Asus Gl553VW turn on no windows boot
+ More Options
Posts
  • Pfudaniel
    • Feb 2021
    • 91
    • Netherlands
    #41
    Re: Asus Gl553VW turn on no windows boot
    Originally posted by SMDFlea
    In future please put all bios requests in the "Bios requests ONLY!" section - https://www.badcaps.net/forum/forumdisplay.php?f=40 .That way the main laptop forum won`t turn to shit again with umpteen bios requests and dumps. Thank you
    Thank u for the headsup! Wil definatly do!
    • Pfudaniel
      • Feb 2021
      • 91
      • Netherlands
      #42
      Alright so i have another question, if u update the bios does the EC also get updated ? i notice that the EC wil stay the same version no matter wich bios update is done ( 302-304-306) and what about the Vbios ( nvidea gpu ). cud that be something to look at ?
      Link to foto in bios: https://ibb.co/GH73ppX
      Also i run memtest succesfull with 0 errors.
      Link to foto memtest: https://ibb.co/jJtmMRT
      what else can there be checked for ? can it be some component that controls the harddrive ?
      • Pfudaniel
        • Feb 2021
        • 91
        • Netherlands
        #43
        OMG guys look what i found on the back of the damn board!
        https://ibb.co/g7DYYZW
        i made a visual inspection before posting al this, thanks to boardvieuw i found it. i was measuring some back parts components and look! il replace this part right now and wil post if it fixed the problem or not!
        • Pfudaniel
          • Feb 2021
          • 91
          • Netherlands
          #44
          pfff problem is stil there..... doesnt boot into windows even after replacing...
          it is C8102 on boardview...
          • Smoxx
            • Jun 2019
            • 36
            • Argentina
            #45
            Check that capacitor nets in boardview... maybe there are other damaged components.
            • Pfudaniel
              • Feb 2021
              • 91
              • Netherlands
              #46
              wich nets ? the +ac_bat_sys or GND .
              and what shud i exactly measure ? with ac adapter in or out ?
              thanks i think were getting there !
              • Smoxx
                • Jun 2019
                • 36
                • Argentina
                #47
                +AC_BAT_SYS
                Do you replaced the cap with 10uf/25v as specified in the boardview or with a random one?
                • Pfudaniel
                  • Feb 2021
                  • 91
                  • Netherlands
                  #48
                  +AC_BAT_SYS
                  i took 1 from a spare board, the cap is same size and colour. not sure if its exactly same one tho. What do u think?
                  if u think its better to order a new one. than il order also all the mossfets, and whatever there is on that ac bat sys?
                  • Smoxx
                    • Jun 2019
                    • 36
                    • Argentina
                    #49
                    For 19v rail the cap needs to be above that voltage, otherwise it won't handle. The same applies for all other rails.
                    If you know the rails of the spare board then you could pull a capacitor out from the 19v, test with MM and then replace. Otherwise, better order a batch of that specific cap online.
                    But before start making orders, make sure you tested everything according to boardview. Double check if needed.
                    • Pfudaniel
                      • Feb 2021
                      • 91
                      • Netherlands
                      #50
                      Alright the pwm controller tps51225crukr ti qfn-20 is definatly not good, no clear reading on this, it gos up and down.
                      The capacitors show me all good voltage, also the one i replaced. Yes its from a 19v rails so shud be fine.
                      I will also order all the mosfets and uf caps and just replace them. I wil put my order Tomorrow so it shud arive before coming thursday.
                      Shud i replace the coils aswell or those dont really go bad? I know mosfets can go bad without a real sign of it.
                      Thanks again! I rlly appriciate u givin ur time to help me solve this!
                      Edit: ordered the full. +AC_BAT_SYS parts. was 58euro its worth a try! al from mouser
                      • M1ch4L
                        • 9
                        • SK
                        #51
                        I had one time a laptop with a problem like this. It was an older Asus ROG. After some days I could not find the problem and when I almost gave up I found a damaged ribbon cable between keyboard and motherboard ... the cable made a short there. Check it ... you never know ...
                        • Smoxx
                          • Jun 2019
                          • 36
                          • Argentina
                          #52
                          Ordering the full rail is kinda overkill ...as we are not sure yet of the issue, but no problems with that, as the parts can be useful for other repairs in the future.
                          5v and 3v seem ok in the board. Try cleaning the TPS51225 with IPA and ESD brush and re-do the measures.
                          Also, I don't think the board would be able to run and complete memtest from USB in a faulty 5v rail (TPS51225). But repairs can be tricky sometimes and I could be wrong.
