Macbook pro 2012 820-3115-B Greenlight no Power on
  • platinumsteel
    • May 2019
    • 234
    • Trinidad&Tobago
    Gooday people i have a 820-3115-B Macbook pro 2012 that gives me greenlight but does not power on...History of the machine was there was no green-light and dead.And i replaced the ISL chip for brand new 1...Greenlight now but will not power on automatically or fan spin.I checked most of my relevant power rails and i realize that PP5v_S3 is missing...It's drawing 0.02 Amps Possible you guys can help me pinpoint the issue? btw 12.58v on PPBUS_G3H
  • dellxps15
    • Feb 2014
    • 1588
    • italy
    Re: Macbook pro 2012 820-3115-B Greenlight no Power on
    check bios pins if are ok, check if 3.3 and 5 volt ic is ok.
    • platinumsteel
      • May 2019
      • 234
      • Trinidad&Tobago
      My friend I am getting 0v on all bios pins....What does this mean?
      • dellxps15
        • Feb 2014
        • 1588
        • italy
        check the 3.3 5v ic u7500 pins
        • piernov
          • Jan 2016
          • 4435
          • France
          Go through the list of power rails as always…
          • platinumsteel
            • May 2019
            • 234
            • Trinidad&Tobago
            Okay hi here is the list of power rails.I may have added some irrelevant rails but thanks..if any of them are missing kindly let me know and i will add it asap.
            PPBUS_G3H = 12.58v
            PPBUS_S5_HS_COMPUTING_ISNS = 12.58v
            PPBUS_S5_HS_OTHER_ISNS = 12.58v
            PPDCIN_G3H = 18.52v
            PP3V42_G3H = 3.42v
            PPVRTC_G3H = 3.42v
            PP3V3_S5 = 0v
            PP3V3_SUS = 0v
            PP3V3_S4 = 0v
            PP3V3_S3 = 0v
            PP3V3_S0 = 0v
            PP5V_S5 = 5v
            PP5V_SUS = 5v
            PP5V_S3 = 0v
            PP5V_S0 = 0v
            • dellxps15
              • Feb 2014
              • 1588
              • italy
              PP3V3_S5 = 0v
              check why this is 0v
              • platinumsteel
                • May 2019
                • 234
                • Trinidad&Tobago
                okay thanks will go tru and see what happens
                • platinumsteel
                  • May 2019
                  • 234
                  • Trinidad&Tobago
                  Originally posted by dellxps15
                  PP3V3_S5 = 0v
                  Hi again guys am not sure if am at least on the trail but I read on this forum where piernov stated that ''There are power rails derived from PP3V3_S5 and PP5V_S4RS3'' so i checked on PP5V_S4 and it looks like there is a dead short there..I tested that rail on another identical donor board and it's not shorted..So Can anyone of you guide me further on how i should proceed? ..thanks
                    • 20952
                    Use openboardview instead of BoardViewer, it`ll give you a better visual understanding of whats connected to what. http://openboardview.org/
                    • Flippers McCoy
                      Tinkerer
                      • Mar 2018
                      • 106
                      I believe PP3V3_S5 is your immediate problem, I would recommend checking that out before any S4 or lower rails.
                      Is it shorted to ground?
                      My computer with my schematics is not available right now so I can't tell you which pins on which components to check out, but I'd check to see if PP3V3_S5 is shorted to ground. If it's not shorted to ground, find the IC that creates it and see why it's not doing its job
                      • platinumsteel
                        • May 2019
                        • 234
                        • Trinidad&Tobago
                        Thanks for the reply..But PP3V3_S5 doesn't seem shorted to ground..And well am a little bit of a newbie and having a hard time finding the IC that creates it in the schematic.Will be grateful for some help.
                        • KNIGHTWOLF
                          • Jun 2020
                          • 3
                          • INDIA
                          U7200 CREATES PP3V3_S5.Check the ic location on broadview.Inspect for corrosion,bad cap and feedback resistors.
