hello everyone i have a question. When i connect the adapter to the motherboard the voltage goes 1v-1.5v-0.5v and flickers like that. what could this be caused by. Im a beginner and searched a lot on the forum but didnt find anything to help me
asus x555ld no power
Become a Badcaps supporter
Thanks to all supporters.​
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Re: asus x555ld no power
18650 battery is commonly used for the purpose, but is kind of dangerous if you don't know what you are doing
>>>Link to Youtube video for you to see how it works<<<
Last edited by Vesko356; 02-05-2020, 01:04 PM.----------------------------------------------------------------------------------------------------------------------------------------------------------
soo i found the area of the short. checked the components 1 by one and the ones in red are shorted to ground i checked the others connected to the PU8200 and they are fine. also i removed the pu8200 to check if the short would dissapear and it didnt. Any help would be appreciated.
EDIT: not sure why the image won't load so ill add an imgur link. https://imgur.com/a/tcGWh8xLast edited by mmdqn; 02-06-2020, 11:49 AM.Comment
Because you must tag the image address not a web page, so to speak tagged address must be ending with *.png or *.jpg and so on.soo i found the area of the short. checked the components 1 by one and the ones in red are shorted to ground i checked the others connected to the PU8200 and they are fine. also i removed the pu8200 to check if the short would dissapear and it didnt. Any help would be appreciated.
Upload the boardview and schematic here, this image alone is not enough to see what we are talking about.Code:https://imgur.com/a/tcGWh8x ---> Not OK https://i.imgur.com/CqLzzqr.png ---> OK
The image:
Last edited by Vesko356; 02-06-2020, 12:43 PM.----------------------------------------------------------------------------------------------------------------------------------------------------------
here is the boardviewAttached FilesComment
Excellent, now it's way bettеr.
I saw quickly the boardwiew, and will suggest to open the jumper PJP8200, then to check if the short is still present or not, if the shot is gone check the caps PC8205, PC8206 and PC8207 then come back with the result here.----------------------------------------------------------------------------------------------------------------------------------------------------------
before u inject voltage to main rail, u must check if u dont have shorted some of high side mosfetComment
Question - applying 1v to the 19v power rail will cause a problem with the cpu/gpu or not?
Check caps PC8226 PC8227 PC8203 PC8201
BTW it is still removed from the board or you solder PU8200 back in place?Last edited by Vesko356; 02-07-2020, 07:33 AM.----------------------------------------------------------------------------------------------------------------------------------------------------------
@Vesko356, my comments not meant for you. Lots of newbies join our forum and they do commit this type of silly mistakes. As far as your question or comment about 1V-2A power on B+ rail is definitely not going to kill cpu even if high side fet is shorted.Comment
@mmdqn, it will be a puzzle to actually find a shorted cap without lab psu. Get one for you at the earliest.Comment
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
Assuming...7 Photos -
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
by ShadowAiHello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,... -
by meraklinetxHello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
- Loading...
