A1708 intermittent backlight (no flexgate issue)
  • JenneDezaeger
    • Feb 2021
    • 18
    • Belgium
    I have a 1708 with a 820-00840-A board.
    Sometimes I have backlight, I say sometimes because i haven't figured out the pattern when it works and when it doesn't. It doesn't seem to respond to temperature changes (hot or cold).
    I do notice when it works and I unplug it and try again it doesn't work anymore, if I leave it for a while sometimes it starts again.
    The reason that there's no backlight is because my BKLT_EN_R is 0V (except when it works off course, than its 3.3V).
    I've tried and measured everything I could think off. Does anyone have an idea why my BKLT_EN_R is 0V most of the time except sometimes it isn't
    Thanks in advance
  • MobileXT
    • Oct 2012
    • 214
    Re: A1708 intermittent backlight (no flexgate issue)
    This is under apple recall https://support.apple.com/13-inch-ma...klight-service
      • 21845
      Originally posted by MobileXT
      That only for 2016 models,the 820-00840-A is a mid 2017 board as far as i know .
      • JenneDezaeger
        • Feb 2021
        • 18
        • Belgium
        It's indeed a mid 2017
        • JenneDezaeger
          • Feb 2021
          • 18
          • Belgium
          Could it be that although the screen flex looks OK, that my BKLT_EN_R is missing because of bad communication between the screen and the board? I haven't got another screen to test with for the moment but maybe I should try that.
          An external screen isn't possible without a working internal display as far as I know, so it's hard to tell what is happening, but I've seen it boot into the login screen on 1 occasion.
          • mon2
            • 14659
            2017 are also impacted by Flexgate. Just read the many postings on ifixit website. We did a full display assembly replacement to resolve this issue.
            However this unit would always turn on while almost full closure of the unit. Would blank out while opening at 90 degrees.
            Your case may be different as the enable pin is low on your unit.
            Could your lid sensor be a factor?
            • JenneDezaeger
              • Feb 2021
              • 18
              • Belgium
              I've measured the lid sensor and it seems fine.
              • mon2
                • 14659
                When the backlight is OFF, are you able to see the screen contents with an external flashlight on the front / edges of the display?
                If yes, the display is working so backlight needs the review.
                An external monitor should be possible to test. I do not believe the internal screen will prevent this test.
                Trace back the backlight enable signal lines for a possible break.
                • piernov
                  • Jan 2016
                  • 4439
                  • France
                  There are 2 lid sensors with 2 different signals and a 3rd combined signal.
                  • JenneDezaeger
                    • Feb 2021
                    • 18
                    • Belgium
                    I've ordered a new screen just to rule it out.
                    • JenneDezaeger
                      • Feb 2021
                      • 18
                      • Belgium
                      OK, so I replaced the screen and have the same problem.
                      It starts and draws around 0.580A @ 20V and I can turn it off by holding the power button.
                      But still no backlight!
                      If I connect an external monitor nothing show either and I can't seem to see the logo at startup, so it could be no image.
                      • JenneDezaeger
                        • Feb 2021
                        • 18
                        • Belgium
                        Apparently when I leave the board for 15-20 min without battery and without power and I then plug it in it starts, if I then disconnect the USB-C and reconnect it doesn't start.
                        When it works it draws around 450mA, when it doesn't it jumps to 580mA. Sometimes when it starts it stops working and also jumps to 580mA.
                        • mon2
                          • 14659
                          When it starts, do you hear the chime? Does the backlight work?
                          Have you checked for possible bad caps on the logic board? Place the meter in resistance mode, remove the power adapter and the battery to the logic board, then check the resistance on each cap (black on ground; red on the + of the cap under test) - record each resistance.
                          Some of the CPU core caps will be low resistance but proceed as noted.
                          Perhaps the power rail is shutting down due to 'excessive current draw' due to a shorted or almost shorted cap. This is common to see.
                          • JenneDezaeger
                            • Feb 2021
                            • 18
                            • Belgium
                            The speakers are not connected so i suppose the chime is playing if I get the logo, but that is only after I leave the board for a while, and as I said, if it starts it blacks out after a couple of minutes and then it doesn't do anything. I see the current go up to 580mA and I can shut it down with the powerbutton, but no backlight but also no image.
                            But when it works, everything works also the backlight.
                            Any pointers on which caps to start with, because otherwise I would be busy for quite a while.
