Macbook Pro A1706 doesn't power on
  • miro.manchev
    • Nov 2018
    • 15
    • Bulgaria
    Hi, my own laptop died. One morning it doesn't start up. No charging, nothing. I've opened it, found the boardview and schematic, here in the forum. So I was able to trace some power lines.
    I know about the Enable power line for USB-C chips so my PP3V3_G3H is 3.3V and seems fine. Then I saw that PPBUS_G3H is very low, about 0,51V. After some tracing on the board, I found short on PP3V3_UPC_XB_LDO, which is near one of the CD3215C00. Firstly I saw a ceramic cap ( C3208), that looked a bit blackish, so I've unsolder it, but the short remained. So, do you think if I replace CD3215C00 it may work? it's U3200 on the schematic I believe.
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Macbook Pro A1706 doesn't power on
    Did you check voltage&current on USB-C ammeter? I guess you have 5V on DC-in?
    There's still C2890 and U2890 on PP3V3_UPC_XB_LDO, very unlikely to be the problem but still confirm they are not causing the short.
    It looks like your CD3215C00 are underfilled so they'll be a pain to remove and replace. If you don't have experience with underfilled BGA chips I'd recommend having someone who does have experience do the job. Or at the very least practice on donor boards beforehand.
    • miro.manchev
      • Nov 2018
      • 15
      • Bulgaria
      Unfortunatelly I don't have an USB-C volt and ampermeter. I've ordered one, but I couldn't wait it to arrive, so I used only my multimeter. The CD3215 look like glued or something, and my idea was to bring it to someone experienced in BGA soldering, I cannot risk ruin the board, as my data is still there I put an image showing clearer the chip's base.
      • Weelcup
        TopTech
        • Oct 2017
        • 307
        You can clean it with isopropyl alcohol 99% not white spirit.
        And see.
        Was there any waterdamage ?
        • piernov
          • Jan 2016
          • 4439
          • France
          There's no sign of liquid damage, LDI are not triggered and CD3215 themselves won't get directly damaged by liquid since they are underfilled. So I assume no liquid damage.
          A knockoff AC adapter could've been the cause of it dying, but sometimes it can die randomly too.
          Since this is not a T2 Macbook, the data itself can still be rescued from the Lifeboat connector. If you really worry about losing data, you should find someone with the equipment to hook up to that connector and save the data before working on the board. And always make frequent backups.
          • miro.manchev
            • Nov 2018
            • 15
            • Bulgaria
            There is no liquid damage, and I never used a knockoff adapter. I have 2 genuine Apple AC adapter, but one of the USB-C cables started to make bad contact, not sure if that can cause the chip burn out. I have some backup's, so I can try to save the board, and even something happens, nothing major will be lost.
            P.S. I took a closer look and I'm not sure that this BGA is underfiled. I cannot see epoxy on the edges.
            • miro.manchev
              • Nov 2018
              • 15
              • Bulgaria
              The CD3215 finally arrived and I gave it to a workshop to reball it. It was replaced, but the laptop is still dead. The short on PP3V3_UPC_XB_LDO is gone and there is 3.3V now there.
              I saw that the PPBUS_G3H is not present, but it's not shorted. It behaves strangely, varies from 750k to ~ 400k but while measuring it's dropping instead of rising. So I focused on D6902 diode.
              D6902 diode pinout:
              - 1. PPBUS_G3H 300mV 400-750kOhm
              - 2. PPDCIN_G3H_CHGR 5.2V
              -3. PPVIN_G3H_P3V3G3H 4.8V
              The laptop is consuming 5.20V and about 0.03-0.05A on the USB meter.
              I measured the double diode, and seems fine 0,5V on the anodes while measuring diode on the multimeter, and 0 if I change the polarity of the probes.
              I'm really stuck now, and have no idea what to check now? Any help will be apreciated.
              Regards
              • piernov
                • Jan 2016
                • 4439
                • France
                R6907 is the resistor that feeds the PP3V3_G3H regulator circuit when on battery. It is not relevant here, PP3V3_G3H will be fed directly from the AC adapter through R6902.
                If the ammeter is still stuck at 5V, you have to check the voltage on PP3V3_G3H again and all the LDO outputs of all the CD3215C00.
