Macbook A1466 820-00165-A - wont turn on
  • Okrutnik
    • Apr 2022
    I'm having issue with this macbook. No liquid or corrosion found on the board. I'm not quite sure what to measure so would appreciate some advices.
    Weird thing I noticed is that charging voltage on the battery pin is droping from 8.5v to 0v and than jump back to 3.3v after a while resets again and jumps to 8.5v. I think there may be something wrong with a charging circut.
    Unfortunately I've got a non original charger so I'm not able to check what LED shows. However that laptop is working fine as i tested it with different laptops.
    I've checked voltage on all the coils and I'm getting voltage only on 2 of them. 3.3V and 8.5V, rest is 0v
    Please help guys
  • mon2
    • 14337
    Re: Macbook A1466 820-00165-A - wont turn on
    Suggest to source an original and recommended charger and test again.
    If you remove the battery, any difference with the logic board?
    • mferna14
      MacBook Air A1466 does not turn on from keyb ON/OFF button
      by mferna14
      Dear buddies., working on a MacBook Air A1466 (Logic Board 820-00165-A 2017). The logic board turns on fine (This is all done without battery) & the Magsafe jack is lit to orange. I boot it up to OS. Once I shut it down, it does not turn on again unless I remove the magsafe 2 jack & put it back again. There is no liquid spill & the voltages seem to be fine. I re-build a new BIOS & CleanME region done, but the problem still exsist. Once shut down, does not turn on from the keyb power ON/OFF button. I put in a new keyboard & the MagSafe/Audio board & a new flex cable too,...
      08-01-2024, 05:20 PM
    • redbaron1007
      Liquid damaged macbook A1466 fan spins, but doesn't turn on.
      by redbaron1007
      I got a tricky one today in the form of a macbook air A1466 820-00165-A that will recognize the charger and turn the light green then back to orange and the fan will spin constantly, but the system won't power on. The screen never turns on, it doesn't make the bong noise it's supposed to, and pressing the power button doesn't do anything. When I took the board out to visibly inspect it I only found one spot of corrosion on the bios IC. I pulled the chip, cleaned it and the area with IPA and put fresh solder on both and put the bios chip back on, but when I went to test it again it still does the...
      10-24-2024, 05:45 PM
    • Instafixx
      Macbook A1466 820-00165 will not turn on after shut down
      by Instafixx
      Namaste,
      I have a Macbook A1466 820-00165 which has come with erratic issues. it reboots. Trackpad doesnt work. Doesnt Turn on etc.
      Upon inspection
      Corrosion at the Trackpad - changed that to check.
      Some Keys including Power Key and Arrow Keys dont work on the keyboard.
      Wifi Stick Corroded - Changed to Check..
      Corrosion under U3540. Removed and Reballed.
      Now
      The Macbook turns on when plugged to the charger but if we shut it down, it wont turn on when charger connected. Have to remove and install the battery....
      04-17-2023, 01:53 AM
    • Ryan.man
      by Ryan.man
      02-04-2025, 12:23 PM
    • psdavid65
      Macbook Air A1466 820-3437-B Booting Problem
      by psdavid65
      I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
      06-20-2024, 12:27 AM
