WDC hard drive ?
  • bianchi77
    • Jun 2016
    • 1121
    WDC hard drive ?
    Dear Member,
    I've found SMD diode with code 5463 on WDC Hard drive,
    Is it compatible with TVS diode ?
  • Duranitron
    • Jul 2014
    • 544
    • Philippines
    Re: WDC hard drive ?
    Originally posted by bianchi77
    Dear Member,
    transient voltage suppressor diode is mostly connected in parallel to the circuit voltage with fusible resistor or fuse in series with it.. if this smd diode code 5463 is connected with this setup most likely its a TVS to protect the WDC hardware from transient voltages or even over voltage 5v and 12v a diode test in the voltage pins can assume there is a tvs in parallel in circuit. if this diode is connected in series most likely its a ordinary a schottky a signal..a zener diode is also connected in parallel. if you want you can test it to determine the clamping voltage of the tvs using a adjustable voltage regulator..
      • 21841
      Dear Member,
      A picture is worth 1000 words .
      • federalhouse
        **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
        by federalhouse
        I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
        **Background:**
        I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
        **What I've Tried So Far:**
        1. I accessed
        08-01-2024, 07:03 PM
      • tmcw
        PC case - Hard drive rails
        by tmcw
        A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
        So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
        I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
        Now, the case is a CiT Gaming Case, and...
        05-22-2022, 12:04 PM
      • ntec
        hard drive logic board Diode identification
        by ntec
        I need to replace this small diode that is found on the logic board of a hard drive. What type of diode is this so I know I buy the correct one.
        09-27-2022, 09:05 PM
      • madura2010
        DAY11AM6E0 hard disk drive and optical disk drive not detected
        by madura2010
        Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
        i checked the connectivity of ribbon=good communication with hard and motherboard
        changed hard disk and checked=3f0 error persist
        sata power=+5v available
        Then checked data capacitors=all good
        Then checked data lines path connectivity to pch=all good
        reflashed...
        03-12-2023, 09:09 AM
      • ash91
        Hp pavilion 15 not detect hard drive
        by ash91
        Hello gentelmen .... this is my first post and sorry for my bad english,
        so my proplem is my laptop keep losing hard drive even if i but the
        hard disk in the cady (the box that can replace the dvd rom with hard disk)
        when i turn the laptop on the massage that said no boot media found pop on
        the hard disk is fine and to be sure i try another hard
        i also update my bios to the last update
        the 5 volt is present on the hard connector on the motherboard
        the dvd rom work fine when i but a windows dvd in it
        also when i boot from flash...
        06-07-2023, 01:45 PM
