Re: MacBook Pro 15" 2017 A1707 Touchbar No power
No worries. We are on similar paths. Have a painful A1706 that needs more love and trying to avoid it. Doing so without a microscope till the CNY.
Do post your DIODE readings as they may assist us in debugging this logic board.
The board never goes to 20V. It just gets to 5.20v then cycles off and repeats. I have replaced two CD32 chips, I guess I need to replace the other two as well. I have stenciled the other two and they came out great, Ill just replace those other two and reball them and put them back on the board and see what happens.
lol it just sucks because these CD32 are a bitch since there is 4 of them you have to do lol. Also I will look into buying that stuff as well. Ill keep you posted. This is just a board laying around. We threw it in our Crest Ultrasonic cleaner and it cleaned up very well, and still having issues so now we know its def in this area for sure. So far visually under the scope there are no lifted pads (THANK GOD). This may be a 2TB board with the max GPU upgrade and we really want to get this working because this is a very pricey board we want repaired. Other boards are pretty easy, but once we get to this level it starts getting down to problem solving again, ALSO thanks for your help mon2Last edited by Stephen; 02-11-2021, 01:31 PM.Leave a comment:
Which CD32xx USB controllers have been replaced?
When you attach a suitable power adapter, does the voltage ever negotiate to 20V?
Are you confident of your CD3215 replacement exercise?
From my (limited) knowledge, each CD3215 controller is required to be operational and has to ping back to the SMC controller over the I2C bus (SDA / SCL lines).
That is, the SMC controller will systematically communicate with each local controller over the I2C bus using their unique address and the respective controller is required to ping back a valid response.
Perhaps this communication is broken with one of more of the CD3215 controller. Or it is possible that the communication is ok and then the power negotiation is escalated to 20V and the unit powers down due to an excessive current draw and starts this looping cycle.
Have not personally attempted it but any chance you have a low cost USB based logic analyzer? They are < $20 USD on Amazon and < $5 USD on Aliexpress.
Using such a tool, you can solder 3 wires onto the macbook and snoop on the I2C bus traffic to monitor what the SMC is sending / receiving from each I2C slave.
Here is what I am referencing:
https://www.aliexpress.com/item/4000...archweb201603_
There are many others at lower costs.
You just need to find one that is available in the USA at a fair price.
We may be going down a rabbit hole here but am a strong believer that you need to the proper tool to diagnose such rather high tech devices.
Perhaps a better suggestion is to first check the wikipedia link:
https://logi.wiki/index.php/CD3215_Bootup_Sequence
and confirm the diode readings for the D+ / D- lines for each CD3215 port.
1) Place your multimeter in DIODE mode.
2) Turn OFF all power to this logic board.
3) RED (yes RED) meter lead to GROUND.
4) BLACK (yes BLACK) meter lead to the D+ line to a CD3215 port.
What is the reading?
5) BLACK (yes BLACK) meter lead to the D- line to a CD3215 port.
Repeat the above steps (4 & 5) for each USB Type C port.
What are the readings for each probing?
If the readings are off then that local CD3215 controller may need to be replaced.
Please post your updates.Leave a comment:
Also if the resistor is brought back the line will fluctuate and loop.Leave a comment:
When we bring back the resistor the board starts to turn off and on on the USB C meter. It basically starts the process over looping. It stopped when the resistor was removedLeave a comment:
That is a high reading and that is fine. If you bring back the zero ohm resistor, this line starts to fluctuate or is it steady?Leave a comment:
Figures thanks
It starts at 40.00 M OHMS and drop and keeps dropping.Leave a comment:
Resistance and Diode values can only be measured with the unit powered OFF.
Kill the power and black probe to ground; RED probe onto pin 2 of this resistor pad that has been removed.
Wish to check the resistance along this rail to see if it is too low. Often too low of a reading implies a short circuit - either external due to corrosion or internal from some bad cap. Tantalum (black polarized ones) are usually the bad ones over time.Leave a comment:
ok don't think I am dumb here. But I have it set to Resistance. But should i have the power plugged in for this or not? Because I get two readings doing it. Sounds dumb I know.Leave a comment:
What is the reading of the value?Leave a comment:
Left the shop, will post value first thing tomorrow!Leave a comment:
Yes, as per above.
What is the resistance to ground on pin 2 of the removed zero ohm resistor?
If the value is low, then you have probably have a bad cap on this rail.
Please post the value.Leave a comment:
Try check on pin 2 R6923 for shorted.Leave a comment:
Removed the O OHM resistor. It is not power cycling anymore and I now have a 3.3v steady on PIN 1.
Also our board is
820-00281-ALeave a comment:
Hey replaced a few CD32 and still same issue, Going to check this now.Leave a comment:
Check to confirm that the LDO_BMC value for EACH of the CD3215 is @ 1v1. This voltage rail powers the BMC communication for the USB power delivery handshakes.
Do review this very nice webpage on this subject:
The TBT (thunderbolt) controller apparently is required to communicate with each of the CD3215 controllers over the I2C bus. If something is wrong with this process, this may cause your cyclic booting.
Do check for any voltages on SMBUS_SMC_4_G3H_SCL and also SMBUS_SMC_4_G3H_SDA.
Any voltages? What are the values? If no activity, then I2C bus communication is not working.Leave a comment:
Also, from here:
See the following:
Satyrcon 11.12.2020
Issue: 820-00840 wont take anything from charger, either port, or orientation.
Visible inspection resulted in marks on CC1/2 pins on both USB-C ports.
Diode mode measurement showed ~0.550V on 3 of them, one ~0.040V.
Replacing the port fixed the issue.
Conclusion: One damaged CC pin can cause the whole lot to stop functioning.Leave a comment:
by soflesHello there
I have problem with Macbook Pro 15" 2017, model 2017, MB code 820-00928.
I bought it as broken with some artefacts on the screen, first I thought that this is problem with ribbon cable but after inspectiing ribbon cable I know it is fine. I tried to reinstall macOs and then I figured out that this must be something with GPU as installation freezes at the end (when drivers are loaded). I installed Windows and was able to install every each of drivers except GPU driver, as soon as I tried to install GPU driver - black screen and restart.
...11-21-2024, 05:25 AM -
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by modtoolHi to all,
the owner of this macbook brought it to me after a fall, that hit the upper right corner of the top case.
Luckily enough, the screen and all other parts of the machine haven't been damaged, only the touch bar wasn't lighting up anymore, and the macbook began to behave strangely, because it seems to start and work fine but suddendly it shutsdown (and at the same time the fans make a high rotation for half a second, as if an animal was annoyed by something...) at random times, sometimes after 2 minutes, sometimes after 5 minutes, but never over 10 minutes, then restarts... -
by kurtspiritHello,
I have a Macbook Pro 2017 Touchbar (A1706) that suddenly shut down for no reason.
So I took it apart and started measuring.
The PP3V3_G3H seems problematic. I traced the line to component U6903 and on Pin 10, I measured 1.9V instead of 3.3V.
Unfortunately, my skills stop there and I don't understand where this type of failure can come from.
I saw on videos of repairers that the failure could come from the U7000 component which would be at the origin of the 3.3V but they have absolutely no voltage. I have a 1.9v...
What do you think ?... -
by leonemax81Hi guys I have a Macbook a1707 with motherboard 820-00281, without liquid damage that behaves strangely, with the battery connected the Macbook does not turn on and the USBC meter stops at 5v in loop, when I disconnect the battery the Macbook turns on and works fine, I have already tried to replace the battery twice without success, as soon as I connect the black cable of the battery the Macbook does not turn on, it stops at 5v and in loop.
- Loading...