                • Weelcup
                  TopTech
                  • Oct 2017
                  • 307
                  D6902 diode pinout:
                  Regards
                  Did you disconnect the battery and get this 5v on the metre? If so then i would still suspect the usbc chip (the CD3215 chip) circuit.
                  Check the 1M ohm resistors on around all the CD3215 chips.
                  In general, check all CD3215 feeding resistors values. I would suspect a defected resistor as the value on the metre should be 20v.
                  However, it is very very important to use a high wattage 87w like usbc charger before you go with anything else. Very possible charger defect (adapter or cable) issue might lead to 5v instead of 20v
                  • miro.manchev
                    • Nov 2018
                    • 15
                    • Bulgaria
                    I have 3 original 61W usb-c apple chargers. I have another macbook pro and I verified they are working well, and also tested the usb-c meter working fine. The battery is disconnected and never put back while diagnostic work. I bought the CD3215C00 from ebay, so I can suspect bad chip, or bad reflow work as I cannot be 100% sure it was done properly. But the short is gone and there is 3.3V there now. As I can see from this power rail name PPVIN_G3H_P3V3G3H
                    isn't 4.8V voltage too high?
                    Will a new CD3215C00 work right a way, without any needs of coding?
                    I will check all resistors and LDO outputs on all CD3215C00.
                    Regards
                    • piernov
                      • Jan 2016
                      • 4439
                      • France
                      PPVIN_G3H_P3V3G3H is the input voltage for PP3V3_G3H regulator as the name suggests. Voltage is brought down to 3.3V by the regulator so PP3V3_G3H should mesure 3.3V.
                      CD3215C00 are custom chips pre-programmed for Apple, they most likely are not "new" but rather pulled from donor boards. As long as the revision C00 matches with all the other chips it's good.
                      • Weelcup
                        TopTech
                        • Oct 2017
                        • 307
                        Regards
                        Great!,
                        As much as you guarantee the charger itself then we passed it.
                        Now, just to be clear. If a SINGLE CD3215 on the board is defective, NONE OF THE OTHERS WILL WORK!
                        I mean all would show 5v on metre when you connect the charger to.
                        So try to see if the G3H_P3V3G3H 3.3v is present when you connect the charger to the other usbc ports one by one.
                        However, do should do resistors checks that mentioned before.. make sure the 1M ohms are not reading higher resistance...
                        For now ignore the PPVIN 4.8v.
                        Also check if the metre is reading higher amps when connected to the other ports.
                        Like "piernov" mentioned this exact model chip is pre programmed and if not working then it is highly likely defected or bad soldering.
                        • miro.manchev
                          • Nov 2018
                          • 15
                          • Bulgaria
                          There are some strange things going on. The usb-c meter recognize 5V only from one of the sides, and on one of the usb-c there is interupts after about 10s, goes to 0V and then again 5.2V. On the second port it works without flickering. The other side stays dead. I'm pretty sure it was working too, before I put the mother board inside the laptop. There are no other ribbon cables connected, just the USBs. I will put the board out againg and check, if I there is some bad connection to this side ports. P3V3_G3H is present and it's 3.3-3.4V. The 1mOhm resitors are between 650k-800k, I've check the others near CD3215C00, some 15k and 2,2k and looks fine on the multimeter.
                          • Weelcup
                            TopTech
                            • Oct 2017
                            • 307
                            If all the resistors are ok. Then one of the CD3215's is faulty. lt might be the one that is cutting the power that you just mentioned..
                            • miro.manchev
                              • Nov 2018
                              • 15
                              • Bulgaria
                              Any idea from where to source a good CD3215C00? I bought one from ebay, but I cannot be sure it was ok. However, the one cutting the power is different from the one that was changed.
                              • Weelcup
                                TopTech
                                • Oct 2017
                                • 307
                                As mentioned above, it is very unlikely to find new ones. And any one online would have been taken from donor boards.
                                However, i personally order such chips from ebay too but from a chinese source.. i had not have any issues with any chip that i ordered from so far ( since 2017 ).
                                https://www.ebay.com/itm/202621291250
                                But it might take some time to get it delivered during this pandemic period.
