I need helo on this lenovo b470 core i5 nvidia laptop, the problem is turns on only if battery only plugged in but if both battery and charger plugged in cannot turn on and also if charger only plugged in cannot turn on also. anyone can help on this please
					lenovo b470 turns on only on battery
	Tags: None
 Re: lenovo b470 turns on only on battery
 i cannot find a schematic on this model, but i made a measurement with charger only plugged in on the ic BQ24745 base on datasheet pin3 VREF=2.5V pin2 ACIN=19v pin13 ACOK =3.3v but pin21 LGATE = 0vComment
 ok thanks as post#3 ive mentioned above some readings on pu4001 pinsComment
 @mielta sorry for the late response. here is the pu4001 all pins with charger only plugged in measurement
 pin1=0v
 pin2=2.6v
 pin3=3.3v
 pin4=0v
 pin5=0v
 pin6=0v
 pin7=0v
 pin8=0v
 pin9=3.3v
 pin10=3.3v
 pin11=3.3v
 pin12=0v
 pin13=3.3v
 pin14=0v
 pin15=0v
 pin16=0v
 pin17=0v
 pin18=0v
 pin19=0v
 pin20=0v
 pin21=0v
 pin22=19v
 pin23=0v
 pin24=0v
 pin25=0v
 pin26=3.3v
 pin27=0v
 pin28=19vComment
 here is the measurement both battery and charger plugged in
 pin1=0v
 pin2=2.6v
 pin3=3.3v
 pin4=0v
 pin5=0v
 pin6=0v
 pin7=0v
 pin8=0v
 pin9=3.2v
 pin10=3.2v
 pin11=3.3v
 pin12=0v
 pin13=3.3v
 pin14=0v
 pin15=11.08v
 pin16=11v
 pin17=11v
 pin18=11v
 pin19=0v
 pin20=2.2v
 pin21=6v
 pin22=18.6v
 pin23=12v
 pin24=15.6v
 pin25=18.6v
 pin26=3.3v
 pin27=19v
 pin28=19vComment
			by ZentechI got a Lenovo Thinkcentre MT-3218 that when I plug the power cord, the computer turns on. The power button seems to work just fine. When I press it the computer turns off, and when I press it again, it comes back on. But when I unplug the power, and plug it back again, it turns the computer on... does anyone have an idea what might be causing this strange behavior. Could this be the power supply or a bad contact on the power button?
 thanks
 PS: everything else on the computer works fine
			by coasterghostFor Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
 Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
 Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
 System Hardware:
 Processor: AMD Ryzen 7 PRO 5850U
 Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...09-08-2025, 10:46 PM
			by twonk9098Hi all,
 I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
 I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
 I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
 I have tried a few new bios but exactly...
			by keepreadI've been using this laptop for quite some time w/o battery. It has Linux installed. Recently, someone sent me a web link in an instant messenger. When I clicked on that link the laptop turned off that instant, before the browser even loaded to open it. Since then it turns off several seconds after I start it up and log into the Linux graphical desktop. I can see the mouse cursor moving around the screen when I draw my finger on the touchpad or move the mouse, and then a terminal window begins to load because the desktop autostarts it from last time, and then I hear a pop from the speakers and...
			by zatara10lenovo B580 change wifi card after this error "unauthorized wireless network card is plugged in. power off and remove it"
 bios dump attached...-
							Channel: BIOS Requests ONLY!
- Loading...
