Gooday people i have a 820-3115-B Macbook pro 2012 that gives me greenlight but does not power on...History of the machine was there was no green-light and dead.And i replaced the ISL chip for brand new 1...Greenlight now but will not power on automatically or fan spin.I checked most of my relevant power rails and i realize that PP5v_S3 is missing...It's drawing 0.02 Amps Possible you guys can help me pinpoint the issue? btw 12.58v on PPBUS_G3H
					Macbook pro 2012 820-3115-B Greenlight no Power on
	Tags: None
 Re: Macbook pro 2012 820-3115-B Greenlight no Power on
 My friend I am getting 0v on all bios pins....What does this mean?Comment
 Go through the list of power rails as always…OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
 Okay hi here is the list of power rails.I may have added some irrelevant rails but thanks..if any of them are missing kindly let me know and i will add it asap.
 PPBUS_G3H = 12.58v
 PPBUS_S5_HS_COMPUTING_ISNS = 12.58v
 PPBUS_S5_HS_OTHER_ISNS = 12.58v
 PPDCIN_G3H = 18.52v
 PP3V42_G3H = 3.42v
 PPVRTC_G3H = 3.42v
 PP3V3_S5 = 0v
 PP3V3_SUS = 0v
 PP3V3_S4 = 0v
 PP3V3_S3 = 0v
 PP3V3_S0 = 0v
 PP5V_S5 = 5v
 PP5V_SUS = 5v
 PP5V_S3 = 0v
 PP5V_S0 = 0vComment
 okay thanks will go tru and see what happensLast edited by platinumsteel; 08-30-2020, 05:49 PM.Comment
 Hi again guys am not sure if am at least on the trail but I read on this forum where piernov stated that ''There are power rails derived from PP3V3_S5 and PP5V_S4RS3'' so i checked on PP5V_S4 and it looks like there is a dead short there..I tested that rail on another identical donor board and it's not shorted..So Can anyone of you guide me further on how i should proceed? ..thanks
 Use openboardview instead of BoardViewer, it`ll give you a better visual understanding of whats connected to what. http://openboardview.org/Comment
 I believe PP3V3_S5 is your immediate problem, I would recommend checking that out before any S4 or lower rails.
 Is it shorted to ground?
 My computer with my schematics is not available right now so I can't tell you which pins on which components to check out, but I'd check to see if PP3V3_S5 is shorted to ground. If it's not shorted to ground, find the IC that creates it and see why it's not doing its jobComment
 Thanks for the reply..But PP3V3_S5 doesn't seem shorted to ground..And well am a little bit of a newbie and having a hard time finding the IC that creates it in the schematic.Will be grateful for some help.Comment
 U7200 CREATES PP3V3_S5.Check the ic location on broadview.Inspect for corrosion,bad cap and feedback resistors.Comment
 Thanks a lot knightwolf for pointing it out...I took some voltages measurements and haven't really picked up any corrosion or short... and hoping you all could tell me if i might need to change U7200 still
 Vin = 12.58V
 VREF= 2.6V
 ENTRIP1 = 0V
 ENTRIP2 = 0V
 VREG5 = 0.8V
 VREG3 = 0V
 EN0 = 3.7V
 PGOOD = 0VComment
 There's an issue with your measurements, in post #6 you said " PP5V_S5 = 5v", in post #14 you said " VREG5 = 0.8V". They're the same rail.OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
 Resistance on
 L7220 = 0.138V
 =0.812k
 L7260 =0.440V
 =3.425K and climbing
 Below are U7941 and U7200 voltages
 U7941
 Pin1 PP3v42_G3H 3.42v
 Pin2 SMC_PM_G2_EN 3.42v
 Pin3 P5V3V3_Reg_EN 3.5v
 Pin4 P3V3S5_EN_L_R 0v
 Pin 5 GND
 Pin6 PP3V3_S5 0v
 Pin7 S5PGOOD_DLY 0v
 Pin8 S5_PWRGD 0v
 Pin9 GND
 U7200
 pin1 P5VS3_ENTRIP =0v
 pin2 P5VS3_VFB =0v
 pin3 P5VP3V3_VREF =2.6v
 pin4 P5VP3V3_REG3 =0v
 pin5 P3V3S5_VFB =0v
 pin6 P3VS5_ENTRIP =0v
 pin7 P3v3S5_V02 =0v
 pin8 P5VP3V3_REG3 =0v
 pin9 P3V3S5_VBST =0v
 pin10 P3V3S5_DRVH =0v
 pin11 P3V3S5_LL =0v
 pin12 P3V3S5_DRVL =0v
 pin13 5V3V3_REG_EN =3.7v
 pin14 P5VP3V3_VREF =2.7v
 pin15 GND
 pin16 PPBUS_S5_HS_OTHER_ISNS =12.58v
 pin17 PP5V_S5 =0.865v
 pin18
 pin19 P5VS3_DVRL =0.861v
 pin20 P5VS3_LL =0v
 pin21 P5VS3_DRVH =0v
 pin22 P5VS3_VBST =0v
 pin23 P5V3V3_PGOOD =0v
 pin24 P5VS3_VO1 =0v
 pin25 GNDComment
			by SarcasticOPI am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?- PPBUS_G3H (12.6V-12.8V)- This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
- PP3V42_G3H (3.42V)- This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
- PPVRTC_G3H (3.3V)- This
 Assuming...7 Photos
			by PantherDaveHi all!
			by GLISITHi all,
			by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
- Loading...
