Macronix 1.8V serial flash memory
  • blazzelia
    • Nov 2019
    • 40
    • Romania
    Having an Asus FX505DT with a broken BIOS, I pulled the BIOS chip - a Macronix MX25U12873F - to read what's left in it. I noticed the chip is a 1.8V chip while my RaspberryPi provides 3.3V on GPIO lines.
    I also have an USBASP programmer but it supports 5V and 3.3V voltages.
    Any idea on how to safely interface the little guy to one of the readers?
    Thanks,
    B
    • 31259
    Re: Macronix 1.8V serial flash memory
    buy a 1.8v adapter on ebay for a few €
    • blazzelia
      • Nov 2019
      • 40
      • Romania
      Yes, I just did that. I was hoping for a quicker trick... thanks
      • blazzelia
        • Nov 2019
        • 40
        • Romania
        I bought a Pololu level shifter adapter but each time when I read the chip I get a slightly different content (I'm checking using MD5SUM). After 2-3 read operations flashbios no longer see the chip. After a few minutes I can read it again.
        I checked the voltage - 1.85 to 1.9V. Any idea what I am missing?
        Thanks,
        B
        • Duranitron
          • Jul 2014
          • 544
          • Philippines
          Thanks,
          B
          you said its broken bios.. just reflash it with a new bios dump.. for the issue about the 1.8v just buy the 1.8v adapter that will not cost you time, effort and problem because it is proven working for a fraction of $.
          Never stop LEARNING because life never stops TEACHING!
          • Duranitron
            • Jul 2014
            • 544
            • Philippines
            that 1.8v adapter card will convert your existing 3.3v to 1.8v. that will safely reflash your bios.. i use ezp2010 that has no issue with 1.8v eeprom.. i have never destroy a 1.8v eeprom with this programmer and a little experiment.. i read both the dump with 1.8v adapter attached and without it read and program it , the same dump checked both and verify its identical maybe its how it powers the eeprom.. anyways. thats my opinion..
