Asus K56CB-XO488H not detect Nvidia GT740M
  • Gripen
    • Sep 2020
    • 37
    • Slovakia
    Hello.
    I got a faulty Asus K56CB-XO488H laptop that did not turn on. The problem was the BIOS. On this forum I got a BIOS dump which I flashed to new chip.
    The laptop is working now. There is only one problem with it. The laptop has Intel HD 4000 and Nvidia GT740m. Only the Intel HD 4000 appears in Device Manager. There is no setting in the BIOS to disable it. I also tried updating the BIOS, it didn't help. The Nvidia Chip doesn't even heat up.
    Could it have to do with having a bios dump from the forum and not the original? Or need to look for the fault elsewhere?
  • stingerchamp
    • Sep 2020
    • 425
    • Pakistan
    Re: Asus K56CB-XO488H not detect Nvidia GT740M
    Uma bios yes
    • Gripen
      • Sep 2020
      • 37
      • Slovakia
      Originally posted by stingerchamp
      Uma bios yes
      Do you know a bios dump that would be good for me to this?
      • piernov
        • Jan 2016
        • 4435
        • France
        BIOS requests go into the BIOS request section.
        • caspian
          • Oct 2015
          • 1589
          • Laptop
          https://www.badcaps.net/forum/showthread.php?t=91747
          • Gripen
            • Sep 2020
            • 37
            • Slovakia
            I had an old post about this laptop there(when not power on due to bios), I also wrote there with this problem but I didn't get an answer to the graphics problem. I also wrote here because I wasn't sure this was a BIOS problem.
            If I have the BIOS flasher here, I'll give it a try. Thank you!
            • Gripen
              • Sep 2020
              • 37
              • Slovakia
              I tried it but it still doesn't work.
              • Sametbey
                • Jan 2021
                • 229
                • Turkey
                Could there be a similar problem? Lenovo U510 LA-8972P. Despite the display screen, the video card is not seen in the device management, PU801 GPU power control RT8813A chip no + 5v at 21 pin, 2.2 ohm protection resistor open circuit. The chip was replaced and the problem was resolved. Check the VGA_GPU voltages.
                I'm not happy to be so strong. because it's not humanly
                • Gripen
                  • Sep 2020
                  • 37
                  • Slovakia
                  I'm still a beginner in these so I don't really know what to look for.
                  There is a mosfet (Nikos P1203BV) between the processor and the NVIDIA chip. I noticed that the Drain pin is 1.05V, but the Source and Gate pin are 0V. Could this be a problem?
                  • Gripen
                    • Sep 2020
                    • 37
                    • Slovakia
                    I just noticed that a capacitor and a diode(maybe) on the other side has burned.
                    • razor_amd
                      by razor_amd
                      12-15-2020, 07:07 PM
                    • grimacelord
                      by grimacelord
                      07-10-2025, 02:52 PM
                    • throwaway327
                      by throwaway327
                      Model No: RC72LA
                      Serial No: SBNVKD001014459
                      06-18-2025, 05:52 PM
                    • jbonavita
                      by jbonavita
                      Some issues
                      Things I tried
                      04-29-2025, 09:38 PM
                    • lrouw84
                      by lrouw84
                      Hi there,
                      01-28-2023, 01:31 PM
