Asus fx553vd keyboard, usb not working
+ More Options
Posts
  • myth77
    • Feb 2017
    • 380
    • Croatia
    So laptop boots fine to windows but keyboard is not working... Tried with usb keyboard but nothing...even in bios. So it seems that all usb ports are not working and keyboard, and usb mouse .Hdmi and ssd working. Used bios dump i found but same...
    Any suggestion where to look?
    Oh, one other thing...when i inserted usb keyboard it did show those three lights but nothing...not working..
  • myth77
    • Feb 2017
    • 380
    • Croatia
    Re: Asus fx553vd keyboard, usb not working
    Update...
    The touchpad is working so i was able to install a new copy of windows..
    In control panel i have error code 10 on usb xhci compliant controller driver..and thats the reason why keyboard and usb are not working.
    Also, when i try to restart laptop all is fine, but when i tried to shutt it down...it stays forever on black screen but not shutting down complete...
    Any advice?
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3616
      • slovakia
      find schematic. check usb connectors for damaged pins
      • rediii
        h???, spurrrn
        • Mar 2018
        • 496
        • somewhere in europe
        Originally posted by myth77
        Update...
        Any advice?
        do you have any power on usb ports (seems so, he?)? check with usb volt/amp module. if yes, maybe data-line filters are corrupted but i think it's a/the hub controller/driver or maybe in the worst case the pch... usb 3.0/2.0?
        • myth77
          • Feb 2017
          • 380
          • Croatia
          there are two usb 3 ports and one usb 2 port on daughter board.
          i did some testing and found voltages....so when i put usb charger for mobile phone it will charge the phone but obviously no data communication....so i believe its either it8176fn embadded controler failure or pch failure.
          I tried to find short somewhere but there is none. So maybe drivers on it8176fn are corrupted but i dont know how to check? the main controller it8587 is programmed directly from bios, but what about it8176fn? any ideas?
          I attached boardview, its the gl553vd v 2.0, just first flip it horizontaly
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3616
            • slovakia
            check for shorts on datapins and check data pins filters for continuity
            • myth77
              • Feb 2017
              • 380
              • Croatia
              i have 5 volts reading on 5v pin. Resistance to gnd on all pins seems ok:
              pin 1 +5V
              pin 2 USB PN1 30 R 1900 OHM
              pin 3 USB PP1 30 R 1900 OHM
              pin 4 GND
              pin 5 USB RXN1 R 800 OHM
              pin 6 USB RXP1 R 800 OHM
              pin 7 GND
              pin 8 USB TXN1 R
              pin 9 USB TXP1 R
              pin 10 GND
              pin 11 GND
              pin 12 GND
              pin 13 GND
              • myth77
                • Feb 2017
                • 380
                • Croatia
                update...
                When i press restart in windows its ok...but when i press shutdown in windows it will go to idle forever...and i have to force shut it down. Also when go to the idle the screen goes black and i can see this (_) in the screen in upper right corner blinking all time...
                I extracted the ite8587 and it8176fn ec and compared it with working dumps and they are the same.
                Used threee more bios dumps i found and i cleaned them but result is the same...
                The resistence +1.0 vsus on pch chip is low 2,8 ohm...but i read with multimeter arround 1.0 voltage so its seems fine?
                I check every resistor and capacitor near pch but didnt find short anywhere...
                I check every resistor and capacitor near usb ports but didnt find short anywhere...
                I am out of ideas...any ideas? any help?
                • jasko_jacker
                  • Oct 2014
                  • 1140
                  • italy
                  In these models, the pch is often the cause of many problems, but I do not recommend replacing it without making tests that are not simple. Enable windows logs and try to understand why it does not turn off.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Remove Lan chip and see if it shuts down completely. PCH_Wake signal checked??
                    • alimohammad
                      • Oct 2020
                      • Iran
                      Hi
                      I've the same problem, I want to know that could you find a solution for this problem? I've searched in Internet and figured out that this may be because of damaging to SouthBridge but I'm not sure. If you found a solution I'd be happy to help me to fix my laptop too����
                      • myth77
                        • Feb 2017
                        • 380
                        • Croatia
                        Hello... first i also read all over the internet same problem on this series...gl553, fx553, zx53 but they have all same motherboard.
                        In the end i believe its pch fault because i tried everything beside replacing pch chip...i reprogramed both ite chips...and so on... but usb ports and keyboard would not work. I didnt try to replace the pch chip itself because it was not worth the trouble...But i will tell you why i think its pch...
