la-9104p MB 7 Beeps error and no display
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Need help i have Dell 3521 la-9104p MB 7 Beeps error no display
    Histoire of the MB 7 Beeps power up no display CPU CORE missing, close up inspection sort of glue liquid damage bottom side , clean up the MB flash EC BIOS from the Badcaps Mcpslsg123 have upload it MB power up with post all ok except now the MB randomly goes to 5 Beeps error with out post no image change the BIOS battery same error with or without BIOS battery, do I have to flash main bios ?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: la-9104p MB 7 Beeps error and no display
    What's the harm friend?? I always prefer flashing both main+ec-so that they belong to same version. Have seen cases where main and ec bios version difference creates problem. RTC circuit should be checked.
    • Techtiger
      • Oct 2014
      • 1602
      • france
      I flash the main bios but the problem remains same I did trace RTCVCC up to PCH 3caps seems to be ok
      • imranromi
        • Jan 2015
        • 1290
        • Pakistan
        When give beep then press power button about 20,30 sec then press again and check what happen.
        Read post #6
        https://www.badcaps.net/forum/showthread.php?t=70433
        • Techtiger
          • Oct 2014
          • 1602
          • france
          Read post #6
          Imranromi post#6 not working for me Mb randomly goes to five beeps
          • caspian
            • Oct 2015
            • 1591
            • Laptop
            When it gives five beeps, which voltage/signal is not present?
            • Techtiger
              • Oct 2014
              • 1602
              • france
              VCC GFC CORE PL700 missing with 5 beeps
              • caspian
                • Oct 2015
                • 1591
                • Laptop
                Had the liquid infected the PCH or its nearby components?
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Reflash both main and EC from another batch. To me it still seems bios issue.
                  • Techtiger
                    • Oct 2014
                    • 1602
                    • france
                    sort of glue liquid damage bottom side but not near PCH
                    • Techtiger
                      • Oct 2014
                      • 1602
                      • france
                      ok will do and let you know
                      • Techtiger
                        • Oct 2014
                        • 1602
                        • france
                        the problem remains same after flashing couple of bios the MB randomly goes to 5 Beeps error with out post no image
                        • lapfix
                          • Mar 2020
                          • 2764
                          • my workshop
                          Got the same problem at 2 boards..change dump /chip still the same ,try to clean ME region the original dump still this 7 beeps but...
                          I see a trick posted by imranromi for 5 beep : press power button hold 20 sec and press again wait for display.
                          I try it still got the 7 beep but i have 1.124V at Pl701 ( The VCC cORE ) and no display...the current go from 0.12 amp to 2.20 .
                          any idea about that !
                          • Techtiger
                            • Oct 2014
                            • 1602
                            • france
                            SIO pin 4 5 7 8 9 Voltage ?
                            • lapfix
                              • Mar 2020
                              • 2764
                              • my workshop
                              All 3.41v
                              • Techtiger
                                • Oct 2014
                                • 1602
                                • france
                                you have 3 resistors near the UH6 check voltage both sides of them
                                • lapfix
                                  • Mar 2020
                                  • 2764
                                  • my workshop
                                  Yes i measure them before ,but only on OHM ... all are 33 OHM.
                                  Votage RH265 = 3.4v from the 2 sides
                                  Voltage RH266 / RH267 = 0V from the 2 sides
                                  • lapfix
                                    • Mar 2020
                                    • 2764
                                    • my workshop
                                    For DRAMRST# , i think it must be active low ! i find 0.049v at pin 30 of ram slot.
                                    Any other place to check !!
                                    • Techtiger
                                      • Oct 2014
                                      • 1602
                                      • france
                                      Voltage on QC2 all pins do you have a working la-9104P CR108? RH266 / RH267 To check the voltage on those 2 resisters
                                      • lapfix
                                        • Mar 2020
                                        • 2764
                                        • my workshop
                                        QC 2 :
                                        D = 0.049v
                                        G = 3.40v
                                        S = 0.049v
                                        RC108 = 1.5v from one side and 0.049v from the second side.
                                        I can find a working motherboard to compare RH 266/267.
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • lanovey
                                          SF314-41 BIOS without internal display
                                          by lanovey
                                          Hello there,
                                          I have a SF314-41 motherboard that i bought impulsively recently, the problem is that i only bought the motherboard only, nothing else. When i tried powering on the board with 19V (soldered on the DC IN port), and then shorting the pin 1-2 of the keyboard, the board is turning on (as indicated by the fan), however it seems like the board is displaying on the internal display as connecting to a display on the HDMI (external) does not display anything.
                                          I tried connecting a USB keyboard, the keyboard is powered on, however pressing numlock do nothing (supposed to toggle...
                                          06-13-2025, 02:38 AM
                                        • AustinCER
                                          HP ENVY Desktop TE01-1214 - No Display, Powers On, Corrupt BIOS
                                          by AustinCER
                                          I currently have an HP ENVY Desktop TE01-1214
                                          S/N -
                                          2MO22342GX
                                          Motherboard - L75365-001
                                          BIOS Chip - W25Q128JVSQ
                                          Suspected Windows updates contained BIOS update in which, during update the Desktop PC displayed a black screen to the monitor while still powered on. Display image never restored.
                                          Tested RAM in both slots, as well as new RAM. Tested a brand new known working i5-10th Gen GPU (Same CPU as original installed). Cleared CMOS. Tested the Desktop PC with a dedicated GPU connected, but still no display. Device will not POST when powered...
                                          04-25-2025, 05:56 PM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • ikelectro
                                          After bios recovery by pen drive HP15s eq0007AU display flashing a light for short time.
                                          by ikelectro
                                          Schematic : DAOP5EMB6E0 REV:E​
                                          I have tried manually flashed the bios, also tried hp bios recovery tools to recover the bios. But no luck. Display is not coming, 3 to 4 times recovery display is coming if I tried to recover by pen drive[win+ B]. But after restarts it goes to dark screen and a light is flashing after a certain time in the display + fan speeds increasing and decreasing. I have tried almost every bios for this motherboard avaiable in the internet.
                                          Any help or guide to proceed?...
                                          03-19-2025, 08:17 PM