                          • platinumsteel
                            • May 2019
                            • 234
                            • Trinidad&Tobago
                            Thanks a lot knightwolf for pointing it out...I took some voltages measurements and haven't really picked up any corrosion or short... and hoping you all could tell me if i might need to change U7200 still
                            Vin = 12.58V
                            VREF= 2.6V
                            ENTRIP1 = 0V
                            ENTRIP2 = 0V
                            VREG5 = 0.8V
                            VREG3 = 0V
                            EN0 = 3.7V
                            PGOOD = 0V
                            • dellxps15
                              • Feb 2014
                              • 1588
                              • italy
                              post voltage on L4901 .
                              • platinumsteel
                                • May 2019
                                • 234
                                • Trinidad&Tobago
                                L4901 is 3.42v on Pin 1 and 2
                                • dellxps15
                                  • Feb 2014
                                  • 1588
                                  • italy
                                  check resistance on l7220 and l7260
                                  check all u7941 volts
                                  check all u7200 pin voltage.
                                  • piernov
                                    • Jan 2016
                                    • 4435
                                    • France
                                    There's an issue with your measurements, in post #6 you said " PP5V_S5 = 5v", in post #14 you said " VREG5 = 0.8V". They're the same rail.
                                    • platinumsteel
                                      • May 2019
                                      • 234
                                      • Trinidad&Tobago
                                      Sorry about..I now checked over PP5V_S5 and it's reading 0.8v
                                      • platinumsteel
                                        • May 2019
                                        • 234
                                        • Trinidad&Tobago
                                        Resistance on
                                        L7220 = 0.138V
                                        =0.812k
                                        L7260 =0.440V
                                        =3.425K and climbing
                                        Below are U7941 and U7200 voltages
                                        U7941
                                        Pin1 PP3v42_G3H 3.42v
                                        Pin2 SMC_PM_G2_EN 3.42v
                                        Pin3 P5V3V3_Reg_EN 3.5v
                                        Pin4 P3V3S5_EN_L_R 0v
                                        Pin 5 GND
                                        Pin6 PP3V3_S5 0v
                                        Pin7 S5PGOOD_DLY 0v
                                        Pin8 S5_PWRGD 0v
                                        Pin9 GND
                                        U7200
                                        pin1 P5VS3_ENTRIP =0v
                                        pin2 P5VS3_VFB =0v
                                        pin3 P5VP3V3_VREF =2.6v
                                        pin4 P5VP3V3_REG3 =0v
                                        pin5 P3V3S5_VFB =0v
                                        pin6 P3VS5_ENTRIP =0v
                                        pin7 P3v3S5_V02 =0v
                                        pin8 P5VP3V3_REG3 =0v
                                        pin9 P3V3S5_VBST =0v
                                        pin10 P3V3S5_DRVH =0v
                                        pin11 P3V3S5_LL =0v
                                        pin12 P3V3S5_DRVL =0v
                                        pin13 5V3V3_REG_EN =3.7v
                                        pin14 P5VP3V3_VREF =2.7v
                                        pin15 GND
                                        pin16 PPBUS_S5_HS_OTHER_ISNS =12.58v
                                        pin17 PP5V_S5 =0.865v
                                        pin18
                                        pin19 P5VS3_DVRL =0.861v
                                        pin20 P5VS3_LL =0v
                                        pin21 P5VS3_DRVH =0v
                                        pin22 P5VS3_VBST =0v
                                        pin23 P5V3V3_PGOOD =0v
                                        pin24 P5VS3_VO1 =0v
                                        pin25 GND
                                        • SarcasticOP
                                          General question about MacBook power rails for repair.
                                          by SarcasticOP
                                          I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
                                          • PPBUS_G3H (12.6V-12.8V)
                                            • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
                                          • PP3V42_G3H (3.42V)
                                            • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
                                          • PPVRTC_G3H (3.3V)
                                            • This
                                          12-12-2024, 05:50 PM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
