Gooday people i have a 820-3115-B Macbook pro 2012 that gives me greenlight but does not power on...History of the machine was there was no green-light and dead.And i replaced the ISL chip for brand new 1...Greenlight now but will not power on automatically or fan spin.I checked most of my relevant power rails and i realize that PP5v_S3 is missing...It's drawing 0.02 Amps Possible you guys can help me pinpoint the issue? btw 12.58v on PPBUS_G3H
Macbook pro 2012 820-3115-B Greenlight no Power on
Tags: None
Re: Macbook pro 2012 820-3115-B Greenlight no Power on
My friend I am getting 0v on all bios pins....What does this mean?Comment
Go through the list of power rails as always…OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
Okay hi here is the list of power rails.I may have added some irrelevant rails but thanks..if any of them are missing kindly let me know and i will add it asap.
PPBUS_G3H = 12.58v
PPBUS_S5_HS_COMPUTING_ISNS = 12.58v
PPBUS_S5_HS_OTHER_ISNS = 12.58v
PPDCIN_G3H = 18.52v
PP3V42_G3H = 3.42v
PPVRTC_G3H = 3.42v
PP3V3_S5 = 0v
PP3V3_SUS = 0v
PP3V3_S4 = 0v
PP3V3_S3 = 0v
PP3V3_S0 = 0v
PP5V_S5 = 5v
PP5V_SUS = 5v
PP5V_S3 = 0v
PP5V_S0 = 0vComment
okay thanks will go tru and see what happensLast edited by platinumsteel; 08-30-2020, 05:49 PM.Comment
Hi again guys am not sure if am at least on the trail but I read on this forum where piernov stated that ''There are power rails derived from PP3V3_S5 and PP5V_S4RS3'' so i checked on PP5V_S4 and it looks like there is a dead short there..I tested that rail on another identical donor board and it's not shorted..So Can anyone of you guide me further on how i should proceed? ..thanks
Use openboardview instead of BoardViewer, it`ll give you a better visual understanding of whats connected to what. http://openboardview.org/Comment
I believe PP3V3_S5 is your immediate problem, I would recommend checking that out before any S4 or lower rails.
Is it shorted to ground?
My computer with my schematics is not available right now so I can't tell you which pins on which components to check out, but I'd check to see if PP3V3_S5 is shorted to ground. If it's not shorted to ground, find the IC that creates it and see why it's not doing its jobComment
Thanks for the reply..But PP3V3_S5 doesn't seem shorted to ground..And well am a little bit of a newbie and having a hard time finding the IC that creates it in the schematic.Will be grateful for some help.Comment
U7200 CREATES PP3V3_S5.Check the ic location on broadview.Inspect for corrosion,bad cap and feedback resistors.Comment
Thanks a lot knightwolf for pointing it out...I took some voltages measurements and haven't really picked up any corrosion or short... and hoping you all could tell me if i might need to change U7200 still
Vin = 12.58V
VREF= 2.6V
ENTRIP1 = 0V
ENTRIP2 = 0V
VREG5 = 0.8V
VREG3 = 0V
EN0 = 3.7V
PGOOD = 0VComment
There's an issue with your measurements, in post #6 you said " PP5V_S5 = 5v", in post #14 you said " VREG5 = 0.8V". They're the same rail.OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
Resistance on
L7220 = 0.138V
=0.812k
L7260 =0.440V
=3.425K and climbing
Below are U7941 and U7200 voltages
U7941
Pin1 PP3v42_G3H 3.42v
Pin2 SMC_PM_G2_EN 3.42v
Pin3 P5V3V3_Reg_EN 3.5v
Pin4 P3V3S5_EN_L_R 0v
Pin 5 GND
Pin6 PP3V3_S5 0v
Pin7 S5PGOOD_DLY 0v
Pin8 S5_PWRGD 0v
Pin9 GND
U7200
pin1 P5VS3_ENTRIP =0v
pin2 P5VS3_VFB =0v
pin3 P5VP3V3_VREF =2.6v
pin4 P5VP3V3_REG3 =0v
pin5 P3V3S5_VFB =0v
pin6 P3VS5_ENTRIP =0v
pin7 P3v3S5_V02 =0v
pin8 P5VP3V3_REG3 =0v
pin9 P3V3S5_VBST =0v
pin10 P3V3S5_DRVH =0v
pin11 P3V3S5_LL =0v
pin12 P3V3S5_DRVL =0v
pin13 5V3V3_REG_EN =3.7v
pin14 P5VP3V3_VREF =2.7v
pin15 GND
pin16 PPBUS_S5_HS_OTHER_ISNS =12.58v
pin17 PP5V_S5 =0.865v
pin18
pin19 P5VS3_DVRL =0.861v
pin20 P5VS3_LL =0v
pin21 P5VS3_DRVH =0v
pin22 P5VS3_VBST =0v
pin23 P5V3V3_PGOOD =0v
pin24 P5VS3_VO1 =0v
pin25 GNDComment
by SarcasticOPI am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
- PPBUS_G3H (12.6V-12.8V)
- This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
- PP3V42_G3H (3.42V)
- This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
- PPVRTC_G3H (3.3V)
- This
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... - Loading...
