A2941 Macbook air 15” - 5V 0a
  • obelix24
    • Jun 2023
    • 300
    • Slovakia
    I’m working on one macbook air 15” m2 that was water damaged.
    keyboard, lcd, microphone connectors were damaged so i’ve replaced all of them and without screen connected macbook worked fine. Keyboard &trackpad and also lid sensor was working fine.
    i’ve put macbook in shelf and order new screen so i can fully repair it.
    Now i got the screen and macbook stays at 5v 0a.
    i’ve tried if it’s not in DFU with another macbook but it’s not detected at all.
    i don’t have schematics so i don’t know where to start can someone help me?
  • mon2
    • 14995
    At true 0A current consumption, hunt for any onboard fuses that may be damaged from a transient event.
    • obelix24
      • Jun 2023
      • 300
      • Slovakia
      yes but i don't have boardview so it's hard to find fuses
      • obelix24
        • Jun 2023
        • 300
        • Slovakia
        I don’t know where fuses on this board are i’ve checked the white ‘fuses’ near CD32XXXXX are and they’re all good. Have someone boardview file for this macbook ?
        • mon2
          • 14995
          Post a pic of your USB C meter while measuring the current draw. The current draw is 0.00A? Or do you have a few mA of current draw?
          Again, if stuck at 0.00A then you do not have a proper connection to the logic board. Much like floating the power adapter in the air.
          • obelix24
            • Jun 2023
            • 300
            • Slovakia
            It's 0.00a i saw maybe one or two times 0.01-0.02a for approx second but i can't replicate this. I tried more times leave adapter connected, connect / reconnected. ... but still 0.00a
            • mon2
              • 14995
              Remove all power. Meter in resistance mode. Measure the resistance to ground of the fuses. Measure the resistance to ground of each inductor. At 0.00A, you have a disconnect of the power adapter to the board or a dead short on the board.
              • obelix24
                • Jun 2023
                • 300
                • Slovakia
                it looks like boardview can be used from this board : 820-03285
                I've checked fuses around CD3217 chip in diode mode and they all looks good. (0.576 both sides)
                I've checked PPBUS_AON on some caps and in diode mode i get only 0.085 this looks to me too low. If i try in resistance mode i get 85ohm on this caps. should it be so low ?
                i've it's the same then i have 9ohm on PP3V8_AON and also on some others like PP3V8_ATC01_VDDIO_REG
                • obelix24
                  • Jun 2023
                  • 300
                  • Slovakia
                  i'm really confused.
                  I tried to replace all 3 UR700, UR760 and UR730. UR760 have damaged pad on the IC.
                  But macbook is still behaving same only 5V 0.00a
                  i've checked all fuses around CD3217xxxxx chips and they're ok.
                  Also i've checked all big caps on board and they're ok.
                  I've tried multiple times with another macbook if it's not in DFU / recovery, but it's not.
                  One time but i don't know how and why when i've connected screen the screen turns on and goes over some weird test (white, green, blue, it looks like when in factory they're testing screens if there are no burned pixels or so. in that time also caps lock was responding (there was green light) and also trackpad was clicking ...
                  Any idea what should i do / check ? i've found on logi wiki that CD3217B13 are not interchangeable with CD3217B12 (i've only this one's on spare boards) but i don't know if it's still true that you can't replace CD3217B13 with other IC's and you can use only the same CD3217B13 from the exact same location on board.
                  • obelix24
                    • Jun 2023
                    • 300
                    • Slovakia
                    any idea anyone ?
                    • obelix24
                      • Jun 2023
                      • 300
                      • Slovakia
                      I’ve checked all caps arround CD3217 and they’re all good. Also i’ve checked more caps on board and i’m not able to find any short.
                      tested usb-c port with usb-c mechanics tester and both ports looks ok.
                      any idea how to proceed or what can cause the problem 5v 0a ?
                      maybe faulty cd3217b13 ic ? Have someone tried to replace this chip with cd3217b12 is it still blocked ?
                      • obelix24
                        • Jun 2023
                        • 300
                        • Slovakia
                        I’m checking more and more.
