Dell D430-JAU00 LA-3741P fan&display failing
  • kamel
    • May 2011
    • 118
    • TUNISIA
    Hello! Need urgent help P.S !
    Fixed initially a short on memory bus +1.8V rail by removing on board cells getting hot one by one, till last cell.
    Inserted a DDR2 in SODIMM slot1.
    Switched lap, all main voltages are ok, but fan and display are failing.
    Voltages measured on FAN & Thermal Sensor IC "EMC4000" are attached.
    Issues found :
    Pin6- FAN_OUT : 0V ?? no spinning.
    Pin30- THERMTRIP_SIO : 0V low, I guess, it should be high i.e +3.3V p.s correct.
    Pin29- HW_LOCK# : 0V. Is it Hardware lock signal ? Should it be high level i.e +3.3V ? p.s correct.
    Any idea on next steps to help solving issues would be much appreciated!
    Thank you
    Thermal sensor schematic moved to new thread - https://www.badcaps.net/forum/showthread.php?t=123687
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Dell D430-JAU00 LA-3741P fan&display failing
    Please clarify what "fan and display are failing" mean.
    Also THERMTRIP_SIO doesn't have # indicating active low signal, so 0V should be correct (meaning thermal protection not triggered).
    • Duranitron
      • Jul 2014
      • 544
      • Philippines
      Switched lap, all main voltages are ok, but fan and display are failing?
      what do you mean failing. no fan spin and no display? is there any led that lights as indication the laptop is alive. try to insert known working memory maybe the old one got busted..have you flash the bios..
      Never stop LEARNING because life never stops TEACHING!
      • kamel
        • May 2011
        • 118
        • TUNISIA
        First, Thanks for your quick follow up.
        I mean fan is not spinning and there is no display.
        P.s also confirm : Found Pin29- HW_LOCK# = 0V. Is it "Hardware lock" signal ? and if so, shouldn't it be high level i.e +3.3V ?
        • kamel
          • May 2011
          • 118
          • TUNISIA
          Thanks for your follow up.
          As explained, fan is not spinning and no display.
          I add, when switched on, led lights for 45" and then off. All main voltages including cpu are correct.
          Though, I shunted pin1 of JFAN1 "+FAN1_VOUT" directly to 3.3v run voltage, power led always went off after 45".
          • piernov
            • Jan 2016
            • 4435
            • France
            I don't see anything that could allow disabling the onboard RAM in the schematics.
            • kamel
              • May 2011
              • 118
              • TUNISIA
              Yes, I agree with you, but as far as I understand, the 3 DDR2 (2 on board and 1 SODIMM SLOT1) are supplied in parallel with same voltages and signals, so removing the 2 onboard DDR2 and using only the SODIMM slot 1 DDR2 should be ok. The GMCH will deal with the existing Ram. Please correct.
              • piernov
                • Jan 2016
                • 4435
                • France
                If BIOS tries to initialize non-existent onboard RAM, POST will fail.
                • kamel
                  • May 2011
                  • 118
                  • TUNISIA
                  I share your point of view.
                  Is it possible to edit bios dump and modify it consequently, so as to initialize only the Sodimm slot ?
                  • kamel
                    • May 2011
                    • 118
                    • TUNISIA
                    Well, I can confirm now that's a problem of initializing removed onboard RAM, because after assembling laptop, I noticed that 2 leds were constantly blinking once switched on (Memory fail).
                    Thank you.
                    Laptop was returned to customer. Thread is to be considered closed.
                    • F R 2568
                      Dell Latitude 5420 does not start (no post) need help to find the reason why
                      by F R 2568
                      Hello all,
                      this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                      I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                      If the laptop is only connected to the AC adapter (battery removed):
                      When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                      The power/battery...
                      01-08-2025, 05:45 AM
                    • master3112
                      by master3112
                      Today, 01:55 PM
                    • OntarioTL
                      Dell 5410 greyed out BT
                      by OntarioTL
                      Well I've learned something new today. Of all the Dell laptops I've come across I have never seen bluetooth greyed out, and only to learn this is during the build from Dell factory. I've tried to pull the original BIOS and fix with another dell with the same issue on the forums, however the original was not recovered from the forum upgrade so I cannot do a comparison to attempt the fix on my own.
                      If someone could help me out with this unit and I'll try the next one as so far I have 2 on my desk with this issue. Thanks in advance!
                      Dell Lattitude 5410
                      Service Tag...
                      07-25-2025, 01:28 PM
                    • lalle-
                      Dell G5 SE 5505 - "Invalid memory installed" after BIOS update.
                      by lalle-
                      Hello!
                      I have a problem with a Dell G5 SE 5505 laptop that I hope someone can give me a few pointers on.
                      [OK, it's not really a laptop, I'm running the motherboard on my desktop with only cooling, RAM and an M2 drive attached.]
                      I had some performance issues, so I decided to update my BIOS from 1.7.0 to the latest version, 1.20.0.
                      The computer restarted and the update dit not want to continue without a battery connected, even though I used dell's method of bypassing this requirement.
                      I tried updating to a custom BIOS from Reddit user Satori_Nori https://www...
                      08-11-2024, 02:01 PM
                    • trix11
                      Dell Precision T1650 MT Workstation bricked after BIOS update
                      by trix11
                      I have a Dell Precision T1650 MT workstation (of the following spec.) that was bricked yesterday when attempting to update the BIOS from A27 to A28 per:
                      - https://www.dell.com/support/home/en...-t1650/drivers > Dell Precision T1650 System BIOS
                      - Dell Precision T1650 mid tower Workstation
                      - Xeon E3-1225 V2
                      - 32Gb PC3-12800E RAM
                      - 4Tb SATA HDD
                      - motherboard: Dell part: 0C3YXR CN-0C3YXR-72200-39C-01GR-A02
                      I see now that others have experienced like issues e.g.:
                      - https://www.dell.com/community/Prec...
                      10-24-2022, 10:35 PM