                        First, the resistence was very low, +1.0vsus was only 2.8 ohm as far as i can remember...what confused me is that i had picture and touchpad was working, wlan also. ssd....so it seems that pch chip was partially working?! And becuase of that i tried to isolate where low ohm is coming from..maybe its not from pch ?..but removing capacitors and resistors led me to believe that 2,8 ohm low was coming from pch chip itself.
                        Maybe its something more dead but this low ohm is not normal for sure.
                        If you have same low ohm readings and will replace pch chip come here later with report
                        • alimohammad
                          • Oct 2020
                          • Iran
                          Hello again
                          I wanna u know that I changed the pch with new one and after that keyboard and usb are working fine, tnx for helping )
                          • alimohammad
                            • Oct 2020
                            • Iran
                            But after changing the pch, I've faced with new problem, when I want to turn on my laptop, after pushing power botton, I have to wait 18s to see asus logo but before that it took less than 5s to show asus logo. I've update bios to last version with EZ flash in bios but again nothing changed so do you have any idea what should I do to fix this delay?
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              You need to clean me region of your bios.
                              • dokterpc
                                • Aug 2020
                                • 47
                                • Indonesia
                                Hey i wanna know it8176 must be flashed or just change without flash?? This type asus most trouble in it8176
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  For asus, EC will flash itself on 1st boot as long as its blank and the main bios is not corrupt.
                                  • dokterpc
                                    • Aug 2020
                                    • 47
                                    • Indonesia
                                    Thanks i'll try replace it, bcoz i try reflow the ic kb can use normal but less an hour it's not function again
                                    • ktmmotocross
                                      Asus G513QE keyboard and backlight not working
                                      by ktmmotocross
                                      Have this Asus G513QE with keyboard, keyboard backlight and Led backlight not working. other works ok.
                                      i measure all voltages ok on keyboard, KB backlight and Led backlight. looks like a kbc error.
                                      but as laptop works i think it cannot be bad. maybe its FW. have anybody some hint for this?
                                      08-08-2025, 06:29 AM
                                    • Kambi13
                                      Asus N550JV Keyboard not working properly
                                      by Kambi13
                                      Hi there need some advise. I have an Asus N550JV-CN102H with board N550JV Re2.1 suddendly started to behave weird, with almost no keys working on keyboard, opening random stuff, touchpad also working weird
                                      Nothing has been spilled. Tought, well keyboard has gone bad, ordered a replacement one, installed it, and to my surprise the issue remains the same....
                                      I'm wondering if the EC has gone Bad. Updated Bios also, but with no avail.... Does anyone knows if ITE IT8585E/FX has to be programmed?
                                      11-28-2024, 02:05 PM
                                    • fichamba
                                      MSI GL75 Leopard keyboard (almost) not working - HELP
                                      by fichamba
                                      Hello everybody:
                                      Let me put all the laptop's info before describing the problem:
                                      BRAND: MSI
                                      MODEL No.: MS-17E7
                                      SKU: GL75 Leopard 10SEK-261XES-BB71075H16GXXDXX
                                      MoBo: MS-17E71 VER. 1.0
                                      This laptop arrived to fix the broken left hinge, due to a hit. The hinge was repaired, and when I went to check it out, everything worked well, but I observed certain artifacts (mainly random lines) in the screen.So I decided to remove the screen bezel again, and I saw certain damage to the main LCD harness.
                                      This time I also observed that the right...
                                      10-09-2024, 04:53 PM
                                    • SuperAman
                                      Keyboard replacement not working issues with Win 10/11 (2) different laptops
                                      by SuperAman
                                      I have had an issue that I've never come across in all my years of laptop repairs and it has happened twice in the last couple of weeks. The issue occurred on 2 laptops.
                                      1. The first laptop a Lenovo Yoga 7 convertible 14 inch 13th gen i7. This laptop came in working, customer wanted to replace the top keyboard assembly for cosmetic reasons so I replaced the keyobard assembly and put their touchpad in it. After booting into windows it would not work, so I assumed I needed to update it or something. Since they didn't give me the Admin account, as it was a company laptop and the...
                                      08-31-2024, 07:30 PM
                                      ASUS FX553VD-DM645T Notebook Specification for Upgrade or Repair
                                      This specification for the ASUS FX553VD-DM645T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX553VD-DM645T boardview and FX553VD-DM645T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                      09-06-2024, 08:00 AM