                            • JenneDezaeger
                              • Feb 2021
                              • 18
                              • Belgium
                              If I measure on the "big" caps like C1163 you said they would be low resistance, but I get 2.4Ohms. Is that normal?
                              • JenneDezaeger
                                • Feb 2021
                                • 18
                                • Belgium
                                OK so I discovered if i spray the CPU heatsink with freeze spray it turns on.
                                But sometimes with artifacts on the screen.
                                • JenneDezaeger
                                  • Feb 2021
                                  • 18
                                  • Belgium
                                  I reflowed every power IC en it works
                                  • mon2
                                    • 14659
                                    Well done!!
                                    • ktmmotocross
                                      Boardkiller
                                      • Feb 2014
                                      • 3627
                                      • slovakia
                                      wish to know what ic to rework. i dont want to touch every ic
                                      • bajdik
                                        Intermittent Power Issue on Asus X553MA – CPU Voltage Drops ftom 0.89V to 0V
                                        by bajdik
                                        I have a problem with an Asus X553MA motherboard. Sometimes the system works fine, but other times the CPU voltage drops to 0V. In most cases, the laptop reboots after a few seconds due to the voltage drop.
                                        Occasionally, it shows the ASUS logo or boots into the BIOS. Sometimes it can stay in the BIOS for hours without issue.
                                        I checked the board with a thermal camera, but I couldn't find any overheating or leaking capacitors.
                                        Unfortunately, I don’t have access to the schematic.
                                        It seems to me that when I bend the board, something changes.
                                        Could this...
                                        08-13-2025, 07:26 AM
                                      • Stephen
                                        MacBook Pro 13" 2017 A1708 Black screen issue (not flexgate)
                                        by Stephen
                                        This is not a flexgate issue.
                                        The lcd turns on and functions fully and fine. When installing or even attempting to install an OS the screen goes black and doesn't turn on. We swapped the LCD with a testing LCD (that works) and it too is also black. After the computer cools down it turns back on and show the screen again and then it goes black when it gets hot. Sounds like a CPU issue to me (since these do not have their own dedicated GPU) but I may be wrong. Has anyone experienced this with this model? Battery is good btw. also I disconnected the battery and it still does the...
                                        06-10-2021, 09:09 AM
                                      • fixme2024
                                        Intermittent Power Issue with HP DV6 Motherboard Occasional Failure to Turn On
                                        by fixme2024
                                        Hello everyone, I have an HP DV6 DAOLX6MB6F2 REV: F motherboard. The issue I'm facing is that sometimes the motherboard doesn't turn on. I've checked the voltages for the power on button panel, and they seem to be okay. Right now, it's working perfectly fine, so I can't pinpoint the exact problem. I have the HP DV6-DV7 Quanta LX6_7 (Liverpool) DAOLX6MB6F2 Rev 1A.pdf schematics, a multimeter, and a 5A power supply. If anyone could guide me on where to start checking first, I would greatly appreciate it. This is my first experience with this. Thank you.
                                        Here, I have attached a document...
                                        02-14-2024, 09:24 PM
                                      • Riananyaina
                                        MacBook A1708 820-00840-A backlight issue
                                        by Riananyaina
                                        Hello Everyone ,
                                        today I'm coming to you regarding my issue which is no Backlight .
                                        I have image on my screen but no light .
                                        The macbook was one that I bought few month ago that I used with an external screen . Now I started to do some analysis on the MB which my limited knowledge .
                                        First thing is that it suffered from liquid damage . The fuse was not ok when I openned it the first time . But I already changed it after testing that there is no short to ground on this line .
                                        Please find below few informations which can help for the analysis...
                                        04-24-2023, 05:03 AM
                                      • slimmy182
                                        MacBook Pro 15" 2016 820-00281 no backlight. Another flexgate issue?
                                        by slimmy182
                                        Hello, I bought this machine from a friend. It's a 15 inch MacBook Pro 2016 model, logic board 820-00281. He said that the screen would go off if open more than a certaing angle but it's perfect working whit an external display.
                                        The backlight screen remains stay off even if I open just a little the lid, so I never see backlight work, but I can confirm that LCD show images as using a torch I can see it on the screen. It seems also that camera is not rocognized as the keyboard backlight stay off and touchbar have full brightness.
                                        Is this a classic flexgate issue? I...
                                        10-19-2022, 12:44 AM
