Laptop battery charging circuit
This is a sticky topic.
  • fauzanmint
    replied
    Re: Laptop battery charging circuit
    Thank You
  • FaissalDZ
    replied
    Very helpful information, thanks
  • lazaro.089
    replied
    Thank you @Piernov!
    I have a question. I have 2 identical laptops (HP Pavilion Gaming Laptop 15-dk011la)
    1 does charge the other doesn't. Both batteries charge in one laptop. Both adapters are recognized in both laptops.
    But one of them refuses to charge the battery. What should I check first?. The battery is detected correctly in the laptop that doesn't charge (powercfg /batteryreport OK). It discharges just fine. But charging doesn't work.
    AnĂ½ ideas?
  • Cuboy
    replied
    Thank you for the post.
  • antunes.jrca
    replied
    Thanks for this very good topic.
  • emirich
    replied
  • fabio fanesi
    replied
    Thank you so much for the precious informations!!
  • Weelcup
    replied
    Thanks a lot
  • lappyfixer
    replied
    thank you for the detailed post piernov, exactly what ive been searching for...
  • Gomez2969
    replied
    Thanks so mush
  • piernov
    replied
    Yes indeed, some platforms only have the AC adapter connected to the DCIN/VCC pin of charger IC, and others have the DCIN/VCC pin of the charger IC connected to both battery and AC adapter (through a dual diode).
    I don't have a definitive explanation about it.
    It makes sense to have the battery connected to it if you still use some features of the charger IC like current sensing on battery only, but at the same time some platforms provide these features on battery only even though the DCIN/VCC pin is not connected to the battery. So I assume they take the power internally from the battery rail.
  • Greg81
    replied
    I have a question to the following:
    DCIN/VCC: input voltage from the AC adapter, should be close to AC adapter voltage
    Does the input voltage always come from the AC Adapter? Is the charger IC inactive when running from battery? I was trying to understand the input voltage for Quanta FH5 mainboard, there seems to be no connection to the battery rail although in every IC charger datasheet you read about input from battery and in other schematics VCC is connected to the battery input.
  • dhan
    replied
    Thank You for this informative thread
  • DavidThijs
    replied
    I have a question for a problem with the two n-channel mosfets - which I already replaced to be on the safe side. The BQ24725 emits every 1.3 seconds a very short pulse with an amplitude of approx 11v on the gates of the two N channel mosfets. When does the charge controller go in such a mode ? On battery alone, the mainboard correctly powers up. On the DC jack alone, I get nothing unless I bridge the 1st mosfet. Then the power button starts the laptop. Having both battery and a lab power supply connected to the DC jack won't start the laptop unless I bridge again the 1st mosfet. But then the current limiter of the lab psu kicks in for good reasons. Any ideas would be appreciated.
  • kalilinux25
    replied
    new ideas noted keep sharing
  • stingerchamp
    replied
    Originally posted by jessy
    Hello, good morning thanks for accepting me I have a question
    It had a board in which there was no scheme but its input mosfets were channel N, the charger source was the Bq25a, therefore the charger activated the gates to the mosfets, however, in the gates of the mosfets there was no voltage, now the charge ic was powered it had the acdet = 2.41, the acin was 0v and the regn = 0v but the capacitor that goes in that Regn line was beeping on both sides, I took the capacitor to measure outside and it was fine to feed the plate without that capacitor and in the regn terminal had no voltage, my query is, could the ic charger be bad?
    I also took out the second mosfet to measure it outside and it's ok, thanks
    If charging ic is not generating REGN and charging ic vcc is ok and acdet is normal then yes you are right otherwise check logic and signal state Active on low or high
    If you read sheet there you will find comparing circuit read it for more information
  • kadi144
    replied
    thamks
  • jessy
    replied
  • ruletero
    replied
    Thank you for the information, is very usefull.
    Now, in case of battery not detected and not short in SMBUS SDA and SCL lines, what other thing can cause the fail?
  • nassih
    replied
    very important topic tanks
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
    ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
    Highly Integrated Narrow VDC Battery Charger for Notebook Computers
    The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
    for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
    Narrow VDC applications where the system power source is
    either the battery pack or the regulated output of the charger.
    This makes the max voltage to the system equal to the max
    battery voltage instead of the max adapter voltage. Operating
    at lower system voltage can improve...
    11-05-2024, 04:43 PM
    MT3608 Step-Up Converter IC Datasheet
    The MT3608 is a constant frequency, 6-pin SOT23 current mode step-up converter intended for small, low power applications. The MT3608 switches at 1.2MHz and allows the use of tiny, low cost capacitors and inductors 2mm or less in height.
    Internal soft-start results in small inrush current and extends battery life.
    The MT3608 features automatic shifting to pulse frequency modulation mode at light loads. The MT3608 includes under-voltage lockout, current limiting, and thermal overload protection to prevent damage in the event of an output overload. The MT3608 is available...
    10-07-2024, 05:02 AM
  • alro7779
    MOSFET? Is its voltage reading normal?
    by alro7779
    Hello, guys!
    Got this 8-pin MOSFET (I presume) on the motherboard that I'm still trying to repair (HP Stream 11-ah117wm DAY0HGMB6C1 REV:C), close to the DC IN connector, and when I read voltage on Drain (5-8 pins) and Source (1-3 pins), I got the 19.81 VDC of the DC IN on each, but on the Gate (pin 4) it's 25 VDC. Is it normal? Now, I'm not quite sure the component is a MOSFET, but it looks like, and since it has the printed code on it totally unreadable, I can't try to find the datasheet. Can anyone give me a hand on this? Or maybe ff there's some MOSFET tutorial or something that you can...
    06-19-2025, 08:19 AM
  • Sean Devine
    Cyberpower 1285AVR (CP1285AVRLCD) reporting wrong battery voltage?
    by Sean Devine
    UPS turned off one night and it seemed that the 3 year old batteries gave out.
    Replaced with a new pair, but the UPS software claimed the battery voltage was only 18 volts and needed to charge. After 24 hours, the UPS claimed only 60% charge and 20 volts (although FWIW, my meter sees 27v).
    ...then I found various Cyberpower threads here with some guidance on what to check.
    C1 (22uF) tested at 2, so I replaced that.
    Put it all back together and didn't see a change on the reported battery voltage. Although, I did run the quick battery diagnostic...
    03-03-2025, 08:23 PM