                                • philipjhart
                                  • May 2020
                                  • United Kingdom
                                  Do you have a link to the forum where you found the board view & schematic?
                                  Newbie here, so still trying to figure how BadCaps works!
                                  Cheers,
                                  Philip
                                  • Weelcup
                                    TopTech
                                    • Oct 2017
                                    • 307
                                    Cheers,
                                    Philip
                                    You can find it here.
                                    This is for A1706 touchbar model.
                                    820-00239-A
                                    https://www.badcaps.net/forum/showthread.php?t=63867
                                    Goodluck.
                                    • miro.manchev
                                      • Nov 2018
                                      • 15
                                      • Bulgaria
                                      This is a video how the 4 USB-C behave. Only one is not boot looping, and the rest are. However, the one that doesn't boot loo, at some point the Amparage drops to 0 and then rises again to 40-50mA, looping in it's own way. I'm not sure what to meassure now, and how much CD3215 to order and replace...
                                      https://www.youtube.com/watch?v=ONSX6iLbgIY
                                      • miro.manchev
                                        • Nov 2018
                                        • 15
                                        • Bulgaria
                                        Could it be something with thunderbolt RAMs ?
                                        • Danielreinaa
                                          HELP need password bios Macbook A1706
                                          by Danielreinaa
                                          Hola chicos, espero estén bien, he estado buscando información para aprender a hacer eliminación de password EFI en macbooks.
                                          Actualmente tengo un problema con una macbook pro A1706 820-00923 SN:C02VD3GJHV2Q
                                          Si podrian ayudarme les agradeceria mucho o algun link para aprender a hacerlo y no volver a molestarles.
                                          gracias de antemano y que tengan una linda tarde, disculpen si estoy rompiendo alguna norma.
                                          Hi guys, I hope you are doing well, I have been looking for information to learn how to remove the EFI password on macbooks.
                                          09-07-2024, 03:47 PM
                                        • capon5153
                                          Macbook A1706 works perfectly but no data on USB C
                                          by capon5153
                                          hello,
                                          so i have an macbook pro A1706, motherboard 820-00923, everything works and it does charge without a problem but when i plug anything to the usb c it doesnt do anything, it doesnt give 5V on usb drive or any other peripheral,
                                          i have opened the macbook and i can see some little corrosion on C7601 and C6950,, i have cleaned it and i measure 15v on C6950 PPVBAT_G3H_CONN
                                          06-22-2025, 09:42 AM
                                        • B2L_Repairs
                                          Macbook A1706 touchpad and keyboard not working. Please help
                                          by B2L_Repairs
                                          Hi guys i am new to macbook repairs (i mostly do microsoldering on iphones and android devices. I need your assistance with macbook a1706 (touchbar edition) that came in without touchpad and keyboard functionality. External keyboard and mouse does work but the keyboard and touchpad on the macbook does not work. I changed the touchpad flex, also replaced the touchpad but the issue persisted. I then measured voltage on the board and found that PIN 44-50 of the touchpad connector (J4501) got 11.2V instead of 12.6V. Those pins required 12.6v and they get their 12.6v from PPVIN_S4-TPAD_FUSE . I measure...
                                          10-09-2023, 04:56 AM
                                        • johnbeton
                                          Macbook Pro A1706 820-00923 no power after replacing top cover and keyboard
                                          by johnbeton
                                          I have a A1706 with 820-00923-A board. The laptop came in with non-working keyboard. I bought a new top-cover with keyboard and transfered everything to the new topcover.
                                          Since then the macbook will not charge or power-up. Before replacing top cover, I started the macbook to test, and it worked fine apart from keyboard. Then shut it down and did replacement.
                                          This is what I measure so far:
                                          Resistance from F7000 to ground is 123 Ohm on pin 1 and 2
                                          PPBUS_G3H = 0,79v
                                          PPBUS_HS_CPU = 0,79v
                                          PPBUS_HS_OTH5V = 0,79v
                                          PPBUS_HS_OTH3V3...
                                          05-21-2024, 02:06 PM
                                        • envym
                                          MacBook Pro 2018 with Activation Lock
                                          by envym
                                          Hi everyone!
                                          I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                                          I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                                          06-27-2025, 08:54 AM
