Macronix 1.8V serial flash memory
  • blazzelia
    • Nov 2019
    • 40
    • Romania
    Having an Asus FX505DT with a broken BIOS, I pulled the BIOS chip - a Macronix MX25U12873F - to read what's left in it. I noticed the chip is a 1.8V chip while my RaspberryPi provides 3.3V on GPIO lines.
    I also have an USBASP programmer but it supports 5V and 3.3V voltages.
    Any idea on how to safely interface the little guy to one of the readers?
    Thanks,
    B
    • 30977
    Re: Macronix 1.8V serial flash memory
    buy a 1.8v adapter on ebay for a few €
    • blazzelia
      • Nov 2019
      • 40
      • Romania
      Yes, I just did that. I was hoping for a quicker trick... thanks
      • blazzelia
        • Nov 2019
        • 40
        • Romania
        I bought a Pololu level shifter adapter but each time when I read the chip I get a slightly different content (I'm checking using MD5SUM). After 2-3 read operations flashbios no longer see the chip. After a few minutes I can read it again.
        I checked the voltage - 1.85 to 1.9V. Any idea what I am missing?
        Thanks,
        B
        • Duranitron
          • Jul 2014
          • 544
          • Philippines
          Thanks,
          B
          you said its broken bios.. just reflash it with a new bios dump.. for the issue about the 1.8v just buy the 1.8v adapter that will not cost you time, effort and problem because it is proven working for a fraction of $.
          Never stop LEARNING because life never stops TEACHING!
          • Duranitron
            • Jul 2014
            • 544
            • Philippines
            that 1.8v adapter card will convert your existing 3.3v to 1.8v. that will safely reflash your bios.. i use ezp2010 that has no issue with 1.8v eeprom.. i have never destroy a 1.8v eeprom with this programmer and a little experiment.. i read both the dump with 1.8v adapter attached and without it read and program it , the same dump checked both and verify its identical maybe its how it powers the eeprom.. anyways. thats my opinion..
            • ekozeko333
              [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
              by ekozeko333
              I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
              🔥 The Problem Started After Suspected ESD/PD Fault
              I experienced a power issue or ESD event through a USB-C charger
              After that, the NX20P5090 power switch was visibly burned and was replaced
              Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
              🧠 What I’ve Done So Far
              Flashed...
              06-21-2025, 02:48 AM
            • corrize
              Nikon D800 camera - flash don’t work and capacitor don’t charge
              by corrize
              Hello, I'm stuck in troubleshooting…
              The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
              In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
              When I press the flash button, it's detected by the system, flash icon appear on LDC display....
              10-01-2022, 10:02 AM
            • abajor
              Canon VIXIA HF S10 A read data from inernal flash memory.
              by abajor
              Hello I've had somebody bring in one of these charming little cameras to attempt retrieving data from the internal 32GB flash.
              Something is damaged inside the cameras lens assembly I can hear it clunking around and it has probably dislodged the sensor, powering up the camera gives a blank screen and the focus motor sounds like it's having a fit.
              The camera will not connect to a computer via USB in this state, I have no options no navigation, just power up and focus/zoom motor noises.
              I think my best shot is to figure out a way to read the internal flash memory outside...
              07-20-2024, 12:04 AM
            • Ihandyrepair
              4 red flash led 65X950G boot Sony and android logo but then black
              by Ihandyrepair
              HI guys
              I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
              here is the issue
              I have Sony and android logo. but then 4 led red flash lights front of the tv
              I have 3.3v ref. 12v reg then T con 12v when I press the power on button
              but then I get black screen and 4 red flash light at the front LED
              but I get 3 led flash on the LED driver board.
              I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
              so I tried...
              07-11-2024, 01:45 AM
            • abhorsen
              Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
              by abhorsen
              Hey guys,
              Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
              Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
              Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
              07-06-2023, 10:22 AM
