asus x555ld no power
  • mmdqn
    • Sep 2019
    • 24
    • Bulgaria
    hello everyone i have a question. When i connect the adapter to the motherboard the voltage goes 1v-1.5v-0.5v and flickers like that. what could this be caused by. Im a beginner and searched a lot on the forum but didnt find anything to help me
  • Techtiger
    • Oct 2014
    • 1601
    • france
    Re: asus x555ld no power
    Dissemble the laptop look for any Burn components most likely a shot you can find the Bordview for this MB
    • mmdqn
      • Sep 2019
      • 24
      • Bulgaria
      i found 2 burned transistors and replaced them but i still get a short....
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        Try to inject 1v~2A to 19V power rail and find what is getting hot, most probably shorted cap somewhere.
        Become a Badcaps supporter
        Thanks to all supporters.​
        • mmdqn
          • Sep 2019
          • 24
          • Bulgaria
          I don't have a variable power supply any ideas how to do it without one ?
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            18650 battery is commonly used for the purpose, but is kind of dangerous if you don't know what you are doing
            >>>Link to Youtube video for you to see how it works<<<
            • Techtiger
              • Oct 2014
              • 1601
              • france
              Upload the pic of the area you have replaced Transistor PQ? Did you check for the bordviewr
              • mmdqn
                • Sep 2019
                • 24
                • Bulgaria
                soo i found the area of the short. checked the components 1 by one and the ones in red are shorted to ground i checked the others connected to the PU8200 and they are fine. also i removed the pu8200 to check if the short would dissapear and it didnt. Any help would be appreciated.
                EDIT: not sure why the image won't load so ill add an imgur link. https://imgur.com/a/tcGWh8x
                • Vesko356
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria 🇧🇬
                  Because you must tag the image address not a web page, so to speak tagged address must be ending with *.png or *.jpg and so on.
                  Code:
                  https://imgur.com/a/tcGWh8x ---> Not OK
                  https://i.imgur.com/CqLzzqr.png ---> OK
                  Upload the boardview and schematic here, this image alone is not enough to see what we are talking about.
                  The image:
                  • mmdqn
                    • Sep 2019
                    • 24
                    • Bulgaria
                    here is the boardview
                    • Vesko356
                      VIP Moderator
                      • Aug 2018
                      • 4386
                      • Bulgaria 🇧🇬
                      Excellent, now it's way bettеr.
                      I saw quickly the boardwiew, and will suggest to open the jumper PJP8200, then to check if the short is still present or not, if the shot is gone check the caps PC8205, PC8206 and PC8207 then come back with the result here.
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3582
                        • slovakia
                        before u inject voltage to main rail, u must check if u dont have shorted some of high side mosfet
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Rightly said. It's a must and those who ignores these basic steps, kills the cpu/gpu.
                          • mmdqn
                            • Sep 2019
                            • 24
                            • Bulgaria
                            so i opened the jumper PJP8200 and checked the 3 caps PC8205 PC8206 PC8207 and they are not shorted but im still getting a 0.00 on both sides pc8217. i removed it and checked and it works
                            • mmdqn
                              • Sep 2019
                              • 24
                              • Bulgaria
                              i didnt inject voltage into the 19v rail because i dont have a variable power supply or any good 18650 cells
                              • Vesko356
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                Question - applying 1v to the 19v power rail will cause a problem with the cpu/gpu or not?
                                Check caps PC8226 PC8227 PC8203 PC8201
                                ...also i removed the pu8200 to check...
                                BTW it is still removed from the board or you solder PU8200 back in place?
                                • mmdqn
                                  • Sep 2019
                                  • 24
                                  • Bulgaria
                                  pc8226 is empty on my board because it is not the exact model as the schematic but it is shorted i get 0 on both sides.
                                  PC8203 PC8201 are not shorted and yes i did put back pu8200 because the short didnt go away with it removed.
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    @Vesko356, my comments not meant for you. Lots of newbies join our forum and they do commit this type of silly mistakes. As far as your question or comment about 1V-2A power on B+ rail is definitely not going to kill cpu even if high side fet is shorted.
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      @mmdqn, it will be a puzzle to actually find a shorted cap without lab psu. Get one for you at the earliest.
                                      • mmdqn
                                        • Sep 2019
                                        • 24
                                        • Bulgaria
                                        is there a cheap one you can recommend ?
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • ShadowAi
                                          ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                                          by ShadowAi
                                          Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                                          Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                                          After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                                          03-15-2024, 10:46 AM
                                        • meraklinetx
                                          Asus Z97-a power cycle, no boot no cpu voltage
                                          by meraklinetx
                                          Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                                          05-10-2023, 06:08 AM
