ASUS ROG G751J not turning on, missing 3VSUS_ON
  • maxslo
    • Nov 2013
    • 64
    • Slovenia
    Hello everyone. I have a G751JY laptop that has 2 problems that i think are related.
    Problem #1:
    The laptop takes 20-25s to post, after that though it works flawlessly.
    Problem #2:
    Sometimes the laptop wont turn on, no reaction to the power switch until it's fully drained (which also resets bios config).
    I've checked the schematics and boardview and i've traced the problem to what i think is the root cause of this issue.
    Haven't completely figured out when exactly this happens, but i've got one scenario pinned down where i can reproduce it every time.
    1. Turn on the laptop,
    2. Wait for it to post and enter bios
    3. When it's in the bios unplug the AC (The battery is dead/removed)
    4. When replugging the AC the IT8585VG (U3001) doesn't have 3.3V on the EC_GPF1 net
    I'm also attaching the boardview.
    The IT8585VG datasheet is nowhere to be found, so i'm not really sure what i can do from here. I've read conflicting information regarding the chip needing to be programmed and not.
    On the board there is also a Winbond W25X40CLZPIG which according to the information i've found should hold the EC firmware.
    Any help with solving this problem would be greatly appreciated.
    Thanks.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: ASUS ROG G751J not turning on, missing 3VSUS_ON
    Problem #1 is due to dirty me region. Clean the me region and try again. If you dont know how to do it, then post your original backup bios in bios section and ask for clean me.
    • maxslo
      • Nov 2013
      • 64
      • Slovenia
      I've desoldered the bios and read it, looks like someone has been tampering with it before i got it. It was missing Gbe and ME regions completely and also some sections of the bios.
      I've tried to rebuild it myself and i think i've done it right, i'm attaching both files if some1 can take a look before i solder it to the mobo.
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        Try (Main W25Q64_1.bin first) and leave feedback:
        Become a Badcaps supporter
        Thanks to all supporters.
        • maxslo
          • Nov 2013
          • 64
          • Slovenia
          Hi, I've downloaded these and checked with HxD and they are bioses for G751JL?
          JL is version with GTX 965M while JY has the GTX 980M, is it safe to use this on JY?
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            Yes it's a G751JL version, I don't have a JY one.
            Nothing prevents you from trying. You have a backup, so you can always go back to it. Is it safe? I think so, but I can't be 100% sure, use it at your own risk.
              • 21485
              I agree with you.
              The G751JY bios Posted in the "Bios requests" section .
              https://www.badcaps.net/forum/showthread.php?t=82031 .
              • maxslo
                • Nov 2013
                • 64
                • Slovenia
                Originally posted by SMDFlea
                I agree with you.
                Thanks, I'm trying that now.
                I've also sourced a 206 BIOS dump in another thread and i'll try that later if this one doesn't succeed.
                • maxslo
                  • Nov 2013
                  • 64
                  • Slovenia
                  The 205 version didn't work the laptop starts, but doesnt post and turns off after 15 seconds.
                  I'm trying with a 206 now.
                  • maxslo
                    • Nov 2013
                    • 64
                    • Slovenia
                    The 205 and 206 versions both failed to post, but the rebuilt one i've done posts in about 12 seconds which is half of the time it needed before and i also cannot replicate the issue with no 3VSUS_ON anymore with the steps i was guaranteed to do it before.
                    If i could just get the post time below 5s like normal.
                    Also 2 more things to mention.
                    1. After the first quarter spin animation of windows boot there is a approximately 1s freeze and from there everything goes normally.
                    2. Since the 213 i've rebuilt has been flashed the keyboard backlight no longer work (also windows doesn't register the backlight button combos, all the other onese register just fine)
                    • maxslo
                      • Nov 2013
                      • 64
                      • Slovenia
                      I've gone thru the startup sequence and the laptop completes startup sequence almost immediately, so i'm leaning towards the remaining issues all bein the bios issue.
                      Would it make sense to pull all 3 chips (bios, ec and vbios) and flashing them to the 205 dumps?
