HP 14 DA0U8AMB6A0 short in 1.05v anything hot
  • ruletero
    • Nov 2018
    • 182
    • Mexico
    I have this motherboard DA0U8AMB6A0.
    It has PU14 (+1.0VS5) burned, I replaced it and now when I press the power button it turn on and turn off in half a second.
    I checked and found it has a short in +1.05V line
    PL23 has 1.7 ohms to ground and I inyected 1v and it use 3A or more but anything is hot, only a little the processor but very little.
    The processor is dead?
    Please help
  • ruletero
    • Nov 2018
    • 182
    • Mexico
    Re: HP 14 DA0U8AMB6A0 short in 1.05v anything hot
    (I replaced it and now when I press the power button it turn on and turn off in half a second.)
    Sorry, I forgot to tell it, I have all voltages on that instant including VCCore
    • Spider1211
      • Oct 2019
      • 532
      • Mauritius
      Remove PJP6 (unsolder and make sure contact are properly clean) and measure resistance again on point 1 and 2. If resistance to ground on point 1 is low resistance, remove PU13 and measure again.
      • ruletero
        • Nov 2018
        • 182
        • Mexico
        Sorry, the mother hasn't pads, they are only marked in the schematic.
        I remove PL23 and it has 123 ohms on PU13 side and 1.6 ohms on PJP6 side, then, the short is PCH or processor, I guess.
        • Spider1211
          • Oct 2019
          • 532
          • Mauritius
          Inject 1V in PJP6 side and see what gets hot. If the PCH die gets hot, its most likely shorted.
          Check if resistance of PR240 and PR241 read ok also.
          • ruletero
            • Nov 2018
            • 182
            • Mexico
            I already inyected 1v in PL23 PJP6 side , but nothing is hot, only the processor a litle.
            Values are correct but I had to remove them to check.
            • Spider1211
              • Oct 2019
              • 532
              • Mauritius
              Can you increase the current? I see from post #1 you used 1V @3A. Can you try 1V @5A?
              • ruletero
                • Nov 2018
                • 182
                • Mexico
                I haven't psu, have built a regulated power supply but it can't deliver more than 3A. I'm going to find another option to try with 5A but I guess 3A is a high current and I should to note something hot.
                • Udemzy
                  • May 2017
                  • 161
                  • Guatemala
                  Replace processor it is short.
                  • ruletero
                    • Nov 2018
                    • 182
                    • Mexico
                    That is the first one I thought but I wanted to listen the experts opinion because the processor isn't so hot only a bit.
                    Unfortunately I don't have maner to change it so I'm going to find a new mobo.
                    Thank you for your response
                    • DynaxSC
                      Extreme High Current & Low Voltage Short Killer ??
                      by DynaxSC
                      Hi Folks
                      I'm looking for a extreme high current short killer solution for a reasonable cost.
                      I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                      After taking off the socket, the shorts dissappear again.
                      The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                      10-15-2024, 10:13 AM
                    • Stephen
                      MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                      by Stephen
                      I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                      02-06-2025, 12:03 PM
                    • Victor Moreira Silva
                      Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                      by Victor Moreira Silva
                      I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                      Well, my decice specs are the following:
                      Model: Acer Nitro 5 AN517-54-55T5
                      CPU: Intel Core i5-11400H
                      GPU: NVIDIA GeForce GTX 1650
                      Motherboard: GH51G LA-L181P Rev:1c
                      The symptom:
                      When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                      05-26-2025, 10:49 AM
                    • aaronkatrini
                      Help me find the short circuit on this WORKING Nvidia GTX1650
                      by aaronkatrini
                      Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
                      Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
                      04-18-2024, 03:15 PM
                    • Geeker007
                      9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
                      by Geeker007
                      Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
                      I am new to electronics repair, so my queries could be naive but I am ready to learn.
                      So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
                      01-28-2025, 03:31 PM
