Asus Gl553VW turn on no windows boot
  • Smoxx
    • Jun 2019
    • 36
    • Argentina
    Re: Asus Gl553VW turn on no windows boot
    I forgot 1 step for the basic checks. Power up the laptop with the keyboard disconnected from MB (short pins 25+26 on keyboard connector to power on). I know it may sound silly but a faulty keyboard can also cause shutdown issues.
    Other than that, all voltages seem ok and as pointed out by @piernov, +VCCGT behaviour may be normal in this case and it will kick in only when demanded.
    What I would try now is to backup the ROM and flash another known good BIOS. Try flashing the original BIOS IC first and in case it doesn't work, flash BIOS to a fresh new IC.
    Make sure the BIOS IC and your programmer are compatible before proceeding.
    • Pfudaniel
      • Feb 2021
      • 91
      • Netherlands
      i tried without keyboard/mouse plugged out. No difference.
      I just used ch341a programmer and first backedup the original bios. its 8mb.
      if i download the new bios from asus website and extract with uefipatch its 6mb.
      with version 304 laptop wont boot anymore. same with version 306.
      i put back original bios and works. stil shutdown on windows loading.
      mmm thats kinda weird!?
      Edit: found a 8mb original flash. flashed it and stil same issue, shutdown on windows loading.
      i have a new winbond chip stil here wich i wil try tomorrow.
      I hounestly dont think that wud solve the problem tho
      what is there else we can look for ? do u think the cpu is broken ?
      • petehall347
        • Jan 2015
        • 4426
        you tried booting a live system yet ?or tried installing from usb ?
        • Smoxx
          • Jun 2019
          • 36
          • Argentina
          Yes. You need to flash a full BIOS image... and no, I don't think CPU is broken.
          I did some research and I found that auto shutdown is a common issue for ROG laptops due to CPU throttling.
          Do you have voltage settings in BIOS?
          • Pfudaniel
            • Feb 2021
            • 91
            • Netherlands
            Thanks for ur respond !
            yes im trying it from usb, windows is installed by now ( very lucky it came that far ) but cant get into windows it wil shutdown on the loading screen
            ive tried the m.2 from my own laptop with windows installed on it, stil same issue.
            • Pfudaniel
              • Feb 2021
              • 91
              • Netherlands
              #26
              thats good news at least! no im sorry no settings in bios for voltage.
              The bios is very basic
              • Smoxx
                • Jun 2019
                • 36
                • Argentina
                #27
                Ok. If you have a full BIOS dump I can take a look in the advanced settings.
                • Pfudaniel
                  • Feb 2021
                  • 91
                  • Netherlands
                  #28
                  awsome! here it is.
                  https://filebin.net/6kflt66ng1a45zi6
                  • petehall347
                    • Jan 2015
                    • 4426
                    #29
                    do you get a blue screen error message flash up ?
                    its just i battled with a win 7 not starting .had to change ahci to ide in bios .. its fine now .
                    • Pfudaniel
                      • Feb 2021
                      • 91
                      • Netherlands
                      #30
                      No blue screen, it just shuts down. I can hear a sound coming from speakers tho, "tok"
                      • Smoxx
                        • Jun 2019
                        • 36
                        • Argentina
                        #31
                        Originally posted by Pfudaniel
                        Ok. I'll look into it.
                        Is this BIOS text mode or it has graphical interface as the picture attached?
                        • Pfudaniel
                          • Feb 2021
                          • 91
                          • Netherlands
                          #32
                          the bios is TEXT mode, no graphical interface
                          • Smoxx
                            • Jun 2019
                            • 36
                            • Argentina
                            #33
                            Flash this one and check if there is CPU Configuration in Advanced Settings.
                            • Pfudaniel
                              • Feb 2021
                              • 91
                              • Netherlands
                              #34
                              no theres no advanced settings its the same bios just version 306
                              • Smoxx
                                • Jun 2019
                                • 36
                                • Argentina
                                #35
                                Let's try this one.
                                • Pfudaniel
                                  • Feb 2021
                                  • 91
                                  • Netherlands
                                  #36
                                  Let's try this one.
                                  thanks again i flashed this bios on it, no settings for advanced or cpu.
