Razer Blade 15 HELP ISL955 circuit
  • alekk89
    • Nov 2015
    • 32
    • United Kingdom
    Can someone help identify the missing resistors and any of the other damaged components if possible (check the attached image)
    The laptop is Razor Blade 15 RZ09-02385
    The 2 resistors are part of the ISL955 circuit, probably battery charging IC
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Razer Blade 15 HELP ISL955 circuit
    Missing resistor are PR110/111. You need to check on which pin of ISL95520 are they connected. Open up any other schematic which have isl95520 and findout the value of resistor according to pin number concerned. This way you will get 90% accurate vale of resistors though it may vary from platform to platform a bit.
    • alekk89
      • Nov 2015
      • 32
      • United Kingdom
      Any suggestions on which brand to look at?
      I have no idea what laptops use ISL955
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3582
        • slovakia
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          LA-D071P. Use this schematic. Its available on our forum.
          • coinbusiness
            • May 2017
            • El Salvador
            Thank you!!
