need advice for buying a new Programmer
  • eng.jaudat
    • Aug 2016
    • 63
    • Palestine
    i need to buy a new programmer.
    can you please advice me which the best programmer i must have?
  • peste
    • Dec 2016
    • 13043
    • ROMANIA
    Re: need advice for buying a new Programmer
    that's hard to say..depends on how much you use it, and what you want to schedule, and what money you have..etc..the choice is everyone's ..
    • silentbogo
      • Jun 2020
      • 8
      • Ukraine
      Depends on your daily tasks. If, for example, all you need is something that can flash SPI/I2C chips on mainstream electronics, then your best bet is Flashcat USB with some adapters. I've been using an older variant as a daily driver for nearly 5 years. Later got a "Pro" version from devs for a little favor, which was even more solid and flexible. It also does JTAG and NAND (but kinda clunky). All new versions support 1.8/3.3/5V and can do QSPI as well.
      Buspirate is also pretty cool, but I haven't had a chance to play with it personally.
      Both are under $30. Flashcat is available in US, but they do ship worldwide.
      For some serious work you may want to look at TL866-seires programmers. Got me a TL866-II Plus last year, and been using it ever since. The reason I bough it , is because I needed something that can work with old parallel EEPROMs (my friend brought a few LandRover ECUs that needed a bit of work and tweaking).
      There's also a newer T56 version. Supports a ton of various devices with wide range of voltages (including old chips w/ high-voltage programming, and newest 1.2V parts). Everything is automatic, easy to use, and intuitive. I think the most useful feature is pin check before programming, so you won't have to wonder why programming failed or why your chip ended up corrupted.
      If you work on phones and tablets, then it might be a good idea to invest into a decent dedicated EMMC/UFS programmer. I don't use one, so I can't really tell you much about those.
      • qayyum786
        • Aug 2018
        • 1933
        • INDIA
        SVOD 3 is the best programmer wich is support almost all chip and SIO ec bios
        without any trouble
        • jasko_jacker
          • Oct 2014
          • 1137
          • italy
          Only for bios, I use EZP2010, many say it is not recommended (I don't understand why). Personally I have programmed hundreds of bios without any problem, even the low voltage ones. For the EC I use a vertyanov (the old version) and except with some ITE (often the error depends on the bios installed) also with this I have not had problems.
          • silentbogo
            • Jun 2020
            • 8
            • Ukraine
            It boils down to quality and "best bang for the buck".
            Here's a quick snips of the internals (there are more equally crappy versions of this, but that's the only one I found):
            Basically, if you ignore that dubious "offline copy" feature, it doesn't do anything that you can't accomplish with a $2.50-$3.00 CH341 programmer.
            It doesn't have proper TTL control : only drops VCC/RST to a ballpark of 3.3V (whatever Vdrop on that diode and tranistors, basically), and the rest is handled by current-limiting resistors on data lines, which is not good...
            Basically it's the bottom of the barrel, but costs almost as much as a semi-decent serial programmer.
            I mean, if you already have it - you can make it work. For example, you can mod the 1.8V adapter to do all voltages w/ proper TTL conversion on I/O, disintegrate that questionable diode and replace it with an LDO etc.
            But as a new purchase ...
            • jasko_jacker
              • Oct 2014
              • 1137
              • italy
              It's an old story the same as for example the hantek 6222BL oscilloscope / logic analyzer VS saleae logic analyzer same controller prices are remarkably different, both very limited, but if you have to check a clock they are more than good. But what is the most important thing? for me it is that it does its job, and it does (unsoldered bios chips, not reliable with chips in place) and it costs 10/14 Euros (EZP2010 old model not new models that I don't know)
              For me it all depends on the type of use, in the end the bios chips are always the same with some exceptions.
              • RethoricalCheese
                • Mar 2013
                • 1519
                • Estonia
                I still find Raspberry Pi to be the most reliable programmer when it comes to only programming bios chips. For 1.8V and/or WSON8 I use adapters. For 3V3 soic8 I just use clip and 99% time program on-board without problems.
                Raspberry Pi Zero and Zero W are very cheap (used to be 5€ and 10€). Havent seen a bios chip which was unsupported. Only downside is that since it is not a true programmer, it is not that convenient to use (I need to transfer files between windows PC and raspberry). Plus raspbian and CLI might scare some people
                But it has made automation possible. Instead of unlocking 1 HP in an hour or so I can now unlock most models in just a few seconds and thus far without an issue.
                With CH341A, MiniPro, SmartProg2 and EasyJtag and others I have had reliability issues sooner or later.
                • urad29
                  BIOS Programming - Which programmer to use??
                  by urad29
                  I have done quite a lot of research into which programmer to use and despite me thinking that there should be quite a lot of documentation on this subject there is relatively little.
                  I am looking for a programmer for laptop EC chips (SMD and BGA).
                  I do have some knowledge in programming as I have used the CH341a for BIOS chips.
                  I am looking into the RT809H or F.
                  Despite there being a list of which chips the RT809 supports, it seems that there are videos of people using it for chips not on that list.
                  I guess I would like a programmer that can program...
                  08-10-2023, 03:53 AM
                • Sparklingx
                  Everyone is buying the wrong CH341 programmer
                  by Sparklingx
                  Everyone is buying the wrong CH341A programmer, I have learned from my mistake. Don't buy the Black one or Green one.
                  Buy this one in the photo. Most stable and all your common problems (reading but not writing/erasing, software hanging, disconnects after attaching chip, test cable connected but chip not found/ device disconnected) will be gone.
                  Otherwise you'll have to solder capacitor from GND to VCC if you have those symptoms in your black or green miniprogrammer....
                  09-11-2024, 02:03 PM
                • bohaboha
                  ADVICE FOR BUYING A DIGITAL MICROSCOPE
                  by bohaboha
                  Hi I'm thinking of buying this :1080P 4K HD Industrial Microscope 150X C-Mount Lens 48MP/13MP Digital Camera HDMI USB-C VGA Measurement For PCB Soldering DIY it's on ALiExpress : https://www.aliexpress.com/item/1005...av-description
                  the one i choose is the D full Set
                  maybe you can advise me or maybe someone who has similar who can give feedback on it very grateful for...
                  02-24-2025, 07:13 PM
                • bohaboha
                  Buying some single smd led diode for tv repair, your advice needed
                  by bohaboha
                  I'm thinking of buying some single smd led diode for tv repair to have under hand there is so many, 2835 k-6000k 9v.6v, 3v white etc but don't know which to have if you advise me which Should I buy and which is most usual and bäst to have under hand. thank you
                  03-28-2024, 02:00 PM
                • Hondaman
                  Windows 11 buying advice needed
                  by Hondaman
                  My mother may soon need to upgrade from Win7 (to continue safe browsing, e-mail, and office tasks, without a printer). Right now, she uses an Intel Core2Quad 9550 CPU (not sure of motherboard). Video is either the Radeon 6670 or 6770, completely air-cooled, with fins like a motorcycle engine (I think I pointed a 120mm fan at it). PSU is probably Seasonic, still running after 14 years (I choose quality). I am not sure of the RAM, or the PCI-e wifi chip. Probably 8 GB or 16 GB. Perfect for WIndows 7.
                  She does not want to switch to Linux. And she does not want to use a laptop because...
                  04-14-2025, 11:35 PM
