MSI GL75 Leopard keyboard (almost) not working - HELP
  • fichamba
    • Dec 2011
    • 132
    • Spain
    Hello everybody:
    Let me put all the laptop's info before describing the problem:
    BRAND: MSI
    MODEL No.: MS-17E7
    SKU: GL75 Leopard 10SEK-261XES-BB71075H16GXXDXX
    MoBo: MS-17E71 VER. 1.0
    This laptop arrived to fix the broken left hinge, due to a hit. The hinge was repaired, and when I went to check it out, everything worked well, but I observed certain artifacts (mainly random lines) in the screen.So I decided to remove the screen bezel again, and I saw certain damage to the main LCD harness.
    This time I also observed that the right hinge was also almost loose, so I decided to fix it up also (until then, the only thing I removed was the plastic bezel of the screen). But when I needed to change the harness by the new one, obviously I removed the back cover, installed the new harness, and with both hinges repaired and the new harness installed, I closed everything.
    I turned on the laptop, everything was fine (both hinges and screen's image), BUT only a very few keys worked (very few). Of course, the keyboard wasn't damaged at all.
    After several tests of the original keyboard with no luck and no changes at all, I decided to order a new keyboard (in my mind something told me that the problem was not the keyboard, but in spite of it, I ordered a new one).
    The new keyboard arrived, but the effect is exactly the same: keys not working, and the very few working ones are the same as in the original keyboard. The RGB part of both keyboards works perfectly well.
    I searched here for the schematic, but I only saw the boardview for this model, so I decided to buy the schematic (and share it here). But after looking at all voltages, EC, BIOS, etc., I am not able to detect any failure. Of course, the trackpad and its associated buttons are working, and you can use an external keyboard without problems.
    But I'm desperate because I didn't see any causes for this failure. Of course, I removed all the flat cables going to the MoBo, and I leaved only the one of the keyboard. I tested this one by one, and all at the same time. Only with battery, only with original charger, with lab PSU, removing the LCD cable from the MoBo and using and external HDMI monitor...nothing!. Same (d)effect.
    I beg your help. If any of you here have any idea, please let me know, and I will test it. It will be great, because my brain is empty of ideas to this regard. Of course, I carefully inspected with the microscope all the MoBo for broken or faulty components, and everything's fine. New and clean as from factory.
    Thanks in advance for your invaluable help. If somebody needs any kind of information regarding this laptop, please let me know. My client is desperate too!.
  • rogfanther
    • Jul 2006
    • 458
    • Brazil
    Try with the old screen cable, even if you need to temporary fix it for the test.
    • fichamba
      • Dec 2011
      • 132
      • Spain
      Thank you, but the old cable is destroyed, literally. I still have it, but it’s sure it won’t work.
      My last discovery is that the EC (which ever runs cool) it’s running hotter than normal. It’s warm if you touch it. I will make a thermography and post here the temperature.
      Thanks anyway!!
      • fichamba
        • Dec 2011
        • 132
        • Spain
        Forget it. The thermal camera revealed normal operating temperature of the EC (around 30°C).
        • fichamba
          • Dec 2011
          • 132
          • Spain
          Hello again,
          Could anybody help with this? I’m still waiting for a bit of light…
          TIA!
          • mon2
            • 14368
            Can you share the link for the schematic?
            Is the EC with an external or internal flash for the firmware?
            • fichamba
              • Dec 2011
              • 132
              • Spain
              Thanks a lot, mon2.
              The EC uses its own internal flash memory, and I can confirm that the EC is right, according to both my SVOD3 and SVOD4. Same for the BIOS.
              Here you have both the schematic and BW:
              https://www.badcaps.net/forum/troubl...hematic-needed
              I tested the laptop in every possible manner; with internal keyboard connected (both, because I have a new one as commented), without any keyboard connected (nor any external one), with and without trackpad…
              A curious thing is that it writes by itself, at the very beginning of being started in Windows 10, one character: ç (???).
              Of course, I tried installing W10 from scratch into another NVME, with same results.
              It's the most rare effect that I've found in any repair.
              If you need more info, here I am.
              • fichamba
                • Dec 2011
                • 132
                • Spain
                An small video…this is weird. Specially because the EC is tested and working!
                • mon2
                  • 14368
                  The HID I2C driver is missing in the Windows OS -> can you apply the driver package for this chipset / motherboard to pacify this yellow marked device? It may be important to fix the issue.
                  • fichamba
                    • Dec 2011
                    • 132
                    • Spain
                    Thanks a lot, mon2! I will do it NOW! (…it seemed to me that I saw this in some place inside the laptop…in the device manager, maybe?)
                    EDIT:
                    I have done it. It's solved now. But nothing changed… 😫 and yes: I saw it in device manager.
                      MSI Gaming GL75 10SDR-646UK Leopard Notebook GL Specification for Upgrade or Repair
                      This specification for the MSI Gaming GL75 10SDR-646UK Leopard Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL75 10SDR-646UK Leopard boardview and GL75 10SDR-646UK Leopard schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-07-2024, 01:30 AM
                      MSI Gaming GL75 10SDR-277CZ Leopard Notebook GL Specification for Upgrade or Repair
                      This specification for the MSI Gaming GL75 10SDR-277CZ Leopard Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL75 10SDR-277CZ Leopard boardview and GL75 10SDR-277CZ Leopard schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-07-2024, 01:00 AM
                      MSI GL75 Leopard 10SDR-636 Notebook Specification for Upgrade or Repair
                      This specification for the MSI GL75 Leopard 10SDR-636 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL75 Leopard 10SDR-636 boardview and GL75 Leopard 10SDR-636 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      MSI Gaming GL75 10SDK-614CZ Leopard Notebook GL Specification for Upgrade or Repair
                      This specification for the MSI Gaming GL75 10SDK-614CZ Leopard Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL75 10SDK-614CZ Leopard boardview and GL75 10SDK-614CZ Leopard schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      MSI Gaming GL75 10SEK-615CZ Leopard Notebook GL Specification for Upgrade or Repair
                      This specification for the MSI Gaming GL75 10SEK-615CZ Leopard Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL75 10SEK-615CZ Leopard boardview and GL75 10SEK-615CZ Leopard schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