                      Sadly the EC chip is not standard SIOC-8 like the bios and vBIOS for which i am just using the clips so i'd have to solder the wires separately.
                        VIP Moderator
                        • Aug 2018
                        • 4386
                        • Bulgaria 🇧🇬
                        Well, you know "if it works, don't touch it".
                        • maxslo
                          • Nov 2013
                          • 64
                          • Slovenia
                          Hehe I know, but it's not completely fixed just yet
                          • khaahk
                            • Dec 2013
                            • 806
                            • Estonia
                            Backlight fix:
                            https://www.badcaps.net/forum/showthread.php?t=69782
                            • maxslo
                              • Nov 2013
                              • 64
                              • Slovenia
                              Originally posted by khaahk
                              I know that this was a thing on the G73 models, but the G751J doesn't have the light switch key, are you sure this also applies to the G751J?
                              • khaahk
                                • Dec 2013
                                • 806
                                • Estonia
                                There are only two things certain in life...
                                Try and find out, it changes one byte in bios in the configuration part. If it messes something up just reflash the bios.
                                • maxslo
                                  • Nov 2013
                                  • 64
                                  • Slovenia
                                  Will do when i get back home from work, thanks for the link
                                  • myth77
                                    • Feb 2017
                                    • 380
                                    • Croatia
                                    pozdrav,
                                    what is your version of motherboard? although they look almost the same there are two verisons of this g751jy board...one is with gsync and other without...
                                    I attached bios for g751jy rev 2.5 (gsync version)...try it.
                                    • maxslo
                                      • Nov 2013
                                      • 64
                                      • Slovenia
                                      Originally posted by myth77
                                      pozdrav,
                                      Hey, it is rev 2.5 indeed, i'll give yours a try. thanks
                                      • maxslo
                                        • Nov 2013
                                        • 64
                                        • Slovenia
                                        The fixmykb worked and i had backlight, i've saved the dump with working backlight and started to load the 205 when i've noticed something odd, the writing was actually failing but the program continued writing not caring about the errors. after reading back i've confirmed that the bios doesn't get written properly, sadly i'm left without a working bios at the moment, i've tried writing to some 4MB chips that i have around and they have corrupted data also.
                                        I'm now looking into why this is happening, is it the clips or the programmer...
                                        I'll update once i get the programmer back up and running.
                                        • ugamazing
                                          820-02020 PPBUS_AON missing
                                          by ugamazing
                                          Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                                          Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                                          02-05-2025, 04:21 PM
                                        • jpreza
                                          Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                                          by jpreza
                                          I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                                          Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                                          It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                                          Looking at the card, it appears to be missing the following:
                                          1x 1.0uH inductor - orange square
                                          2x...
                                          11-01-2024, 10:54 PM
                                        • gurj1979
                                          Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                                          by gurj1979
                                          Hey guys.
                                          Need help with this one.
                                          Fan not spinning due to missing PWN Fan signal.
                                          Also 5 seconds from powering up it freezes, unless in BIOS.
                                          But as soon as Windows starts to load, it will freeze.
                                          CPU is COLD / Room temp when it freezes.
                                          I've replaced the CPU, same problem.
                                          Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                                          Replaced fan - same problem.
                                          Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                                          Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                                          08-19-2024, 05:22 PM
                                        • salopian
                                          Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
                                          by salopian
                                          Hello. I would need some advice please.
                                          My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
                                          He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
                                          I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
                                          I have already replaced the logic board with another...
                                          02-27-2021, 07:30 AM
                                        • ein_individuum
                                          Missing Capacitator Intel I9-12900KF CPU
                                          by ein_individuum
                                          I bought a use Intel I9-12900KF CPU and i received it damaged. But it looks like only one component one the backside is missing. But the solder pads looks fine.
                                          I already "googled" it and compare the backside picture of other LGA1700 12th Gen CPU. They look all the same, no matter if its an I9 or an I3, even the Pentium. And at that spot should be a capacitor.
                                          Does anyone have a schematics or assembly diagramm of the alder-lake cpu-backside? Or just know what size and value i need to replace the missing capacitator.
                                          08-06-2025, 01:36 AM
