please HELP Asus ROG GL753VE turn on no windows Boot
  • Safio
    • Jun 2017
    • 46
    ASUS GL753VE and when i want to install windows it shuts down, in bios the laptop stays on forever without problems, I have replaced paste, also nothing seems to be heating up as far as i can see ( fan blowing warm air heat sink temperature is normal) tried different hard drives (ssd, M.2 and few others) did all the troubleshooting i could find on google (CMOS reset, battery removal and discharging the MOBO etc..) ran memtest to check the Ram and all come back good, replaced the mem ram and still same, tried live usb system also still same shut off issue, i know there is few threads out there about CPU Vcore issue but i dont really know where to start with that, please help me to get this fixed its my only laptop and i cannot afford new laptop as im still a student and trying to get by. let me know if there is any further information to provide here
    thank you
  • Safio
    • Jun 2017
    • 46
    Re: please HELP Asus ROG GL753VE turn on no windows Boot
    anyone can help me please
    • Sephir0th
      • Oct 2020
      • 1289
      Tried to Install in minimal configuration while the Motherboard is pulled Out of the Case?
      Exclude everything Else which is connected to the Motherboard, even the Power-button If possible (you can short the Pins e.g. With tweezers),before suspecting the Board itself. Put external Keyboard and also external Display and try again.
      Of course try another USB drive and make Sure you're working With known good Adapter of correct wattage and also known good RAM.
      FairRepair on YouTube
      • Safio
        • Jun 2017
        • 46
        the wattage is correct i checked that also i did RAM test and its good , but i will try the above troubleshooting and let you know soon
        • petehall347
          • Jan 2015
          • 4442
          • United Kingdom
          did you do the long ram test ?
          • petehall347
            • Jan 2015
            • 4442
            • United Kingdom
            any errors or blue screen /?
            • Safio
              • Jun 2017
              • 46
              yes i did the long RAM test and was good no errors at all, however i have some updates here, so i though it was BIOS related issue but a friend recommended to reflash the bios with clean dump or reflow the cpu as he was thinking it was data related issue and CPU as well, so i started with CPU reflow , and surprisingly it worked so now i can install system and run the computer normally also i did a stress test , benchmark test, 4k video for 3 hours , and other tests and the laptop never did the same issue again so im not sure if it will last or is it a temporary fix, and by the way my friend has same issue before with different laptop and he did the exact same and it did fix the issue for him and now his laptop is running fine for over a year with no issue just wanted to share this with you guys, hopefully this is a good fix for this problem as its really annoying, and i really do appreciate your help thank you again
              • Safio
                • Jun 2017
                • 46
                update,
                after reflowing the cpu, it worked great not having same issue anymore however now when i installed a game on it the laptop run the game for 10 to 15mn than shut down so im not sure what you guys would suggest regarding this specific issue, your help would be really appreciated
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3628
                  • slovakia
                  how u do that reflow?
                  • DarkMooon
                    • Apr 2021
                    • 11
                    • UA
                    The thermal pads were accidentally removed from the GPU power supply?
                    • Safio
                      • Jun 2017
                      • 46
                      I got good heat gun, 40sec on 400c hands moving circles, used a good flux as well
                      • Safio
                        • Jun 2017
                        • 46
                        No not at all i check them everytime i take the heat sink and they are correctly in place
                        • Safio
                          • Jun 2017
                          • 46
                          Is there something to do with cpu power circuit, is there anyone had this issue before and resolved, some People said it can be a capacitor in that circuit who fail to provide the correct Voltage in turbo mode or to the cpu in general, anyone can confirm and if possible where to start testing ?? Thank you
                          • throwaway327
                            by throwaway327
                            Model No: RC72LA
                            Serial No: SBNVKD001014459
                            06-18-2025, 05:52 PM
                          • Stanley1843
                            Windows 11 disk no boot
                            by Stanley1843
                            I tried to install Linux on a secondary disk in my PC and after a failed Linux grub installation my PC didn't boot in Windows 11. I saw the message (Reboot and select a proper Boot device).
                            I made a bootable USB windows 11 and I run the below commands on the cmd but with no succeed.
                            DISM /Online /Cleanup-image /Restorehealth
                            The DISM.... command shows me the error 87.
                            sfc /scannow
                            chkdsk
                            bootrec /FixBoot
                            bootrec /ScanOs
                            bootrec /RebuildBcd
                            For some reason it writes(Total identified installations 0) like there no...
                            10-18-2025, 04:41 AM
                          • DynaxSC
                            ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
                            by DynaxSC
                            I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
                            Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
                            Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
                            The behaviour is also really very strange, i.e.:
                            • The disk shows always up in BIOS - so it is recognized, so far so good
                            • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
                            02-23-2025, 01:33 PM
                          • Pfudaniel
                            Asus Gl553VW turn on no windows boot
                            by Pfudaniel
                            Hello people!
                            Ive got this asus gl553VW and when i wanne install windows it shuts down, in bios the laptop stays on forever without problems.
                            Ive replaced the fan/repasted and measured lots of things but everything seems normal, also nothing seems to be heating up as far as i know.
                            I made a video to show u guys what it does, hope someone can put me into the right direction of whats broken and where to look for. Its not a heat issue i excluded that for sure
                            Thanks for taking ur time!
                            https://www.youtube.com/watch?v=40_NFBIG3_o&ab_c...
                            02-16-2021, 02:01 AM
                          • futadmytro
                            Asus g713qm-es94 stuck on boot bios problem
                            by futadmytro
                            sn^M4NRKD02753616E
                            MB- g533-6050a3250201-MB-A03
                            Stuck on boot after ROG logo, did not enter to bios
                            In flash bios , laprop boot but have video issue
                            orig bios...
                            06-25-2025, 08:07 AM
