BIOS Programming - Which programmer to use??
  • urad29
    • Dec 2021
    • 11
    I have done quite a lot of research into which programmer to use and despite me thinking that there should be quite a lot of documentation on this subject there is relatively little.
    I am looking for a programmer for laptop EC chips (SMD and BGA).
    I do have some knowledge in programming as I have used the CH341a for BIOS chips.
    I am looking into the RT809H or F.
    Despite there being a list of which chips the RT809 supports, it seems that there are videos of people using it for chips not on that list.
    I guess I would like a programmer that can program basically all laptop EC chips for a decent price.
    Is the RT809 good for this or should I look at something else?
    Thanks in advance for all your help.
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: BIOS Programming - Which programmer to use??
    RT809 series are not really EC programmers. They do support some EC but support is not that great and undocumented, you won't find much help on the Internet and you will probably encounter issues with no explanations. It's more like if you already have it you can try, but I'd not recommend buying one for this purpose.
    I have personally not been successful in talking with MEC5075 with an RT809F even though it's in the support list. (I confirmed the EC is talking properly over JTAG with a JTAG probe).
    It did work fine with some ITE like IT8987E, but RT809F requires the PEB-1 extension kit (RT809H does not need it).
    If you want the best support for ECs with the least trouble you'll need an SVOD4. Of course it's more expensive and harder to get.
    • urad29
      • Dec 2021
      • 11
      Thank you very much for your very informative answer.
      Is there a major difference between svod3 and svod4?
      If so, what are they?
      • reformatt
        • Feb 2020
        • 1472
        SVOD3 isn't available from their store anymore, only SVOD4. No info from them about any new features, but you'd assume it's using easier to source components, faster etc. Just a natural progression.
        The software interface is pretty straightforward I find, just documentation and support from them is a little lacking.
        • macabook
          by macabook
          🧩 Initial Issue
          07-24-2025, 02:17 PM
        • zlr8r
          looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
          by zlr8r
          looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
          cheers
          Dell Inspiron 17 (7786) Laptop
          Service Tag: 5J0NHT2
          Bios: 1.9.0
          MOBO: RO 15 17 WHL 2GB MB / 18706-2
          Attached;
          1. My saved bios using a programmer
          2. Dells Bios updater .exe (v1.16)
          3. Dells Bios recovery file
          4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
          5. Image of ME...
          12-18-2023, 03:08 PM
          by Vesko356
          08-11-2023, 03:27 AM
          Common SPI bios chip programming Questions and Answers
          by SMDFlea
          Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
          A: If you can`t read from it how do you expect to write to it ?.
          Q: Why is my bios chip unreadable ?.
          A: The programmer is faulty or has a worn or broken zif socket.
          The USB cable is frayed,connector pins worn or some other physical damage.
          Not enough amperage or voltage to power the programmer properly.
          Bad...
          09-02-2021, 04:40 PM
        • what_1282105
          Thinkpad t480s, completely dead after BIOS flash using CH341A programmer
          by what_1282105
          Following this guide (https://www.reddit.com/r/thinkpad/co...g_and_flashing) i re-flashed my t480s BIOS using an external (CH341A) programmer. The flash didnt work, so i reverted back to my BIOS backup successfully. The BIOS in the chip and the BIOS backup file are identical according to windows' file compare. The revert, however, didnt work: the only thing the computer does is flash the power button 3 times when AC power is connected. I've tried unplugging the CMOS battery, holding the reset button and holding down the power button- no signs of life....
          02-14-2025, 07:27 PM
