Aser ES1-531 USB not work
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3553
    • slovakia
    Hello.
    Have this ACER ES1-531 that have not working usb. It have damagedUSB3.0 port that i replaced, but all USB not work. All have 5V. I removed EU3401 but no luck. How to test if U3501 is bad?
    what can be wrong and how to test it?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3553
    • slovakia
    Re: Aser ES1-531 USB not work
    i replace U3501 8111H with some other 8111H but no luck
    Windows shows error on xHCI USB controller
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      u3501 Pin 1-2 and 6-7 resistance??
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3553
        • slovakia
        damn both pairs are shorted between them
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3553
          • slovakia
          do u think this two is compatible?
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3553
            • slovakia
            I think im screwd. Both pair are shorted between them even with chip removed
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3553
              • slovakia
              loool i made huge mistake. i was measuring and replacing LAN controller :-)
              So now i measure USB 3.0 lines and one pair is shorted to ground and 5ohm short between them
              I replace u3501, but still the same.
              Measure pair lines from U3501 to CPU and one line have 3,3 and other have 0,0V , no short
              Measure usb hub lines and one line have 3,13V and other have 0,0V, no short to ground
              do u think that blown usb 3.0 in CPU can broke usb 2.0 ?
              • chth96
                How Can I test PWM DM0365R?
                by chth96
                Hello
                I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                06-18-2025, 04:14 PM
              • chronic519
                Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                by chronic519
                Hello.
                GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                Found issue with a RAM block
                Replaced, green lines gone.
                Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                Used a good card to test and same results low errors 32+.
                I am just search for some form of command to do a full test on the GPU.
                I just ran the mats command with my good GPU and passed after roughly 40 min.
                The repaired one, ran...
                05-20-2025, 07:56 PM
              • hollox123
                ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
                by hollox123
                Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
                1. Laptop keyboard doesn't work
                2. The backlight on the laptop keyboard doesn't work
                3. The x2 side LEDs (red) on the laptop don't work
                The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
                I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
                But I am strongly aiming that it is somehow a BIOS-related problem,...
                05-11-2025, 08:05 AM
              • langbaobao
                DIY 3D-Printer WSON8 Pogo Pin Adapter
                by langbaobao
                Hi.
                I'm posting this here in part as a memo to self as well as to describe the procedure I used in case anyone else found it useful. I found a lot of the necessary information to make this work on this forum and I figured I would give something back. If this is not the appropriate place to post this, I don't mind it being deleted but I hope it can help other people.
                I got an admin password locked HP Elitebook 840 G5 recently that I wanted to unlock. I'm a relative newcomer to reprogramming and unlocking firmware. The only previous experience I had was unlocking a BIOS...
                01-08-2024, 05:58 PM
              • alltvrepairs
                Lg TCon test pins for screen test
                by alltvrepairs
                i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                Appreciate your help....
                06-13-2025, 06:33 AM
