2019
    • 70
    • italia
    Hello you all do you know how to adapt this DELL LATITUDE e 6530 camera module to a usb connector?
    Do you have any schematics?
    Thanks for the reply
    Hello everybody
  • ut-norm
    • Nov 2019
    • 70
    • italia
    Re: laptop camera module
    I apologize I forgot to specify the form code: 11P2SF117
    • tobbyhush
      • Apr 2017
      • 13
      • Catalonia
      You can not connect that camera directly to USB, or you'll fry it rather quickly. It needs 3.3V to operate correctly, as it says on the silkscreen itself.
      If you don't want to get a voltage regulator, to minimize complexity I would recommend you use two diodes and a 100ish ohm resistor in series. But do never take this as a permanent fix for a permanent project.
      Hope you have the original loom that plugged into the motherboard. That way you can easily get the pinout from the following part of the schematic:
      • ut-norm
        • Nov 2019
        • 70
        • italia
        Thank you for your reply. I have already found this schematic (dell latitude and 6530). The module must be powered at 3.3 volts, I have the regulator, unfortunately I cannot find the positive pin.
        The original connector of the module has 8 pins the last one is nc. It is not possible to tell from the colors. This is the photo of the connector.
        • tobbyhush
          • Apr 2017
          • 13
          • Catalonia
          Note that you are enumerating that connector backwards in respect to the schematic. The twisted pair should be D+ and D- (2 and 3) but you've got them labeled as 6 and 7. It will make a lot more sense if you flip that around.
          CAMERA_VDD (Pin 4) is the 3.3V.
          Ignore G1 and G2 on the schematic, they're just the anchors for the connector
          Hope that helps
          • ut-norm
            • Nov 2019
            • 70
            • italia
            I made the connections as you suggested and everything works fine. On the schematic is pin 1 the microphone output?
            The module appears to have two microphone capsules ...
            Thanks anyway for everything tobbyhush.
            • tobbyhush
              • Apr 2017
              • 13
              • Catalonia
              From what I can gather from the schematic:
              CAM_MIC_CBL_DET# is directly connected to 3.3V through a 10Kohm 5% resistor.
              DMIC_CLK is the clock signal generated by the audio CODEC (92HD93)
              DMIC0 is the microphone output (for both).
              It is extremely unclear whether these microphones are analog, digital, or both. The output is supposed to be analog audio, but the clock selects either one mic or the other (during rising and falling edge).
              Try leaving DMIC_CLK floating and see if something comes through. If there's nothing, hook it up to either GND or 3.3V. The issue would be if it only sends for some microseconds if there's not a clock present, but I doubt that to be the case. If it was, you'd need to provide that signal yourself.
              But don't expect that audio on the USB! The output signal on DMIC0 should be analog, not digital (despite the letter D), so you'd need to hook it up to your microphone input or a preamp.
              • kamkooltech
                kamkooltech
                • Jun 2019
                • 117
                • nigeria
                Best site where to buy universal construction camera and cable for laptops.
                • mon2
                  • Dec 2019
                  • 14603
                  AliExpress.
                  • kamkooltech
                    kamkooltech
                    • Jun 2019
                    • 117
                    • nigeria
                    I search for it, is not available, that is why I drop help message, if you got link help me out.
                    Look the picture, same as that item
                    • mon2
                      • Dec 2019
                      • 14603
                      Post more details of this module.
                      Which laptop? Which model?
                      • Stevedb
                        Stevedb
                        • Feb 2018
                        • 624
                        • Belgium
                        Hi you can find it on ebay or aliexpress
                        https://www.ebay.de/itm/172833715931
                        • mon2
                          • Dec 2019
                          • 14603
                          Nice find @Stevedb!! Thanks 👍
                          • kamkooltech
                            kamkooltech
                            • Jun 2019
                            • 117
                            • nigeria
                            Thank you
                            • diamon
                              Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                              by diamon
                              I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                              Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                              Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                              Pictures of these boards:
                              Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                              Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                              Dell...
                              02-28-2024, 12:51 PM
                            • m1ch43lzm
                              70mai Dash Cam A510 - help identifying connector on camera module
                              by m1ch43lzm
                              Hi everyone
                              I have a 70mai Dash Cam A510 which failed after about 3 months of being installed in my car, likely due to heat, i got it from aliexpress so no point in trying to return it for warranty (and shipping it back would cost me almost the same as a new one from ali)
                              The camera would boot loop showing 70mai logo on the screen, sometimes it would boot fine then the live view would freeze or display purple lines
                              I already took it apart, and found out that the camera boots fine if i unplug the camera module from the main PCB, sometimes "playing" with the connector...
                              05-11-2025, 06:02 PM
                            • Amber TC
                              [NOT A RESCUE BIOS] Dell Latitude E6530 Rare Factory BIOS (Revision A86)
                              by Amber TC
                              ⚠️ Not a Rescue BIOS. Flash at Your Own Risk. ⚠️
                              This is not A17.
                              This is not listed on Dell's support site.
                              This is an unreleased internal firmware revision recovered from a university loaner Latitude E6530... and it possibly bricked the system it came from.
                              It is from the 8 MB Winbond W25Q64 chip. Could be nothing burger but given the anomalies this is a very interesting firmware dump.
                              Firmware collectors and reverse engineers might find this useful, It contains certs, modules, and DXE drivers not present in A17. This is likely...
                              04-17-2025, 03:54 PM
                            • YOUCEF4787
                              Dell Latitude 5490 (LA-F401P) - Boots from USB-C only, not from DC Jack after BIOS flash
                              by YOUCEF4787
                              I'm working on a Dell Latitude 5490 with a LA-F401P motherboard that has a very peculiar issue, and I would appreciate your insights.
                              Initial Problem:
                              The laptop was completely dead, no signs of life, no power LED.
                              Action Taken:
                              I flashed the main BIOS chip with a clean dump. This brought the machine back to life, but with a strange limitation.
                              Current Situation & The Main Issue:
                              The laptop now works perfectly when powered through the USB-C port. It charges the battery, powers on, boots into the OS, and functions 100% correctly....
                              09-21-2025, 12:19 PM
                              DELL Latitude 5540 Notebook 5000 Specification for Upgrade or Repair
                              This specification for the DELL Latitude 5540 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5540 boardview and 5540 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5540...
                              09-07-2024, 07:19 AM
