lenovo b470 turns on only on battery
  • String2016
    • Nov 2015
    • 2230
    • philippines
    I need helo on this lenovo b470 core i5 nvidia laptop, the problem is turns on only if battery only plugged in but if both battery and charger plugged in cannot turn on and also if charger only plugged in cannot turn on also. anyone can help on this please
  • qayyum786
    • Aug 2018
    • 1933
    • INDIA
    Re: lenovo b470 turns on only on battery
    Send schematic and voltage details of charging ic pins
    • String2016
      • Nov 2015
      • 2230
      • philippines
      i cannot find a schematic on this model, but i made a measurement with charger only plugged in on the ic BQ24745 base on datasheet pin3 VREF=2.5V pin2 ACIN=19v pin13 ACOK =3.3v but pin21 LGATE = 0v
      • mielta
        • Apr 2015
        • 368
        write the name of the motherboard for the right schematic
        • String2016
          • Nov 2015
          • 2230
          • philippines
          on the main board i cannot find the markings of the board id but on the other board which connected to usb it has mark 48.4kz02.021. I have attached the photo
          • mielta
            • Apr 2015
            • 368
            I Have the schematic uploaded under Schematic-Forum search after B470
            Put only AC adapter and then messure at Pu4001 voltage
            • String2016
              • Nov 2015
              • 2230
              • philippines
              ok thanks as post#3 ive mentioned above some readings on pu4001 pins
              • String2016
                • Nov 2015
                • 2230
                • philippines
                @mielta sorry for the late response. here is the pu4001 all pins with charger only plugged in measurement
                pin1=0v
                pin2=2.6v
                pin3=3.3v
                pin4=0v
                pin5=0v
                pin6=0v
                pin7=0v
                pin8=0v
                pin9=3.3v
                pin10=3.3v
                pin11=3.3v
                pin12=0v
                pin13=3.3v
                pin14=0v
                pin15=0v
                pin16=0v
                pin17=0v
                pin18=0v
                pin19=0v
                pin20=0v
                pin21=0v
                pin22=19v
                pin23=0v
                pin24=0v
                pin25=0v
                pin26=3.3v
                pin27=0v
                pin28=19v
                • String2016
                  • Nov 2015
                  • 2230
                  • philippines
                  anyone can help this please
                  • qayyum786
                    • Aug 2018
                    • 1933
                    • INDIA
                    Send clear picture near charging i.c side (bq24745)
                    and dcin connector side
                    please remove the cable from dc jack
                    • qayyum786
                      • Aug 2018
                      • 1933
                      • INDIA
                      Upload clear image from marked area
                      parts number not so clear
                      • String2016
                        • Nov 2015
                        • 2230
                        • philippines
                        @qayyum786 here it is the pic
                        • qayyum786
                          • Aug 2018
                          • 1933
                          • INDIA
                          Connect battery and chatger both
                          than check voltages On BQ24745
                          • String2016
                            • Nov 2015
                            • 2230
                            • philippines
                            • qayyum786
                              • Aug 2018
                              • 1933
                              • INDIA
                              • String2016
                                • Nov 2015
                                • 2230
                                • philippines
                                here is the measurement both battery and charger plugged in
                                pin1=0v
                                pin2=2.6v
                                pin3=3.3v
                                pin4=0v
                                pin5=0v
                                pin6=0v
                                pin7=0v
                                pin8=0v
                                pin9=3.2v
                                pin10=3.2v
                                pin11=3.3v
                                pin12=0v
                                pin13=3.3v
                                pin14=0v
                                pin15=11.08v
                                pin16=11v
                                pin17=11v
                                pin18=11v
                                pin19=0v
                                pin20=2.2v
                                pin21=6v
                                pin22=18.6v
                                pin23=12v
                                pin24=15.6v
                                pin25=18.6v
                                pin26=3.3v
                                pin27=19v
                                pin28=19v
                                • qayyum786
                                  • Aug 2018
                                  • 1933
                                  • INDIA
                                  Did yiu replace the bq ic ?
                                  • qayyum786
                                    • Aug 2018
                                    • 1933
                                    • INDIA
                                    REMOVE PQ4002 and check for voltage
                                    On pin NO:- 7 = ?
                                    • String2016
                                      • Nov 2015
                                      • 2230
                                      • philippines
                                      i did not replaced the ic i just reflowed the chip
                                      • qayyum786
                                        • Aug 2018
                                        • 1933
                                        • INDIA
                                        Follow #18 & reply