                        there is still only 5v 0a on usb-c ampmeter
                        PPBUS_AON 12.29v
                        • obelix24
                          • Jun 2023
                          • 300
                          • Slovakia
                          i noticed one very strange issue.
                          When i connect USB-C port's (there are 2 ports) and there is power to one port the other port's getting output (it turn's ampmeter even if it's only bare ampmeter connected no cable connected to ampmeter)
                          I've compared if this is normal on another macbook (a2442) and if there is connected power and bare ampmeter it's not turning it on.
                          I've checked the port's and they looks ok.
                          • mon2
                            • 14995
                            Which exact USB-C port is showing these symptoms?
                            • obelix24
                              • Jun 2023
                              • 300
                              • Slovakia
                              both ports. It's really strange as ports on these macbook are separate parts (it' not like on old macbooks where 2 ports were together)
                              • obelix24
                                • Jun 2023
                                • 300
                                • Slovakia
                                mon2 do you have any idea what can cause this ? maybe it's the reason for 5v 0a
                                • obelix24
                                  • Jun 2023
                                  • 300
                                  • Slovakia
                                  Ok i male mistake only one port is doing this strange thing
                                  i've checked and one port was little water damaged. Cleaned it and it is doing the same. I tried another usb-c port from a2442 and it's doing exactly the same
                                  • mon2
                                    • 14995
                                    You are not using the meter correctly.
                                    Insert the power adapter cable into the rear of the USB-C meter and test again.
                                    • obelix24
                                      • Jun 2023
                                      • 300
                                      • Slovakia
                                      I know that this is not how it should be used 🤣 i'm just wondering if this is normal behavior. Because i gues the ampmeter should not light up when there is no power going dorectly into it. Does it not mean that there is short somewhere ? Or this is not the problem ?
                                      • mon2
                                        • 14995
                                        This is not a problem. Just like the older usb connector, vbus from the logic board can be used to power usb devices like usb keyboards or USB mice, etc. If a power adapter is mated with the port, then the direction of vbus will reverse after the CCx pin communication and then the power adapter will send the voltage into the logic board for that port only.
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • reformatt
                                          by reformatt
                                          07-31-2025, 08:37 PM
                                        • MagJ_
                                          MacBook Air M1 A2337 Screen Replacement - keeping TrueTone
                                          by MagJ_
                                          Hello Everybody,
                                          I have a cracked screen and want to fix it. Usually, TrueTone will be gone as long as one does not prune open the screen and exchange only the LCD. However, I have seen the following Youtube video https://www.youtube.com/watch?v=MBNqhp6p_ZM, Solve MacBook M1 Pro screen true tone issue from the channel Master Liu, where only two chips called "display control chip" and "code chip" are swapped over to the new screen. I know, it is for the MacBookPro version. Though, I had the hope that it could work similarly for the MacBook Air as well.
                                          10-09-2024, 02:51 PM
                                        • sofles
                                          Macbook Pro 16" A2141 screen artefacts, kernel panic
                                          by sofles
                                          Hi there.
                                          I have Macbook Pro 16" 2019, model number A2141, motherboard number 820-01700. I have some problem with dedicated graphic card. When Macbook switches to dedicated GPU it is getting instantly hot and starts to show glitches on screen, then it freezes (trackpad is not clicking anymore) and shuts down.
                                          I tried to reinstall MacOS But it was a pain, it started to show glitches in middle of installation and I could not finish it. I only was able to reinstall MacOS when I put Macbook outside (it is winter and -2 Celcius).
                                          Now situation looks like this, If...
                                          02-05-2025, 05:05 AM
                                        • ahoonid
                                          MacBook A1990 vertical stripes on external screen
                                          by ahoonid
                                          Hey everyone,
                                          I bought a MacBook A1990 with no screen. I bought it knowing the motherboard was defective but wasn't sure what the problem was until I received it. It actually turns on but as you see from the attachment, it has vertical stripes, on an external screen!!
                                          The board is neat. Not opened before for sure. Just a little dust, nothing more.
                                          Recovery using wifi can be opened, as can also be seen in the photo but it doesn't go all the way through after connecting it to a wifi. It downloads the initial Recovery files but never completes the rest of the...
                                          06-20-2025, 08:54 AM
