Is my HP 250 g7 motherboard useless?
  • martin100181@gmail.com
    Netbatch
    • Sep 2020
    • 4
    • Argentina
    Hello. After replacing the screen my laptop stopped working. It charges and turns on the charging light. Also, with the ON button it turns the power light on for a few seconds and then off.
    Cooler, screen and hdd look dead.
    What should I check to know if I need to change the motherboard?
    Thank you!
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3590
    • slovakia
    Re: Is my HP 250 g7 motherboard useless?
    r u replacing screen with battery or charger attached?
      Netbatch
      • Sep 2020
      • 4
      • Argentina
      Unfortunately yes. The person who changed the screen did it with the battery on place. Is it possible that motherboard is fixable?
        Netbatch
        • Sep 2020
        • 4
        • Argentina
        Please. If anybody can help me I need to know if I have to buy a new motherboard or if maybe I can fix this one
        Thanx
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3590
          • slovakia
          search for short on that LVDS connector. check schematic
          • Rav_tangle
            MacBook Pro 2011 turns on with keyboard light , screen dead
            by Rav_tangle
            Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
            I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
            Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
            is this...
            05-31-2024, 04:09 PM
          • smic717394
            by smic717394
            07-25-2024, 10:16 AM
          • Archimedes
            HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
            by Archimedes
            Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
            Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
            Fans are spinning. Blindly could install windows11 and got the device manager...
            07-30-2024, 05:14 PM
          • Stanley1843
            Motherboard W26361-W84-X-02 - Black Screen
            by Stanley1843
            Hello to everyone.
            My W26361-W84-X-02 motherboard starts but don't show image (no logo screen neither bios). Because, I have two of them I desoldered the bios chip from the no working motherboard and I soldered it to the working motherboard and the motherboard works OK, so the bios firmware isn't the problem. Below I took some measurements from the no working motherboard when is power on. Also, I replaced the RAM and didn't work again (maybe some pins from the RAM slot don't have the right voltage?). I replaced and the bios battery, and I made reset on the bios and again the problem didn't...
            05-23-2024, 03:51 PM
          • Mess
            Motherboard diagnostic beginner advice
            by Mess
            To save you some time: the most important bits are in bold.
            Some further examples/explanations or to the side & in grey - you can probs skip them if it's TLDR for you. Sorry, I've got ADHD & tend to over-explain stuff - just like I'm doing right now 😅 Briefness is for poets not me 🙈
            Please help!! 🎶I'm just a girl in a world that wants to scam me out of lots of money for any tech stuff/repairs 🎵 Seriously tho, I'm poor&I can't afford to get laptop diagnosis, especially if it ends up needing a new motherboard. Where I live, all the tech shops are run by very...
            09-12-2024, 07:02 PM
