Charging circuit troubleshooting guide
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3609
    • slovakia
    Hello.
    This time i face charging circuits with some weird problems so i will be happy if someone have some troubleshooting guide or some publications about this circuit
  • MaxPower666
    • Oct 2019
    • 5
    • Austria
    Re: Charging circuit troubleshooting guide
    Macbook ?
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3609
      • slovakia
      asus K54, X555 and so
      • repair-it
        Engineering help - how does the charging circuit on this board work?
        by repair-it
        This board attaches to 2 12v batteries in tandum (Black/Red squares). There is a 24v power supply that attaches at the 2 pin molex connector (circled in red). I need help to determine which components run the charging circuit in an effort to determine a point of failure. There are multiple via's, making it difficult to trace the circuit. Nothing appears to be shorted but I wasn't able to fully test as I do not have 2 12v batteries available. My assumption is that the micro controller (red question mark) determines when to turn the charging circuit on & off. I'm pretty sure a regulator and...
        08-31-2024, 12:32 PM
      • fab13
        Nintendo Switch lite charging chip heats up and does not short circuit
        by fab13
        Hello everyone
        Small technical problem on a Nintendo Switch lite
        Here's what I noticed: the USB port has been damaged internally, with a short circuit on the power supply line to the small fuse.
        After replacing the USB connector, the short circuit went away and I can't see any other short circuit in the whole motherboard.
        When I charge the console, it seems to be charging: I get 15 volts and an amperage of 0.450 A.
        Then, after a while, the amperage increases to 1.1 A and the BQ24193 charging chip starts to heat up, as evidenced...
        09-16-2023, 04:59 AM
      • TurcoLoco
        I Would Like To Fix This HP Laptop, Model:15-dy5058cl
        by TurcoLoco
        Hello all,
        My first post on this forum. Looking at the "Beginner's Guide", I am in the second group even though I'd like to fix this laptop so I can donate it to someone.
        I am a computer tech but very new to electronics repair iow, a total noob but in the process of learning, hence posting here. The laptop was donated to me by a client.
        It is a couple of years old 15" HP Laptop, Model:15-dy5058cl, Prod ID: 8L5X9UA.
        The issue: Charger is detected but doesn't charge the battery.
        Laptop won't power on without the battery (not sure if this is by...
        06-26-2025, 04:54 PM
      • piernov
        Laptop battery charging circuit
        by piernov
        1. Some theory
        1.1. Introduction
        Almost every laptop has a charging circuit of some sort, that does a few things:
        • Manages switching between AC adapter and battery power
        • Manages battery charging and generates power rail to charge battery
        There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:
        • Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
        • Narrow VDC (NVDC)
        Texas instrument has a nice overview of these technologies with some more details at https:...
        11-15-2020, 01:31 PM
      • Techie_hobby1
        Help please with identification of few components for troubleshooting (Solar Water Fountain circuit)
        by Techie_hobby1
        Need some help please with a few components on this small board so that I can troubleshoot the circuit.
        The PCB is a Single sided board fairly simple circuitry has a +ve and -ve Solar cell power input, a 7.4v 1500mAh (dual 18630 cell) power in which the Solar panel charges the cells, and lastly the Output goes to a DC connector...
        J1 is actually 1P1T Switch (in ON position completes Battery cell circuit
        J2 - to DC Output
        J3 is Battery cell connector
        however I am struggling to identify if:
        Y1 (SOT-23) are NPN Transistors, MOSFET's or 11v Zener's....
        07-24-2025, 12:43 PM