                                  i managed to boot into windows tho, for the first time! it seems if the laptop is off for a couple ours it can stay on a bit longer. Once in windows after 2 minutes it shutted down again. There is something with the power delivery. this is a fact.
                                  the question is what cud it be? il be looking in boardview in a moment to see what al delivers/controls the power. i think the problem lays there. super i/o? power management control chips ? thanks!
                                  • Pfudaniel
                                    • Feb 2021
                                    • 91
                                    • Netherlands
                                    #37
                                    its only u3101 (EMBEDDED CONTR IT8176FN-56A/BX
                                    PEGA/0638-0077000 ITE QFN-48 ) and u3001 (C.S IT8587E/FX LQFP128
                                    ITE EMBEDDED CONTROLLER ) i gues ?
                                    i wil let the caps drain from the vccgt rail. i think if their empty 0.0v and i startup the computer boots further. once their loaded the computer shuts down on loading screen from windows. il post in a bit to make sure this is the case or not.
                                    EDIT: ah makes no difference
                                    • Smoxx
                                      • Jun 2019
                                      • 36
                                      • Argentina
                                      #38
                                      If you are able to boot OS then you can try undervolt CPU via software to check if it's related to CPU throttling.
                                      Here's a guide:
                                      https://linustechtips.com/topic/1085...e-intelnvidia/
                                      • Pfudaniel
                                        • Feb 2021
                                        • 91
                                        • Netherlands
                                        #39
                                        Here's a guide:
                                        Yeah it was just a 1 time thing, for a very short period of time. cant get in windows anymore. Stil shutdown on loading..
                                          • 20855
                                          Let's try this one.
                                          In future please put all bios requests in the "Bios requests ONLY!" section - https://www.badcaps.net/forum/forumdisplay.php?f=40 .That way the main laptop forum won`t turn to shit again with umpteen bios requests and dumps. Thank you
                                          • throwaway327
                                            by throwaway327
                                            Model No: RC72LA
                                            Serial No: SBNVKD001014459
                                            06-18-2025, 05:52 PM
                                          • DynaxSC
                                            ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
                                            by DynaxSC
                                            I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
                                            Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
                                            Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
                                            The behaviour is also really very strange, i.e.:
                                            • The disk shows always up in BIOS - so it is recognized, so far so good
                                            • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
                                            02-23-2025, 01:33 PM
                                          • Safio
                                            please HELP Asus ROG GL753VE turn on no windows Boot
                                            by Safio
                                            ASUS GL753VE and when i want to install windows it shuts down, in bios the laptop stays on forever without problems, I have replaced paste, also nothing seems to be heating up as far as i can see ( fan blowing warm air heat sink temperature is normal) tried different hard drives (ssd, M.2 and few others) did all the troubleshooting i could find on google (CMOS reset, battery removal and discharging the MOBO etc..) ran memtest to check the Ram and all come back good, replaced the mem ram and still same, tried live usb system also still same shut off issue, i know there is few threads out there...
                                            04-23-2021, 12:50 AM
                                          • futadmytro
                                            Asus g713qm-es94 stuck on boot bios problem
                                            by futadmytro
                                            sn^M4NRKD02753616E
                                            MB- g533-6050a3250201-MB-A03
                                            Stuck on boot after ROG logo, did not enter to bios
                                            In flash bios , laprop boot but have video issue
                                            orig bios...
                                            06-25-2025, 08:07 AM
                                          • mr.malcom
                                            HP 17-cd0606ng no Windows or Linux Boot, exept idle=poll Boot-Parameter
                                            by mr.malcom
                                            this is a very strange Problem:
                                            Notebook hang instantly on Boot. BIOS is accesable.
                                            Windows: instant after showing "loading circle", even Windows Boot Stick hang instant (even without installed SSD/NVME )
                                            Linux: instantly (if Linux Boot in leagacy Mode with log messages: Machine Check exception after 0.25 sec)
                                            i have tried:
                                            - only one RAM Stick, another working RAM, both RAM channel
                                            - BIOS Flash to newest Version F.50, BIOS Reset
                                            - Memtest86 hang instant at Test 2
                                            - HP UEFI Diagnostic wont find...
                                            02-26-2022, 05:19 AM
