Macbook air 820 - 00165 turn on, when arrive at the User password turn off
  • xalapamac
    • Aug 2017
    • 36
    • Mexico
    I'm lost, where do I start looking for the fault?
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: Macbook air 820 - 00165 turn on, when arrive at the User password turn off
    Try another SSD or disconnected internal SSD and boot on external drive with macOS.
    • xalapamac
      • Aug 2017
      • 36
      • Mexico
      Change the SSD on the other, and it does exactly the same.
      • xalapamac
        • Aug 2017
        • 36
        • Mexico
        The macbook turns on perfectly, which makes me think that all internal voltage values work correctly. Otherwise I wouldn't turn on. PPG3H, PP3v32, etc... It runs the operating system without any problem, the apple appears, the password screen appears and 7 seconds later it shuts down.
        Piernov, So you do the macbook, you consider it a software problem or hardware?
        • disorder
          • Sep 2015
          • 156
          • france
          hi
          take a lamp and look your screen with it at apple logo appears
          i think that when the backlight goes off, u will see the picture for about some seconds then the picture will off too
          if so tell me and i 'll tell u what's wrong !
          • xalapamac
            • Aug 2017
            • 36
            • Mexico
            Disolder:
            Macbook is completely shut down. Not only backlight. It lose all the image completely. The macbook dies after arriving at the user screen. 7 seconds on the user screen, and then die.
            Read recommendations, guys
            • magneh
              • Apr 2014
              • 596
              • Portugal
              Have you tried the built in diagnostics?
              ASD pass with no errors?
              most likely sensor issue.
              That shut down sound to me like temperature related most likely.
              Is the CPU too hot when you touch it?
              What is the history of the logic board? liquid damaged?
              what have you done to it?
              • crazeej
                • Jan 2019
                • 32
                • germany
                Check for corrosion around the ram and cpu mosfet area.
                • disorder
                  • Sep 2015
                  • 156
                  • france
                  so, u don't answer me.
                  i think you have a faulty lid sensor.
                  first chack with another I/O board if u have
                  if not look at lid sensor on I/O board, maybe corroded ?
                  • Dumah Brazorf
                    • Jun 2013
                    • 179
                    • Italy
                    If you can restart it immediately and it does the thing again and again and again it could not be a heat or power related issue.
                    If you remove the disk so it stops at the boot screen does it stay on?
                    • MobileXT
                      • Oct 2012
                      • 202
                      Check the resistor R7122 and R7121 they should be 10 ohms.
                      • Instafixx
                        Macbook A1466 820-00165 will not turn on after shut down
                        by Instafixx
                        Namaste,
                        I have a Macbook A1466 820-00165 which has come with erratic issues. it reboots. Trackpad doesnt work. Doesnt Turn on etc.
                        Upon inspection
                        Corrosion at the Trackpad - changed that to check.
                        Some Keys including Power Key and Arrow Keys dont work on the keyboard.
                        Wifi Stick Corroded - Changed to Check..
                        Corrosion under U3540. Removed and Reballed.
                        Now
                        The Macbook turns on when plugged to the charger but if we shut it down, it wont turn on when charger connected. Have to remove and install the battery....
                        04-17-2023, 01:53 AM
                      • Ryan.man
                        by Ryan.man
                        02-04-2025, 12:23 PM
                      • mferna14
                        Password removal on MacBook Pro A2159
                        by mferna14
                        Hi friends., I am working on MacBook Pro A2159 touchbar 2019. The old logic board was liquid spilled so I ordered another logic board from AE. Received it & all worked fine till I got to the Chinese login screen where the login screen password tobe entered. I tried to reset the password but it again gave me options which I do not know about the Apple ID. I formatted the onboard SSD. & wanted to change the startup boot sequence but in order to change it, again the password is needed for that too. Is there a way to get rid of this password?? The seller has not replied back past 2 days, how...
                        05-13-2025, 04:16 PM
                      • ritalo
                        MacBook Air 13 2014 - Remove EFI password
                        by ritalo
                        I have a MacBook Air 13 inches 2014.
                        I have set a EFI password and I can't remember it : now I want to reinstall macOS and I can't because the MacBook is asking for the password.
                        I know how to remove the password with a usb programmer.
                        I plug the usb programmer to the motherboard and to my pc with usb, I read the EFI and I save it to a file.
                        Then I have to find this value in the file : $SVS because it indicate where is the password.
                        But I can't find the value.
                        I have attached the file​
                        Thank...
                        05-14-2024, 12:10 PM
                      • Okrutnik
                        Macbook A1466 820-00165-A - wont turn on
                        by Okrutnik
                        I'm having issue with this macbook. No liquid or corrosion found on the board. I'm not quite sure what to measure so would appreciate some advices.
                        Weird thing I noticed is that charging voltage on the battery pin is droping from 8.5v to 0v and than jump back to 3.3v after a while resets again and jumps to 8.5v. I think there may be something wrong with a charging circut.
                        Unfortunately I've got a non original charger so I'm not able to check what LED shows. However that laptop is working fine as i tested it with different laptops.
                        I've...
                        06-29-2023, 09:35 AM
