Re: Laptop battery charging circuit
thank you So much.
This is a sticky topic.
what about charger center pins and charger detection circuits?Leave a comment:
Very useful information. THANKS .Leave a comment:
excellent contribution, thanks for sharingLeave a comment:
Thank you for the Information and starting guide for Charger IC !Leave a comment:
Thank you for this useful share.
I have a question, which pin of kbc will activate the charging ic to charge the battery?Leave a comment:
Thank You for a great research!
One question to: AC adapter not detected, wrong AC adapter
what is AD_ID voltages for HP, Lenovo and other resistive dividers. (Dell has one-wire bus for it). If that ID voltages are model dependant, some examples please.
Konstantin.Leave a comment:
what about the battery that was long without charging and it's dead now? i open the battery, charge it from external PS, and how to get it to work again,since the managment chip is probably not turning the output...
i did that multiple times,and it never works...just yesterday, i charged it from external PS,and it's now charged, i plug it in and it doesn't recognize it, it starts to charge for few seconds and that's that...Leave a comment:
Thank you piernov. This helped me a lot understanding how those circuits work!Leave a comment:
great job thanks for sharingLeave a comment:
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
Highly Integrated Narrow VDC Battery Charger for Notebook Computers
The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
Narrow VDC applications where the system power source is
either the battery pack or the regulated output of the charger.
This makes the max voltage to the system equal to the max
battery voltage instead of the max adapter voltage. Operating
at lower system voltage can improve...-
Channel: Common Parts Library - Datasheets
11-05-2024, 04:43 PM -
The MT3608 is a constant frequency, 6-pin SOT23 current mode step-up converter intended for small, low power applications. The MT3608 switches at 1.2MHz and allows the use of tiny, low cost capacitors and inductors 2mm or less in height.
Internal soft-start results in small inrush current and extends battery life.
The MT3608 features automatic shifting to pulse frequency modulation mode at light loads. The MT3608 includes under-voltage lockout, current limiting, and thermal overload protection to prevent damage in the event of an output overload. The MT3608 is available...-
10-07-2024, 05:02 AM -
by alro7779Hello, guys!
Got this 8-pin MOSFET (I presume) on the motherboard that I'm still trying to repair (HP Stream 11-ah117wm DAY0HGMB6C1 REV:C), close to the DC IN connector, and when I read voltage on Drain (5-8 pins) and Source (1-3 pins), I got the 19.81 VDC of the DC IN on each, but on the Gate (pin 4) it's 25 VDC. Is it normal? Now, I'm not quite sure the component is a MOSFET, but it looks like, and since it has the printed code on it totally unreadable, I can't try to find the datasheet. Can anyone give me a hand on this? Or maybe ff there's some MOSFET tutorial or something that you can... -
by Sean DevineUPS turned off one night and it seemed that the 3 year old batteries gave out.
Replaced with a new pair, but the UPS software claimed the battery voltage was only 18 volts and needed to charge. After 24 hours, the UPS claimed only 60% charge and 20 volts (although FWIW, my meter sees 27v).
...then I found various Cyberpower threads here with some guidance on what to check.
C1 (22uF) tested at 2, so I replaced that.
Put it all back together and didn't see a change on the reported battery voltage. Although, I did run the quick battery diagnostic...3 Photos - Loading...
