Macbook A1708 with water damage and problems after removing U2800
  • dbuergi
    • Jul 2024
    • 141
    • Deutschland
    i got a A1708 with water damage. I cleaned everything and the board started normal. But the next day i got 20v but no booting. Thermal cam showed over 160c (never had a chip getting this burning hot before) in U2800 and some shorts on the caps around it. After removal shortages were gone and i installed a donor U2800 which worked before.
    Sadly now the device stays at 5v, 0,4a and 1,9w and i don't find the problem.USB ports worked fine before.
  • Ugur87
    MacBook Air M4 A3240 Brand New Water Damage no Image
    by Ugur87
    I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
    08-28-2025, 01:09 PM
  • Joel Ohana
    Lenovo IdeaPad 3 15IAU7 that suffered water damage
    by Joel Ohana
    I have a Lenovo IdeaPad 3 15IAU7 that suffered water damage. It doesn't turn on (white power light flashes when on button pressed), and the amber light flashes when plugged in.
    Symptoms:
    • Short detected – sparks appear when touching the charging port connection with board with a metal (even a multimeter probe).
    • Visible damage – after cleaning corrosion, I found 4 possibly burnt memory chips near PC3165, labeled UD5, UD6, UD7, and UD8.
    What are my next steps to diagnose and possibly repair it without replacing the entire board? Any guidance would be greatly...
    03-06-2025, 11:25 AM
  • s_henya
    Macbook Air A3114 5V 0.0A after water damage
    by s_henya
    Hi Mac experts :-)
    Im usually not getting too many Mac logic boards repairs, (mostly PC laptops)
    This Mac isn't powering on not boosting to 20v, stays at 5v with 0.0Amps.
    Took out the board and it suffered some water damage, see attached pics.
    All cleaned with IPA but due to long time with corrosion something already got shorted...
    any advice on the below:?
    1. Looking for relatively safe location for voltage injection as all of the caps around that area has 0.0ohms resistance.
    I tried injecting 0.5v on one of the caps...
    08-25-2025, 01:09 PM
  • rtstorm
    HP EliteBook 840 G8 water damage - identify component
    by rtstorm
    Hello, i got an HP EliteBook 840 G8 that has water damage, and i found this component has damage on it U60600. What is that component? I have schematics and boardview and the par no is:
    SINERGY_SYV128RAC_QFN_20P i cannot fount it anywhere. Is this component have some other name?
    Here is schematics + boardview...
    09-18-2024, 05:36 PM
  • TimSinger
    MacBook Pro M4 16" A3403 on the table with water damage
    by TimSinger
    Hi guys,
    I have a MacBook Pro M4 16" A3403 on the table with water damage. I allready found the problem within a bad cap. As far as my researh went, I couldn't find the schematics and boardview for this MacBook model. They seem not to be released now. So my question is if anybody has a working A3403 on the table and could tell me, which specification this capasator has?
    I attached a photo of the missing cap. It's on the bottom side of the logicbard.
    I am very thankful for your replys.
    Thanks in advanced and best regards from Hamburg Germany...
    07-13-2025, 11:12 AM
