Dell D430-JAU00 LA-3741P fan&display failing
  • kamel
    • May 2011
    • 116
    • TUNISIA
    Hello! Need urgent help P.S !
    Fixed initially a short on memory bus +1.8V rail by removing on board cells getting hot one by one, till last cell.
    Inserted a DDR2 in SODIMM slot1.
    Switched lap, all main voltages are ok, but fan and display are failing.
    Voltages measured on FAN & Thermal Sensor IC "EMC4000" are attached.
    Issues found :
    Pin6- FAN_OUT : 0V ?? no spinning.
    Pin30- THERMTRIP_SIO : 0V low, I guess, it should be high i.e +3.3V p.s correct.
    Pin29- HW_LOCK# : 0V. Is it Hardware lock signal ? Should it be high level i.e +3.3V ? p.s correct.
    Any idea on next steps to help solving issues would be much appreciated!
    Thank you
    Thermal sensor schematic moved to new thread - https://www.badcaps.net/forum/showthread.php?t=123687
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Dell D430-JAU00 LA-3741P fan&display failing
    Please clarify what "fan and display are failing" mean.
    Also THERMTRIP_SIO doesn't have # indicating active low signal, so 0V should be correct (meaning thermal protection not triggered).
    • Duranitron
      • Jul 2014
      • 544
      • Philippines
      Switched lap, all main voltages are ok, but fan and display are failing?
      what do you mean failing. no fan spin and no display? is there any led that lights as indication the laptop is alive. try to insert known working memory maybe the old one got busted..have you flash the bios..
      Never stop LEARNING because life never stops TEACHING!
      • kamel
        • May 2011
        • 116
        • TUNISIA
        First, Thanks for your quick follow up.
        I mean fan is not spinning and there is no display.
        P.s also confirm : Found Pin29- HW_LOCK# = 0V. Is it "Hardware lock" signal ? and if so, shouldn't it be high level i.e +3.3V ?
        • kamel
          • May 2011
          • 116
          • TUNISIA
          Thanks for your follow up.
          As explained, fan is not spinning and no display.
          I add, when switched on, led lights for 45" and then off. All main voltages including cpu are correct.
          Though, I shunted pin1 of JFAN1 "+FAN1_VOUT" directly to 3.3v run voltage, power led always went off after 45".
          • piernov
            • Jan 2016
            • 4435
            • France
            I don't see anything that could allow disabling the onboard RAM in the schematics.
            • kamel
              • May 2011
              • 116
              • TUNISIA
              Yes, I agree with you, but as far as I understand, the 3 DDR2 (2 on board and 1 SODIMM SLOT1) are supplied in parallel with same voltages and signals, so removing the 2 onboard DDR2 and using only the SODIMM slot 1 DDR2 should be ok. The GMCH will deal with the existing Ram. Please correct.
              • piernov
                • Jan 2016
                • 4435
                • France
                If BIOS tries to initialize non-existent onboard RAM, POST will fail.
                • kamel
                  • May 2011
                  • 116
                  • TUNISIA
                  I share your point of view.
                  Is it possible to edit bios dump and modify it consequently, so as to initialize only the Sodimm slot ?
                  • kamel
                    • May 2011
                    • 116
                    • TUNISIA
                    Well, I can confirm now that's a problem of initializing removed onboard RAM, because after assembling laptop, I noticed that 2 leds were constantly blinking once switched on (Memory fail).
                    Thank you.
                    Laptop was returned to customer. Thread is to be considered closed.
