Macbook no life a1278 board 820-2327
  • stevieh2o
    • Dec 2012
    • 28
    have an old macbook showing no signs of live
    magsafe lights up green then turns to orange
    iv got the schematics and did some testing but cant see whats at fault, can anyone help me?
    i tested along the pp3v42_g3h
    u6990 and got
    1 -15.5v
    2 unconnected
    3 15.5v
    4 ground
    5- 3.4v
    6-6.7v
    7-3.4v
    8-1.23v
    c6995 3.39v
    r6995 3.39v
    c6999 3.39v
    c4650 and got 3.4v
    r4650 and got 3.4v
    u5403 pin 3 3.39v pin 4 12.45v pin 5 12.45v
    c7046 pin 1 2v pin 2 got 12.45v
    r7047 pin 1 12.45v pin 2 12.45v
    r7031 pin 1 12.45v pin 2 12.45v
    c7041 pin 1 5v pin 2 ground
    c7040 pin 1 5v and pin 2 ground
    r7010 pin 1 16.5v pin 2 3.9v and 29.6kohms
    can someone point me in the right direction...
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Macbook no life a1278 board 820-2327
    List power rails instead of random parts on the board.
    Also you say you have green light so it's useless to check the parts that are responsible for it.
    And you haven't described the symptoms (fan doesn't start spin after pressing power button? no chime? no image? etc…) or the history of the board.
    • disorder
      • Sep 2015
      • 154
      • france
      hi
      take the schematics, look at power rails list and test all of them one by one untill you find one not corresponding tell us.
      then you'll have to check which component could cause the line not working : first check if you have short with diode mode.
      • MobileXT
        • Oct 2012
        • 196
        what is voltage on PPBUS_G3H without the battery?
        • stevieh2o
          • Dec 2012
          • 28
          checked the ppbus_g3h 2.7v at r7801
          • stevieh2o
            • Dec 2012
            • 28
            No fanspin no signs of live at all
            No water damage etc
            Wouldnt switch on a few months ago so i opened it up and got it going using the powerpads. worked for a few months now dead again.
            • stevieh2o
              • Dec 2012
              • 28
              3.3v at PP3V3_S5
              No power getting to PP5VRT_S0 at r 9302
              • MobileXT
                • Oct 2012
                • 196
                your PPBus_G3H is low suppose to be 12.54v check that power rail. I'm guessing you have a PP3V42_g3H present.
                • piernov
                  • Jan 2016
                  • 4435
                  • France
                  It is not possible to have 3.3V on PP3V3_S5 when PPBUS_G3H is 2.7V. Please double check your readings.
                  Also note that R7801 has nothing to do with PPBUS_G3H.
                  • Adogabriel100
                    Macbook A1278 (820-2936) No power. missing SMC_BC_ACOK
                    by Adogabriel100
                    Hey! This is a A1278 macbook 2011.
                    Problem: Not turning on / No green light
                    Im using by3200s charger.
                    Voltajes:
                    PPBUS_G3H = 12.26v
                    SMC_RESET_L = 3.3v
                    PP3V42_G3H = 3.42v
                    U7000 =
                    Pin 1 CHGR_AGATE = 0v
                    Pin 2 CHRG_DCIN = 19v
                    Pin 3 CHRG_ACIN = 4.6v
                    Pin 10 SMBUS_SMC_BSA_SDA = 3.3V
                    Pin 11 SMBUS_SMC_BSA_SCL = 3.3V
                    Pin 12 PP3V42_G3H = 3.42v
                    Pin 13 CHRG_RST_L = 3.3V
                    Pin 14 SMC_BC_ACOK = 0.8V
                    Pin 19 PP5V1_CHRG_VDD = 5.05V
                    Pin 20 PP5V1_CHRG_VDDP = 5.03V...
                    04-01-2024, 01:02 PM
                  • Rezendes
                    Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
                    by Rezendes
                    Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
                    I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
                    The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
                    05-10-2024, 02:18 PM
                  • pcbmaniac
                    MacBook A1278 (3115) No PPBUS_G3H Issue
                    by pcbmaniac
                    Subject: Help Needed: MacBook A1278 (3115) No PPBUS_G3H Issue
                    I'm working on a MacBook A1278 with the 3115 logic board and facing an issue with no PPBUS_G3H voltage. Here's what I've checked so far:
                    1. U7000 Measurements:
                      • Pin 3 has 0V, even though R7012 shows 16.5V from PPDCIN_S5_CHGR.
                    2. Resistors:
                      • I measured R7010 and R7011 with one leg disconnected, and both tested OK.
                    Based on these findings, I believe U7000 needs to be replaced. However, I have a related question:
                    • If I also decide to replace the SMC, do I need to order it pre-programmed,
                    12-02-2024, 04:12 PM
                  • envym
                    by envym
                    Hi everyone!
                    06-27-2025, 08:54 AM
                    Apple MacBook A1278 051-7918 820-2327 Schematic
                    M97A MLB Rev C...
                    11-01-2024, 06:53 AM