                          You have not answered yet if you tried to boot from UBUNTU live USB. This is important because it can give us useful info.
                          No need to replace coils in this case because all voltages are present on them. The same for the polymer capacitors, especially because replacing SMD polymers can be a real pain sometimes, so if they are good just leave it as it is.
                          It's also very important to take a rest to refresh the mind, so tiredness will not get in the way or lead us to mistakes.
                          We'll keep trying to sort this out
                          • Pfudaniel
                            • Feb 2021
                            • 91
                            • Netherlands
                            #53
                            haha yeah ur totally right with this! il let it go for tonight and wait for parts to arrive, il just replace the TPS51225. but yeah probably its fine as it is. il leave the polymer capacitors and coils and change the rest
                            i havent tried ubuntu, i wil do that as soon windows dont work with the new parts. thanks !
                            • digitalpc
                              • Jun 2016
                              • 305
                              • .DLL
                              #54
                              Hi brother, I have same problem like you did you fix this?
                              • RJARRRPCGP
                                • Jul 2004
                                • 6304
                                Originally posted by Pfudaniel
                                Thanks for ur respond !
                                yes im trying it from usb, windows is installed by now ( very lucky it came that far ) but cant get into windows it wil shutdown on the loading screen
                                ive tried the m.2 from my own laptop with windows installed on it, stil same issue.
                                It's like it thinks it's too hot!
                                ASRock B550 PG Velocita
                                Ryzen 9 "Vermeer" 5900X
                                Arc A770 16 GB
                                eVGA Supernova G3 750W
                                Alienware AW3423DWF OLED
                                • Pfudaniel
                                  • Feb 2021
                                  • 91
                                  • Netherlands
                                  #56
                                  didnt manage to fixit no, to much time wasted on it
                                  • digitalpc
                                    • Jun 2016
                                    • 305
                                    • .DLL
                                    #57
                                    I quit too.
                                    • Spitz
                                      • Oct 2010
                                      • 95
                                      #58
                                      Originally posted by digitalpc
                                      I quit too.
                                      Just a thought, I had a Asus with similar problem, but the cause was it was overheating. The motherboard and the bottom case formed the duct for the cpu fan. There was a rubber seal on the board that made the connection between the motherboard and the bottom case, and if the seal was not exactly in the right spot, it would leak enough that the cpu would overheat and shut down. There was markings on the board showing where the seal was supposed to go. Have you ran a program that shows cpu temperature constantly? The cpu on mine went from 50C to 80C in about 2 seconds.
                                      • muradterzi
                                        • Aug 2017
                                        • 39
                                        • Türkiye
                                        #59
                                        I have the same problem, the problem is from the north bridge
                                        • D87
                                          • Mar 2022
                                          • 10
                                          i have the same problem but nothing visibly wrong under microscope. ive tried several operating systems but nothing works. can only go to bios
                                          • throwaway327
                                            by throwaway327
                                            Model No: RC72LA
                                            Serial No: SBNVKD001014459
                                            06-18-2025, 05:52 PM
                                          • DynaxSC
                                            ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
                                            by DynaxSC
                                            I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
                                            Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
                                            Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
                                            The behaviour is also really very strange, i.e.:
                                            • The disk shows always up in BIOS - so it is recognized, so far so good
                                            • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
                                            02-23-2025, 01:33 PM
                                          • Safio
                                            please HELP Asus ROG GL753VE turn on no windows Boot
                                            by Safio
                                            ASUS GL753VE and when i want to install windows it shuts down, in bios the laptop stays on forever without problems, I have replaced paste, also nothing seems to be heating up as far as i can see ( fan blowing warm air heat sink temperature is normal) tried different hard drives (ssd, M.2 and few others) did all the troubleshooting i could find on google (CMOS reset, battery removal and discharging the MOBO etc..) ran memtest to check the Ram and all come back good, replaced the mem ram and still same, tried live usb system also still same shut off issue, i know there is few threads out there...
                                            04-23-2021, 12:50 AM
                                          • futadmytro
                                            Asus g713qm-es94 stuck on boot bios problem
                                            by futadmytro
                                            sn^M4NRKD02753616E
                                            MB- g533-6050a3250201-MB-A03
                                            Stuck on boot after ROG logo, did not enter to bios
                                            In flash bios , laprop boot but have video issue
                                            orig bios...
                                            06-25-2025, 08:07 AM
                                          • 0xx
                                            2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
                                            by 0xx
                                            Hi folks,
                                            My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
                                            What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
                                            I assumed that Windows Update was interrupted due to closing...
                                            09-14-2025, 03:46 PM
