Macbook 820-3536A Problem
  • mrtutz
    • Jun 2020
    • 12
    • United Kingdom
    Update. I'm not sure if I should start a new thread asking these questions in the laptop fault finding section of the forum, so apologies in advance if I'm asking technical questions in the wrong place.
    I carried out some further checks on the logic board and a couple of things are not making much sense to me. When I measure for a short on PP5V_S4 I get a relatively low reading, around 9 ohms. I also don't have an enable signal into U7501, which I have traced back to a missing signal from the CPU on PM_SLP_S4_L.
    I removed U7501 with my hot air station, and the resistance increased slightly to 14 ohms. I also removed L7520 and U7520 and the low resistance in the circuit seems to be on the output side of L7520.
    Am I right in assuming that 14 ohms is too low a resistance on PP5V_S4? Would a short to ground prevent PM_SLP_S4_L?
    I did inject 3v at 1amp and checked for anything warming up, the only thing was U7501.
    Can anyone give me a point in the right direction?
    Thanks in advance
    Last edited by SMDFlea; 12-30-2020, 03:24 PM. Reason: Post moved from Schematic Requests section
  • mrtutz
    • Jun 2020
    • 12
    • United Kingdom
    Re: Macbook 820-3536A Problem
    Sorry. Posted on the wrong thread before. The history of the machine:
    It came to me as a complete, spares or repair unit. No evidence of any water damage. All of the S5 rails in the laptop are present. The charger light turns green when connected, then turns orange.
    • zpi
      • Feb 2018
      • 132
      • Lithuania
      Hi, to be sure you don't have pm_slp_s4_l, you should check for spike with oscilloscope when turning on.
      But 9-14ohms are short on 5v_s4 rail. Definitely first need to fix this to expect stable s4_l.
      You said you removed L7520 and short is on output. So you should inject 1v on L7520 Pin1 (Pin one is output here) and check amperage and find hotspot on board, Thermal cam is a big helper here, even a cheap one. Because you can find even a small short with one Volt and only few degrees hotter spots. But as you have about 10 Ohm short, you should easily find it with your fingers.
      Also please explain: You said U7501 was warm and you removed it, but you still have short here ?
      • mrtutz
        • Jun 2020
        • 12
        • United Kingdom
        Hi Zpi.
        Thanks for responding. U5701 was very slightly warm, it wasn't burning my finger. Unfortunately I don't have a scope, or a thermal camera as of yet, so I will do as you suggest and spray the board with alcohol to see what gets hot that way.
        I will let you know what I find.
        • mrtutz
          • Jun 2020
          • 12
          • United Kingdom
          Update. It looks like this board has been worked on before. U6201 is missing completely from the board, DZ6606 has blown, and burnt out the tracks close by.
          Looks like this one is a parts only board now.
          Thanks for your help.
          • zpi
            • Feb 2018
            • 132
            • Lithuania
            Upload photo, maybe its still fixable.
            • mrtutz
              • Jun 2020
              • 12
              • United Kingdom
              Hi zpi.
              See attached images. They're not the best but will hopefully be OK. I ordered a replacement logic board from Aliexpress, which should arrive in 20-40 days. I would still like to attempt to repair this board if its possible.
              • zpi
                • Feb 2018
                • 132
                • Lithuania
                Board can work without this chip, its sound card, those contacts near headphones also looks like they are for headphone jack. Try to find heating elements on board when injecting voltage to l7520.
                My bet is that U6201 was removed because it had hole in it, because it is driven by 5v_s4, you should find shorted cap while injecting voltage, and board will work
                • envym
                  MacBook Pro 2018 with Activation Lock
                  by envym
                  Hi everyone!
                  I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                  I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                  06-27-2025, 08:54 AM
                • tobeend
                  Bypass mdm macbook m2 ventura
                  by tobeend
                  1. RESET MACOS WITH IPSW
                  a. Power off MacBook, press and hold the power button to enter Recovery
                  b. Open Disk Utility, remove Macintosh HD
                  c. Reboot, connect to the network to Activate Mac.
                  d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
                  d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
                  e. Release the other keys, but keep holding the Power key for another 10 seconds
                  f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
                  05-26-2023, 07:18 AM
                • SarcasticOP
                  General question about MacBook power rails for repair.
                  by SarcasticOP
                  I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                  • PPBUS_G3H (12.6V-12.8V)
                    • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                  • PP3V42_G3H (3.42V)
                    • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                  • PPVRTC_G3H (3.3V)
                    • This
                  12-12-2024, 05:50 PM
                • obelix24
                  A2941 Macbook air 15” - 5V 0a
                  by obelix24
                  I’m working on one macbook air 15” m2 that was water damaged.
                  keyboard, lcd, microphone connectors were damaged so i’ve replaced all of them and without screen connected macbook worked fine. Keyboard &trackpad and also lid sensor was working fine.
                  i’ve put macbook in shelf and order new screen so i can fully repair it.
                  Now i got the screen and macbook stays at 5v 0a.
                  i’ve tried if it’s not in DFU with another macbook but it’s not detected at all.
                  i don’t have schematics so i don’t know where to start can someone help me?...
                  03-27-2025, 01:19 PM
                • Kush679
                  MacBook Pro M1 Activate Mac
                  by Kush679
                  Sorry,I'm using my phone right now and couldn't find any search bar to search on the topic of macbooks.
                  Few weeks back(mid may),I had bought a MacBook pro m1 A2338. It belonged to my friend's younger brother who was a graphic designer,he gave me this MacBook without any icloud account linked to it and I had so much work during that times that I only used it for storage while traveling for shoots (I'm a photographer). So long story short,his brother got involved in a bad accident and was in coma and then fairly recently they pulled out his life support. I mistakenly did an erase Mac and...
                  06-20-2025, 09:43 AM
