asus x555ld no power
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3577
    • slovakia
    Re: asus x555ld no power
    Question - applying 1v to the 19v power rail will cause a problem with the cpu/gpu or not?
    No but with this low voltage u have problem to deliver right amount of power to heat up bad component
      VIP Moderator
      • Aug 2018
      • 4386
      • Bulgaria 🇧🇬
      @Vesko356, my comments not meant for you. Lots of newbies join our forum and they do commit this type of silly mistakes. As far as your question or comment about 1V-2A power on B+ rail is definitely not going to kill cpu even if high side fet is shorted.
      Originally posted by ktmmotocross
      No
      It's enough to find basic problems like shorted cap ans so on.
      Originally posted by mmdqn
      pc8226 is empty on my board because it is not the exact model as the schematic but it is shorted i get 0 on both sides.
      PC8203 PC8201 are not shorted and yes i did put back pu8200 because the short didnt go away with it removed.
      Check PR8214 must be 10K OHM, check resistance and both side to ground.
      Become a Badcaps supporter
      Thanks to all supporters.​
      • mmdqn
        • Sep 2019
        • 24
        im getting 4.2k on pr8214
          VIP Moderator
          • Aug 2018
          • 4386
          • Bulgaria 🇧🇬
          OK, check PC8210 PC8211 PC8212 PC8213 PC8214 PC8215
          • mmdqn
            • Sep 2019
            • 24
            on all of them i get 0.0
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria 🇧🇬
              #26
              Unsolder PL8200, open PJP8201 and then check again PC8210 PC8211 PC8212 PC8213 PC8214 PC8215
              • mmdqn
                • Sep 2019
                • 24
                #27
                i unsoldered PL8200 but i cant find a jumper. Desoldered pc8210 because it said that the jumper is below but there is no jumper. and there is still a short on the others.
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria 🇧🇬
                  #28
                  I said PJP8201 not PJ8201
                  • mmdqn
                    • Sep 2019
                    • 24
                    #29
                    sorry my bad opened the jumper and the short is gone
                      VIP Moderator
                      • Aug 2018
                      • 4386
                      • Bulgaria 🇧🇬
                      #30
                      That's bad, very bad - I really hoped the short will remain. How much is the voltage drop (diode mode) between pin 2 of the PJP8201 to ground?
                      On the other side of the board check caps C2606 C2622 C2623 C2626 C2634 C2611, I really really hope some of that caps to be shorted and to be the reason.
                      • mmdqn
                        • Sep 2019
                        • 24
                        #31
                        0.0 well i guess the cpu is gone ?
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          #32
                          Maybe, but there is still few remaining chances to be something else.
                          Check caps C2606 C2622 C2623 C2626 C2634 C2611 I really hope some of them to be in short.
                          • mmdqn
                            • Sep 2019
                            • 24
                            #33
                            C2622 C2623 C2626 C2634 C2611 are all shorted to ground i get 0.0 on all of them c2606 is working
                              VIP Moderator
                              • Aug 2018
                              • 4386
                              • Bulgaria 🇧🇬
                              #34
                              OK excellent, there is still a chance one of them to be the cause , start desoldering the caps one by one and check if the short is gone.
                              And little correction CE2606 instead of C2606.
                              Start from CE2606 then C2622 and the others after that.
                              • mmdqn
                                • Sep 2019
                                • 24
                                #35
                                desoldered all of them 1 by 1 and still a short... guess the cpu is dead
                                  VIP Moderator
                                  • Aug 2018
                                  • 4386
                                  • Bulgaria 🇧🇬
                                  #36
                                  Damn it!!!
                                  Including CE2606, and all caps was good and not shorted?
                                  How much is the resistance between pin 2 of the PJP8201 and ground now?
                                  Tell me the values in diode mode and ohm mode.
                                  • mmdqn
                                    • Sep 2019
                                    • 24
                                    #37
                                    all caps were good resistance in diod mode is 0.0 in ohm mode is 5 ohms
                                      VIP Moderator
                                      • Aug 2018
                                      • 4386
                                      • Bulgaria 🇧🇬
                                      #38
                                      I'm sorry man, I will look more carefully boardview again tomorrow, but for now I can tell you the cpu is most probably gone.
                                      • mmdqn
                                        • Sep 2019
                                        • 24
                                        #39
                                        Thank you for the effort and time you put into this
                                          VIP Moderator
                                          • Aug 2018
                                          • 4386
                                          • Bulgaria 🇧🇬
                                          #40
                                          Thank you too man, you are nice and skillful guy, it was a pleasure for me to assist you in this repair attempt. I'm really sorry we can't defeat Asus time. Yea such a pity, but we will win next time.
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • ShadowAi
                                            ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                                            by ShadowAi
                                            Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                                            Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                                            After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                                            03-15-2024, 10:46 AM
                                          • meraklinetx
                                            Asus Z97-a power cycle, no boot no cpu voltage
                                            by meraklinetx
                                            Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                                            05-10-2023, 06:08 AM
