Macbook A1707 / 820-00281 : May it be useable if U2800 is damaged ?
  • StephE
    • Mar 2019
    • 10
    does anyone know if this board can be used if U2800 is not in perfect condition ?
    Details :
    Left side USB-port(s) / U3200 got killed by bad power supply (short on XB_CC1)
    Receiving line XB_D2R_N<1> (directly to U2800) also damaged.
    Symptoms were : 1 port dead, the other three stayed at 5V/30mA
    U3200 removed, now symptoms are :
    left : 1 port (XA) stays at 5V/0mA
    right : both ports cycling (7 seconds) at 5V/0mA
    As far as i know these boards need all four CD3215C00 working to do anything at all.
    Does anyone know if there is a chance it may be useable (with right side USB working) if U3200 is replaced, as long as U2800 is damaged ?
  • StephE
    • Mar 2019
    • 10
    Re: Macbook A1707 / 820-00281 : May it be useable if U2800 is damaged ?
    Late answer :
    Most likely yes with 820-00821
    Definitely YES with 820-00928
    With all four CD3215 ok and U2800 removed you get a Macbook with two fully working USB-C ports on the right side and two on the left side you can still use to charge the battery.
    (Probably a good idea to protect the two good ones/UB000 from further accidents)
    • XxMicroSoldering
      ASUS Rog Strix G17-712LV Laptop Liquid damaged
      by XxMicroSoldering
      Hello Guys
      I have a ASUS Rog strix laptop that I bought recently to fix and the previous owner spilled water on it . He brought it into a repair shop for them to check it out and instead of fixing it they damaged the battery connector of the laptop ! Other than that they damaged damaged nothing . But since the liquid damage the laptop only turns on and the keyboard lights up and then immediately turns off. I really want to repair this laptop and I also have experience in repairing phones etc and laptops and a bit of soldering but the diagnosing part is where I need help with and...
      10-17-2024, 10:45 AM
    • CG_Dionysos
      MacBook Pro 15-Inch | Mid 2017 | A1707 | 820-00928-A | 3,1 GHz i7, Radeon Pro 560, 16GB, 1TB | Boardview and Schematics
      by CG_Dionysos
      I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:
      • Model: A1707
      • 15-inch, Mid 2017
      • 3.1 GHz Core i7
      • 16 GB RAM
      • Radeon Pro 560
      • 1 TB SSD
      • Board number: 820-00928-A
      I already searched the forum, but so far I haven’t found a matching boardview for this board. In several posts I came across, it was also mentioned that the uploaded files were often incorrect.
      Thanks in advance!
      Greetings from Germany...
      09-16-2025, 06:43 AM
    • Tomylee
      Identification of Component T5 on NEXIQ USB-Link 2 (damaged due to crushing)
      by Tomylee
      I'm currently repairing a NEXIQ USB-Link 2 that was physically damaged due to crushing. After a thorough inspection, it appears that only one component is visibly damaged: the T5 component, located right next to the Mini-USB port.
      It's a 4-pin SMD component, with one pin at each corner, aligned front-to-back along the USB port axis. Unfortunately, it is broken, and there are no visible markings left on the part to identify it.
      I'm looking for help with the following:
      The exact identification or part number of the T5 component
      05-28-2025, 12:42 PM
    • obelix24
      A1707 - No internal display
      by obelix24
      I got two Macbook's Pro 15" A1707 both fully working except no image on internal LCD.
      I've checked and it looks like it's problem with U9850 (on both pin 1 on screen connector is 0.007 or 0.050 in diode mode)
      My question is if this IC can be ordered from Aliexpress (will it work) ?? or it needs to be taken directly from donor (a1707, a1990, a2141) ?
      Is this IC interchangeable (on my board i have 6142E and i found that there can be also HD3SS212) are this chips same ? ? Is it possible to find this IC on some other Macbook 13" (air, pro) ?? i have...
      04-25-2025, 07:55 AM
    • dbuergi
      Macbook A1708 with water damage and problems after removing U2800
      by dbuergi
      i got a A1708 with water damage. I cleaned everything and the board started normal. But the next day i got 20v but no booting. Thermal cam showed over 160c (never had a chip getting this burning hot before) in U2800 and some shorts on the caps around it. After removal shortages were gone and i installed a donor U2800 which worked before.
      Sadly now the device stays at 5v, 0,4a and 1,9w and i don't find the problem.USB ports worked fine before....
      03-17-2025, 06:27 AM
