Help to identify electronic component.
  • nunofcc
    • Jul 2019
    • 29
    • porto
    Good afternoon, I come to ask your help to identify which is the electronic component that is marked in red. It is found on a notebook motherboard.
    What is the component called?
    And if it's normal to overheat?
    • 21182
    Re: Help to identify electronic component.
    Post in english please !!! .Those are coils. What is the motherboard part number,what problem are you having ?
    • nunofcc
      • Jul 2019
      • 29
      • porto
      Thanks a lot for the help. has no number or reference on the motherboard. the problem is notebook has power but does not give an image. I already reprogrammed the bios but it didn't work. I noticed that one of the coils is very hot, is it normal?
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Seems like acer but there is part number on mb.You need to find out.
        • nunofcc
          • Jul 2019
          • 29
          • porto
          where can i find this part number? can someone help me? it is an acer E5-575G.
          • nunofcc
            • Jul 2019
            • 29
            • porto
            how can I read the reference of this coil?
            • nunofcc
              • Jul 2019
              • 29
              • porto
              Good Morning.
              The problem I have is: the notebook turns on and the screen also turns on but there is no image, it is all black with a small white stroke in the corner blinking.
              Thank you.
              • Techtiger
                • Oct 2014
                • 1602
                • france
                check the voltage on the LCD connector pin 40 39 34 35 36 26 27 10 11
                • Dumah Brazorf
                  • Jun 2013
                  • 179
                  • Italy
                  Wait, the blinking line is an image.
                  It does not seems to load the os. Remove the hard disk and see it you can see the post/bios screen.
                  Have you already removed the internal battery for a while to reset the bios?
                  • nunofcc
                    • Jul 2019
                    • 29
                    • porto
                    Good afternoon.
                    I did everything I was told. I took the battery out of the bios and waited a few hours. I took ram and disk the screen is completely black. Only with the ram a small flashing line appears in the image. Does anyone have any idea what it might be?
                    • nunofcc
                      • Jul 2019
                      • 29
                      • porto
                      Good afternoon.
                      I checked all the voltages on the indicated pins, they are all correct as in the diagram.
                      • petehall347
                        • Jan 2015
                        • 4427
                        • United Kingdom
                        tap f2 right after switching it on and see if it loads bios
                        also try an external monitor
                        • nunofcc
                          • Jul 2019
                          • 29
                          • porto
                          Good afternoon,
                          I did as indicated by the f2 key right after starting. but it does nothing. the laptop starts with the black screen and the white cursor flashing in the upper left corner.
                          • Instafixx
                            Macbook A2179 820-01958
                            by Instafixx
                            Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
                            The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
                            I checked the Power Sequences below and found this -
                            Once a valid external power source (Charger or battery) is connected, the following rails will come online.
                            PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
                            PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
                            05-20-2023, 05:19 AM
                          • cook
                            HP Power Supply 6632A: Fast Mode vs Normal Mode?
                            by cook
                            FAST MODE vs NORMAL MODE
                            I have recently acquired a HP 6632A DC power supply. I am just beginning to use it and I have been reading the manuals for it. It is the first power supply I have ever owned or used. I am a very beginner hobbyist and do not have an engineering background, as may be obvious by my question...
                            I can't seem to understand what the actual use is for the 'Fast Mode' or the 'Normal Mode' on the power supply. Although the manual states what the two modes do from a engineering/technical standpoint, I don't know enough to understand what it all means,...
                            06-07-2020, 05:32 AM
                          • thesame
                            DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
                            by thesame
                            Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
                            The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
                            02-27-2024, 04:31 AM
                          • silver60618
                            Lenovo Legion 7 - Help Identify IC
                            by silver60618
                            Hi gang, its a long shot, but working on Lenovo Legion Pro 7 motherboard NM-F091, and trying to identify this component near GPU with marking "eHFQH" that is burned and shorting the board. Looks like power management IC
                            I couldnt find any schematic or boardview. The CPU side also has same chip. Any way to identify this chip? or take measurements from the good chip to determine what it is?
                            Any help would be appreciated...
                            07-02-2025, 12:16 PM
                          • chth96
                            How can I identify varistor which have been blew up?
                            by chth96
                            I mistakely pluged 100v japanese retro game console to 220v outlet.
                            So It seems that glass fuse and varistor have been blew up.
                            I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
                            Is there any way to identify varistor type in my sega saturn PSU?
                            Any reply would be appreciated.
                            EDIT:
                            It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
                            11-26-2023, 08:52 AM
