Is my HP 250 g7 motherboard useless?
  • martin100181@gmail.com
    Netbatch
    • Sep 2020
    • Argentina
    Hello. After replacing the screen my laptop stopped working. It charges and turns on the charging light. Also, with the ON button it turns the power light on for a few seconds and then off.
    Cooler, screen and hdd look dead.
    What should I check to know if I need to change the motherboard?
    Thank you!
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Re: Is my HP 250 g7 motherboard useless?
    r u replacing screen with battery or charger attached?
      Netbatch
      • Sep 2020
      • Argentina
      Unfortunately yes. The person who changed the screen did it with the battery on place. Is it possible that motherboard is fixable?
        Netbatch
        • Sep 2020
        • Argentina
        Please. If anybody can help me I need to know if I have to buy a new motherboard or if maybe I can fix this one
        Thanx
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3627
          • slovakia
          search for short on that LVDS connector. check schematic
          • Rav_tangle
            MacBook Pro 2011 turns on with keyboard light , screen dead
            by Rav_tangle
            Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
            I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
            Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
            is this...
            05-31-2024, 04:09 PM
          • smic717394
            by smic717394
            07-25-2024, 10:16 AM
          • jean luc ferre
            display screen problems after changing motherboard
            by jean luc ferre
            First on my laptop i had a motherboard with a pentium 6100 processor. Installing w11 i was blocked on the 23h2 version...impossibility to upgrade toward 24h2 because the SSE4.2 functionnality of the cpu was missing. About displaying and screen looking all was perfect.
            I changed of motherboard with an intel I3 processor...and now i don't find the previous aspects of the displaying.
            Now i have a veiled screen and pixels are missing though the graphics parameters have not changed.
            Desinstalling and reloading the drivers in the same time on the graphic card (intel hd...
            09-11-2025, 10:28 AM
          • Archimedes
            HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
            by Archimedes
            Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
            Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
            Fans are spinning. Blindly could install windows11 and got the device manager...
            07-30-2024, 05:14 PM
          • frannyjunk
            Hisense 40H4F no backlight but turns off after splash screen
            by frannyjunk
            So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
            TIA.
            09-24-2025, 10:59 AM
