HDD not detected on BATTERY only Mode
  • IamPritesh
    • Aug 2017
    • 356
    • India
    So I have this motherboard (Model : 6050a2398701-mb-a02 ) which runs fine on AC only as well as AC+Battery Mode but it with battery only it behaves very strange.
    Symptoms on BATTERY ONLY mode :
    (1) HDD is not detected
    (2) Sometime there is no display
    (3) Some kind of "hissing" sound is heard from speaker. If i plug in the adapter , the sound is gone immediately.
    Pls advise
  • stingerchamp
    • Sep 2020
    • 425
    • Pakistan
    Re: HDD not detected on BATTERY only Mode
    Check by replacing battery
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • mkdj
      by mkdj
      Mark and model: ASUS X571
      Tests already made:
      - I have removed...
      Yesterday, 09:16 AM
    • techfreak9356
      Vostro 3400 (LA-K033P) won't charge battery, everything else ok
      by techfreak9356
      09-14-2023, 11:10 PM
    • huzo
      HP ELITE X2 1013 G3 weird battery issue
      by huzo
      Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
      01-31-2025, 12:09 AM
    • trepachka
      iPad Air A1475 Boot loops after replacing battery
      by trepachka
      This iPad was working fine except the battery was not holding charge for more than 40 minutes. I replaced it with a new battery. I haven't glued the battery yet, just inserted it into the slot and held it with battery screw.
      The iPad was powered on with the new battery and I am getting white screen with Apple logo for about 10 seconds, then the screen turns dark. It then cycles like this forever.
      I know the battery is working because the iPad continues to boot loop without the charger until it depletes to 0% and the message displays I need to plug in the charger.
      11-08-2024, 03:17 PM
