hp all in one model 20-r114la white screen problem
  • jonny0404
    • Nov 2014
    • 110
    • Colombia
    hey guys i need help with these intel inside all in one problem is i get white screen on display, i dont see demage on display but i get perfect video by hdmi, question is , you guys think theses is a display problem, i dont se cable flex demage, and i cant find the schematic for these all in one, any one would be kind to tell me any opinion please thanks
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: hp all in one model 20-r114la white screen problem
    Perhaps LCD VDD is missing. You need to check voltage on LVDS pins on mb and compare it with any other mb schematic with similar pin count.
      • 20665
      It could be a corrupt EDID .Whats the panel part number .
      • jonny0404
        • Nov 2014
        • 110
        • Colombia
        i did some measure on the lvd conector in the motherboard
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Your measurements seems strange to me. PIN1,2 and 3 should be together. Check with multimeter are they together or not. If they are together, then thats your LCD VCC line.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            DAN91AMB6D0 RevD-Search this schematic on google. It has 30pin lvds connector-so might help you.
            • jonny0404
              • Nov 2014
              • 110
              • Colombia
              pins 28, 29 and 30 are together...
              • jonny0404
                • Nov 2014
                • 110
                • Colombia
                Connector Pin Assignment
                1 RxO0- Negative LVDS differential data input (Odd data)
                2 RxO0+ Positive LVDS differential data input (Odd data)
                3 RxO1- Negative LVDS differential data input (Odd data)
                4 RxO1+ Positive LVDS differential data input (Odd data)
                5 RxO2- Negative LVDS differential data input (Odd data)
                6 RxO2+ Positive LVDS differential data input (Odd data)
                7 GND Ground
                8 RxOCLK- Negative LVDS differential clock input (Odd clock)
                9 RxOCLK+ Positive LVDS differential clock input (Odd clock)
                10 RxO3- Negative LVDS differential data input (Odd data)
                11 RxO3+ Positive LVDS differential data input (Odd data)
                12 RxE0- Negative LVDS differential data input (Even data)
                13 RxE0+ Positive LVDS differential data input (Even data)
                14 GND Ground
                15 RxE1- Negative LVDS differential data input (Even data)
                16 RxE1+ Positive LVDS differential data input (Even data)
                17 GND Ground
                18 RxE2- Negative LVDS differential data input (Even data)
                19 RxE2+ Positive LVDS differential data input (Even data)
                20 RxECLK- Negative LVDS differential clock input (Even clock)
                21 RxECLK+ Positive LVDS differential clock input (Even clock)
                22 RxE3- Negative LVDS differential data input (Even data)
                23 RxE3+ Positive LVDS differential data input (Even data)
                24 GND Ground
                25 NC No connection (for AUO test only. Do not connect)
                26 NC No connection (for AUO test only. Do not connect)
                27 NC No connection (for AUO test only. Do not connect)
                28 VDD Power Supply Input Voltage
                29 VDD Power Supply Input Voltage
                30 VDD Power Supply Input Voltage
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3577
                  • slovakia
                  u did not see the fault?
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Ok, so PIN28/29/30 is your VDD pin. It should be close to 19V there if this model runs from ac adapter. Check the fuse connected to that pin.
                    • jonny0404
                      • Nov 2014
                      • 110
                      • Colombia
                      yes the fault is vdd was missing on display and is 5v not 19v is very strange, thank you guys.
                      • ahmarzo
                        Asus la-7322p white screen problem
                        by ahmarzo
                        My asus laptop motherboard la-7322p has white screen. Have tried new screen but same problem.lcd vdd is 1.8v when i removed the mosfet an short 3vs with lcdvdd white screen is solved but no data on screen...
                        07-15-2022, 07:52 AM
                      • vpower
                        Asus VivoBook 15 model F512D white screen
                        by vpower
                        I have this laptop showing white screen as soon as I push the power button, it is booting the operating system because I can hear the windows 11 intro sound. If I connect an external LCD with HDMI cable there is no image. Is it possible to hardware disable the AMD gpu in any way? Or any hint?
                        Thanks in advance
                        09-23-2024, 12:50 PM
                      • domu
                        Viewsonic VS16217 strange problem - white flickering screen on power up
                        by domu
                        As per subject, on power up display shows no image, but white
                        flickering screen. Strangely, it only happen after power was lost
                        when it was on. After power returns - white screen only, but if
                        disconnect power for 12-24 hrs, and connect then again monitor
                        works normally.
                        Any clues how to go about it would be greatly appreciated.
                        07-18-2023, 04:57 AM
                      • EazyBone
                        Sharp LC-65Q620U White Screen
                        by EazyBone
                        Another TV topic!!
                        I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                        The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                        Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                        08-21-2024, 12:56 PM
                      • fmajbour
                        Acer Nitro 5 model A515-51 keyboard problem
                        by fmajbour
                        I have ACER Nitro 5 model AN515-51 main board model LA-E911P Rev 1A after replacing the mainboard keyboard stop working properly.
                        Some keys not working like Q,Z,C and some keys show deferent chr$ if i press K i will get I press D for F4 key etc...
                        i have tried all software issues like drivers test the keyboard on Windows 10 and Windows 11 and Linux with same problem.
                        I have check the keyboard connector on the mainboard every thing looks ok.
                        Then i replaced the keyboard with new one ......same problem exact same keys problem.
                        I need your advice if anyone face...
                        11-13-2023, 09:50 PM
