HP 17-e101sl Laptop won't turn on even with voltages
  • SickPick
    • Sep 2020
    • Italy
    Hello guys, I recently bought a broken laptop for so cheap but with learning purposes, I would really like to know more and more about this things but I'm stuck in this issue and I hope that someone could help me here...
    So, as I was saying, I bought this laptop and the problem was the fact that it had no lights on, no signals of life whatsoever. I disassembled it and checked for voltages and turned out that my main 19v power rail was missing after the first mosfet... So I took it down and jumped a wire and, in fact, now I have the charger light and I also have 19v and 3,3v everywhere i checked but when I short the pins from the power up button, all I get is a light which usually is on when the laptop is on, but not only the laptop is not coming on also when I stop shorting those pins, the light goes off.
    I know there is an issue where if there is a short between the middle pin with + the laptop won't just turn on, but I think that's not the case here since I have no short there...
    Now, I'm thinking that the problem in the SuperIO but as far as I know, if it was dead I should not get that light on, is that right?
    I also wanna mention that I got told that could actually be a short on the 5V power rail and that's could be the reason of the light to be on when I short those pins but it doesn't turn on because the SuperIO it's cutting down the power for that ipothetical 5V short... I know the method of the voltage injection is very useful but I only have a 15V 1A Max power supply and it has short protection, so it's cutting down the power when I work on a shorted board...
    I would really like to get some help here if anyone can... I bought this and other laptops like this to learn how to do repairs and I've been successful with several, but this... Maybe this is just too much for my knowledgle...
    Sorry so much for my english, I'm Italian and I'm doing my best and... Thanks in advance!
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP 17-e101sl Laptop won't turn on even with voltages
    is your mb quanta R62?? If so you need to measure voltage on pin 1/4/5 of PQ27 and all pins of PQ30. Remove the jumper you made in first mosfet. Btw, your mb has multiple problems-first is voltage not passing thru PQ27 which is part of DC-IN/ charging section and then there are other faults as well. Theoritically, when you jump PQ27 mb should turn on though charging wont work.
    • SickPick
      • Sep 2020
      • Italy
      Hi, thank for the answer!
      So my MB is a Quanta R63, does it make any difference? I know that by jumping that mosfet I shoud be able to turn on the board at least, but as you said, there are definetly multiple problems...
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        R62 & R63 are almost similar in charging circuit but always preferred to refer to exact schematic if available. Fortunately, R63 diagram is freely available and you need to fix the charging circuit first. You need to tackle problems as per sequence, hence i suggest to fix charging circuit first. Btw, the dc in section which i asked to probe is same in both mb. So get going with these measurements first.
        • yomama07032
          Microsoft Surface Laptop 3 (1868) won't turn on
          by yomama07032
          I have a Microsoft Surface Laptop 3 (1868) - 13.5 inch. It is the version with the i5, 8 GB of RAM, and 256 GB SSD. I believe the motherboard number is M1098028-008. It has been dead for a year and a half. I tried everything that is suggested on Microsoft's support website. I have the original power supply, and the white light on the power supply's connector turns on and stays on when it is connected to the laptop. Nothing happens when I try to turn on the laptop. The caps lock key's light does not turn on. There is absolutely no sign of life. I have also tried charging the laptop using the USB-C...
          11-01-2024, 05:25 PM
        • techrepairheide
          Gaming laptop Clevo NH79EP with short on 5VS-rail
          by techrepairheide
          first of all I want to apologize for my bad English, but I try to give my best.
          Customer brought me a laptop, which is charging the battery (when the dc-jack is connected) but don't power up when the power-button was pressed down. Only the white LED lights up, and you can hear a short noise in same interval when power-button was pressed and hold for longer timer. The customer changed already battery and dc-power-adapter.
          For this laptop the correct shematic is the service manual "Clevo NH50ER NH57ER NH50EPS NH57EPS - 6-71-NH5S0-D02 Schematic"....
          10-13-2024, 02:49 PM
        • PacoGT
          HELP!! Dell E6440 laptop with problem does not turn off and turn itself on help
          by PacoGT
          A few days ago my laptop gave me problems, when I wanted to turn it on to my surprise without charging so I did not put much importance on it, after that I turned it on with a charger, it turned on and charged the laptop, the problem with the laptop is that when it is turned off it turns to turn on after seconds, sometimes at 2 or sometimes at 8, other than that it works normally, I already checked many things, I changed a mosfet at the charge input to a pnp but it remained the same, after that I checked and I did not find anything outside Normally, before that, it had a failure where I changed...
          07-11-2023, 09:31 PM
        • RdeveLabs
          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
          by RdeveLabs
          To all the members here...
          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
          05-05-2025, 04:59 AM
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
